Full Version: Multiple Movie Set Tags
I was wondering is XBMC will support Movie Sets within Movie Sets.
For Example:-
I would like to create a Movie Set Called "Tales of Middle Earth"
Under this set I would like to have "The Lord of the Rings" as a Movie set, then another for "The Hobbit" Movies
So it should look like something below
- The Lord of the Ring Trilogy
- The Fellowship of the Ring
- The Two Towers
- The Return of the King
- The Hobbit
- An Unexpected Journey
- "Hobbit Movie 2"
- "Hobbit Move 3"
Thanks to any replies
many times asked, many times said no
To add on to Martijn's response, you can use multiple <tag> tags to accomplish something similar.
