ok a so i have been trying various old cvs builds trying to get one to work with the new avbroadcast 0.12 plugin for my theater as described in "dvb - xns - xbox" thread. i had little or no luck. bad playback problems with most builds and crashing in the current cvs due to xns issues.
another feature of avbroadcast plug in is http broadcast. i setup mytheater as described
here but instead of xns i enabled http/rstp broadcast.
i created a file called "dvb stream.strm" and opened in notepad pasted "[url]http://192.168.0.100:8000/dvbcore.mpg"[/url] of course replace the ip address with the ip of your computer. save and upload to the xbox audio folder or your audio share(like you would internet streaming files). open the file and it will buffer for a second then start playing.
i still have to change the channel on my computer but otherwise the streaming works great and video looks perfect.
i am working on a python script to change the channels through the http interface avbroadcast uses.
hope this might help out other dvb users who like to keep up to date on the cvs since xns is currently broken.
has anyone tried the new avbroadcast 0.11 ?
or know how to get the channel changing working ?
i've got the xns streaming working just need the
channel chaning.
th3_h0und
th3_h0und: as i understand it version 0.11 doesn't support channel changes through xns.
what xbmc build have you successfully working avbroadcast through xns?
if you read
my other thread i have a setup working with avbroadcast without using xns so it works in the current cvs builds.
Quote:ver 0.12 may 5, 2004
added channel switch remotely via xns (scribitus)
thats from the 0.12 readme. you can download it at
http://www.dvbsoft.net
http://www.your-offers.net/ only has version 0.11
avbroadcast 0.11 and xbmc 2004-03-09
is my setup and i am using xns.
so what do i need to do to get channel changing ?
th3_h0und
umm version 0.12 of avbroadcast
in my previous post there is a url for a website that has the version 0.12. go download it. it will show your favorates as you have them setup in mythreater and you can change between them easily.
thanks for the info on the build you are using i'll give xns a try again.
have you tried channel changing via xns ? is there anything that needs to be setup within xbmc ?
th3_h0und
i've installed avbroadcaster 0.12. now when i start mytheatre i have avb set to always broadcast. i turn my xbox on and goto xbmc then proceed to my xns share i see some items there ie music (1) tv favs (6) radio (4) etc. so if i go into any of those folders it takes anywhere from 5 - 15 minutes before xbmc does anything then there are some .mpg files with a filesize of 0.1mb. now previous versions of avb that is normal just select it and press (a) and start watching tv. this is not the case it does nothing no matter how long i wait. note during the time it takes to retrieve these files which are only about 6 of them. mytheatre reports that there is a remote channel change, to me that seems fine. my question is this. the items that i first see are not what i have in my favorites. do i need to setup some type of channel list in order for this to work ?
th3_h0und
it's more cool than xns
we hope for change channels
thanks, sorry for the english.
(bluecop @ may 12 2004,08:23 Wrote:ok a so i have been trying various old cvs builds trying to get one to work with the new avbroadcast 0.12 plugin for my theater as described in "dvb - xns - xbox" thread. i had little or no luck. bad playback problems with most builds and crashing in the current cvs due to xns issues.
another feature of avbroadcast plug in is http broadcast. i setup mytheater as described here but instead of xns i enabled http/rstp broadcast.
any new news?
yeah, has anybody been able to change channels?
:kickass: bluecop - the http works great - even over a 11g wireless network. thanks!!
of note - i had to disable the network adapter associated with the dvb card.
anyone figure out changing channels yet?
(ze3ez @ june 18 2004,05:37 Wrote:anyone figure out changing channels yet?
yes, there is a python script you can use to change channels. it is on the python script
upload/download page
help!
avbroadcaster stream does not work for me
this what i have: xbmc april09/04,
mytheatre 3.08
avb 0.11
the "dvb stream.strm" created on local xbox drive.
i can start mt, select avb and select port:1400, thought can not change multicast address.
if "dvb stream" selected from xbmc menu there are some quick messages displayed and than nothing.
i can say that i can stream using tsreader from same pc.
or use smb to play some video clips.
what am i missing with avb?
thanks
ok,
reading on 10 different forums figured out that avb 1.2 works best with http but to support http one must use latest xbmc
streaming works now!:lol:
next chalange is python: it runs on xbox but displays empty screen. i changed list_url= "
http://192.168.0.250:8000/xmltv/listing.xml to
my configuration.
is this only one thing to do in the script?
yes, i can see epg and fav on pc running mytheatre.
any ideas?
