recently installed and configured xbmc on a raspberry pi, when playing a list of videos I get a pause between two items in the list, with a short return to Linux tty console from which I manually launched xbmc. This pause lasts for a second or two, then the omxplayer begins playing the next item normally.
Is there any way of avoiding this unpleasant effect (force prefetching for example ... ) or at least force xbmc default background to stay for the time the system loads the next content item?
Many thanks
Marco
(2013-05-02, 13:17)mbarcellona Wrote: [ -> ]Hi,
Many thanks
Marco
Whats your OS and build and how do you start the list? I can't see a terminal but sometimes the default background, on both RaspBMC and OpenELEC.
I'm guessing @
mbarcellona is not using a distribution and has just installed a deb file. That's why he's got a problem.
You need to remove the console when launching xbmc. You could try something like:
tvservice -o && tvservice -p && <xbmc launch command> && fbset -depth 8 && fbset -depth 16
which should kill the console which X is running.
Hi guys,
very interesting replies indeed. I actually got xbmc running on a wheezy flavor of Debian using apt-get.
My doubt at this stage is that I'm invoking xbmc from console right after login, without starting X server at all.
I'll play with the commands in popcornmix's post and let you know if the odd effect disappears.
Many thanks
M
I confirm that, by launching xbmc from X environment, the linux console is not visible during the transition from a media content item to the next. By setting the background to some - say - similar color w.r.t. application skin, the transition effect is minimized and perfectly acceptable
Thanks for your suggestions
/M
