2013-06-03, 01:53
2013-06-03, 09:50
This seems to be a bit out of date its from 2013-05-25 ... but i can see you have "exposed" installed (might be default from the jailbreak). Deinstall exposed as it sucks cpu memory and cpu.
2013-06-03, 10:44
That's the latest crash log I have..
To clarify the problem I'm having, when XBMC crashes soon after it starts, I'm sent back to the apple tv interface. The ATV does not crash!
Thus I was not expecting to find a matching crash log...
thanks for the tip on "exposed". Will remove it.
Is there something else I can try or get you to find out more about this issue?
2013-06-06, 02:20
I'm still crashing also, sorry for the false joy. Same as before, I only log in the main account and wait.
XBMC Log
http://xbmclogs.com/show.php?id=25101
Crash Log
http://xbmclogs.com/show.php?id=25102
Also, same last log
Davilla, Memphiz, this seems to be related to this post.
http://forum.xbmc.org/showthread.php?tid=133620
Thanks,
JS
XBMC Log
Crash Log
Also, same last log
20:07:38 T:174489600 NOTICE: Samba is idle. Closing the remaining connections
Thanks,
JS
2013-06-06, 14:10
So can you confirm that your problem is fixed when running that special test build here:
http://mirrors.xbmc.org/test-builds/darw...o-atv2.deb
But is still there when running latest nightly?
2013-06-06, 14:20
Any idea if my and curlyjs problems are related or even the same..?
I could give it a go to that build and see what happens..
2013-06-06, 14:37
Hi Memphiz,
I can confirm that this load is ok. I left my atv open all nigth wtih no issue.
JS
JS
2013-06-07, 15:32
This load? Wat?
2013-06-07, 17:25
(2013-06-06, 14:10)Memphiz Wrote: [ -> ]So can you confirm that your problem is fixed when running that special test build here:
I can confirm that the load you linked in the previous post work for me and doesn't crash.
However, the latest nightly crashes.
JS
2013-06-19, 16:29
Hi Memphiz,
Any updates on this issue? Please let me know when I should test a new nightly build.
Thanks,
JS
Thanks,
JS
2013-06-19, 17:35
Btw, I had tried the build that worked for curlyjs and it didnt fix my problem.
I think I will try the following:
- update to a recent build
- backup and remove the current mysql db
- let xbmc create a new empty db.
- if that fixes, then the problem has to be with something weird in the upgraded db...
2013-06-20, 13:24
(2013-06-19, 16:29)curlyjs Wrote: [ -> ]Hi Memphiz,
Thanks,
JS
I need a new crashreporter file from you with latest nightly.
2013-06-22, 20:39
Hi Memphiz,
here's the new logs.
XBMC
http://xbmclogs.com/show.php?id=30746
Crash reporter
http://xbmclogs.com/show.php?id=30747
Thanks,
JS
XBMC
Crash reporter
Thanks,
JS
2013-07-18, 17:21
Sorry to bump this, but any update on the issue?
Thanks,
JS
Thanks,
JS
2013-09-20, 11:57
I am also seeing this very issue after upgrading to XBMC 12.2. Gotham nightlies do not have the same problem.
Using NFS, with MySQL backend on ATV2 with IOS4
