I have been searching google and the forums but i can't find a topic regarding this. I looked but it does not seem possible to display In-Progress Episodes, only for Movies. Is there a add-on or script or something so i could display them? thanks
Im on Win7 AEON NOX 4.0 and Frodo 12.1
Smartplaylists can give u this. If you set it to type tvshow, then it will display the shows you are currently watching, if u set it to episode, it will display episodes that have been started but not yet finished
This is how i have mine i also have same one setup for movies you can also set it for displaying shows with incomplete episodes but i preferred to display those particular episodes
i also didn't want every show i never finished or someone in my house didn't finish so as you can see i limited what it displays to the last 25 items you can go smaller or larger depending on what you prefer
Protocool77 and endlesslyonline im sorry i should have explained my situation better. what i meant is in the main menu i want in progress episodes as a widget. like my movies. Also i do not have my TVSHOW as smart-playlist only my movies have smart playlist.
Already exists. In progress tv shows is called 'Recommended Episodes'.
(2013-05-05, 08:56)Vaikin Wrote: [ -> ]Already exists. In progress tv shows is called 'Recommended Episodes'.
never seen anything called 'Recommended Episodes'?
There is an "In Progress" submenu option but is does not work... it shows everything, not just shows that have been started & not completed
It would be great if it did work properly.
The in progress submenu is for tv shows that you are watching and haven't finished, not for episodes that you haven't finished.
As for in progress episodes widget:
http://i.imgur.com/OEOpw8G.jpg
(2013-05-06, 07:46)Vaikin Wrote: [ -> ]The in progress submenu is for tv shows that you are watching and haven't finished, not for episodes that you haven't finished.
As for in progress episodes widget: http://i.imgur.com/OEOpw8G.jpg
Ok i will set that option thanks strange way to word it i suppose. Anyhow thanks for the help Vaikin
(2013-05-06, 12:47)Audible101 Wrote: [ -> ] (2013-05-06, 07:46)Vaikin Wrote: [ -> ]The in progress submenu is for tv shows that you are watching and haven't finished, not for episodes that you haven't finished.
I agree completely... poor choice of decription
