Full Version: Ace Skin, Custom Menu options
I have been customizing the menu using the skin settings --> customize main menu
One item I have added is a custom playlist...however i need it to prompt when i select that playlist as I have added a PIN to the folder to stop the kids accessing that playlist, but can't work out how to add a prompt to the menu item
Had a search through some of the xml files to see if I can find the command and update it but no luck
Any one point me in the right direction?
I am guessing it has something to do with skin.ace.subvpl1.path in guisettings.xml...
