Full Version: Full Features RSS News Reader Addon
Pages: 1 2
Finally, a full features RSS News Reader that Display Feed, Image and adjustable font size !
~This is not the RSS ticker at the bottom of XBMC home screen, this is Full Text RSS Reader !!
More screenshot at the bottom of this post !!
Disclosure 1: All credit go to the original creator
Disclosure 2: I am not the creators of this wonderful add-on and I have zero experience about python script, but I some how manage to edit the add-on the way I want it , so if I can do it , anyone can 
Name of the Add-on: script.rssclient-standalone-1.0.6.zip
Where to Download:
http://passion-xbmc.org/addons/Download....-1.0.6.zip
or
https://github.com/downloads/pieh/pieh-x...y.pieh.zip
or
http://www1.datafilehost.com/d/d3299e89
or
http://www.yourfilelink.com/get.php?fid=837198
or
http://www.filedropper.com/scriptrssclie...dalone-106
or
http://sharesend.com/zo0jw4dh
Installation
Go to System > Settings > Add-ons. > 'Install from zip file' option
Add_on on Setting (2 files)
To add / change RSS Feed: (RssFeeds.xml)
To change Feed Font Size , scroll speed and other setting: (script-rssclient-standalone-main.xml)
What is the Line Number Mentioned below?
Note: All the number in front of the code are added for Easy reference and discussion ONLY:
“script-rssclient-standalone-main.xml”
https://github.com/pieh/pieh-xbmc-addons...e-main.xml
How to Edit the RSS Feeds
Edit file :RssFeeds.xml
Location for WinXP: C:\Documents and Settings\Administrator\Application Data\XBMC\userdata\
Replace "Administrator" with your windows username
Location for Win7: please help
References : http://wiki.xbmc.org/index.php?title=Use...sFeeds.xml
How to Edit the RSS Font size ?
Edit file Confusedcript-rssclient-standalone-main.xml
Location for WinXP: C:\Documents and Settings\Administrator\Application Data\XBMC\addons\script.rssclient-standalone\resources\skins\skin.confluence\720p\
References :https://github.com/pieh/pieh-xbmc-addons...e-main.xml
Which Line to edit:line 82 , <font>font10</font> to <font>font30</font>
How to Edit the Auto scroll speed ?
References : https://github.com/pieh/pieh-xbmc-addons...e-main.xml
Which Line to edit:line 80 , <autoscroll time="3000" delay="4000" repeat="5000">True</autoscroll>
where 3000, 4000, 5000 is the seconds
How to Edit the RSS attached Image Size ?
Which Line to edit:line 148,149
Navigation key
For Keyboard :up down down left right, "Esc" to Exit ,
Keep press down until you are on the left panel to choose different feed (e.g. CNN, Yahoo News etc...)
Use Left or right to cycle news
"Show List Item" to List ALL "News Title"
For Remote like (VRC-1100 Remote)
press "clear" to exit
Some RSS Feed for you to try and play around:
http://www.cnn.com/services/rss/
http://www.nbcnews.com/id/5216556/#Topheadlines
http://news.yahoo.com/sitemap/
I have try different RSS Feed , Blog RSS, blogger.com RSS , wordpress.com RSS, etc...
Some , some don't , dont know why , May be someone can slove the problem for me too
Creator of this add-on stop develope this long time ago , so it require the community to support ! Smile THANKS
I try it the other night, it is fantastic , I was always wonder what is the point to the original news ticker at the bottom of the home screen for if I can't click/read the news.
NOW with this Addon, I can actually READ the news, just to let others know , this Addon share the same sources as the original news ticker that come with XBMC, just edit the RssFeeds.xml , so it is convenience.
is this addon working in android boxes?
I only try it on windows only ,...
Doesn't work in XBMCBuntu 12.1:
DEBUG: Addon script.rssclient-standalone requires xbmc.gui version 2.11 which is not available
Hi
can you show me your file RssFeed.xml, because i added a new link rss and dont work
Dependencies not met in Windows XBMC 12.2
skin transparency v5.0
Too bad I like the idea.
Hi all, I tried to install this plug-in in Kodi 15 but does not work, does anyone know if it is compatible or not?
Thanks, Mark.
P.S. Does anyone know a program to manage / read the news rss?
I'm also looking for a rss reader like this....please, is there someone who can modify for kodi 15...would be cool
Anybody
I tested this plugin it works fine in linux and windows
https://www.youtube.com/watch?v=YR4ugy2U...e=youtu.be
(2016-08-07, 13:54)vadim72 Wrote: [ -> ]I tested this plugin it works fine in linux and windows
Which version do you use because I´m using v16.1 and getting errors too.
linux 15.2 and windows v16.1
to put script.rss client-standalone hands
to help you
unzip
throw your hands in the add-on
http://www.fayloobmennik.net/6503731
Setup worked for me. But not all rss feeds are displayed. And the feeds do not refresh. Does somebody have a solution for that?
Pages: 1 2
