I just bought the Blu Ray feature ST:TNG The Best of Both Worlds. Although it shows up in the moviedb.org, it won't show up in my movies list. If I look in files, it is listed but says no info found. What do I have to do to add some fanart and make it show up as a movie?
Do you have a colon in the filename? If so change it to another character.
Nope, the exact name I have is: Star Trek The Next Generation The Best Of Both Worlds (1990)
I copied this from themoviedb.org so I thought it would scrape but it didn't. I am however using Universal Scraper, could that be the problem? I can watch the movie from file mode but I'd like to have it in the movie list.
Try a debug log while scraping.
patseguin: did you end up getting this sorted out? I was planning on just putting the whole Best of Both Worlds as S03E26, and then when season 4 comes out, leave off S04E01 in my ST:TNG TV Show folder. Not putting it as a movie at all.
Actually, no. It won't scrape as a movie so I put then in a stacking folder and just got to it from the files menu.
