Full Version: DVD Playback not working on SMB shares
Hello,
I am running XBMC 12.2 Frodo on an MK809II (Android 4.1 HDMI-Stick). My Videos are stored on a NAS (D-Link DNS320L).
Unfortunately DVD Playback does not work when the DVD Folder (VIDEO_TS) is stored on the NAS or any other SMB share. Same problem with DVD Images (.iso). However, if i copy the DVD Folder or Image to the internal Memory of my MK809II, it works. I took a look at the log files and it seems that libdvdread is having problems with a SMB share.
Her is the log file:
10:34:02 T:1736528504  NOTICE: DVDPlayer: Opening: smb://NAS/Volume_1/Filme/7 Jahre in Tibet/VIDEO_TS/VIDEO_TS.IFO
10:34:02 T:1736528504 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
10:34:02 T:1736528504   DEBUG: CRenderManager::UpdateDisplayLatency - Latency set to 0 msec
10:34:02 T:1736528504   DEBUG: LinuxRendererGL: Cleaning up GL resources
10:34:02 T:1736826168  NOTICE: Creating InputStream
10:34:02 T:1736826168    INFO:   msg: libdvdnav: Using dvdnav version 4.1.3
10:34:02 T:1736826168    INFO:   msg: libdvdread: Using libdvdcss version 1.2.10 for DVD access
10:34:02 T:1736826168    INFO:   msg: libdvdread: Could not open smb://NAS/Volume_1/Filme/7 Jahre in Tibet with libdvdcss.
10:34:02 T:1736826168    INFO:   msg: libdvdread: Can't open smb://NAS/Volume_1/Filme/7 Jahre in Tibet for reading
10:34:02 T:1736826168   DEBUG: libdvdnav: vm: failed to open/read the DVD
10:34:02 T:1736826168   ERROR: Error on dvdnav_open
10:34:02 T:1736826168   ERROR: CDVDPlayer::OpenInputStream - error opening [smb://NAS/Volume_1/Filme/7 Jahre in Tibet/VIDEO_TS/VIDEO_TS.IFO]
10:34:02 T:1736826168  NOTICE: CDVDPlayer::OnExit()
10:34:02 T:1736826168  NOTICE: CDVDPlayer::OnExit() deleting input stream
10:34:02 T:1736528504   DEBUG: CAnnouncementManager - Announcement: OnStop from xbmc
10:34:02 T:1736528504   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnStop
10:34:02 T:1736528504   ERROR: Playlist Player: skipping unplayable item: 0, path [smb://NAS/Volume_1/Filme/7 Jahre in Tibet/VIDEO_TS/VIDEO_TS.IFO]
10:34:02 T:1736528504   DEBUG: Playlist Player: one or more items failed to play... aborting playback
Any ideas how to fix or work around that problem?
Kind Regards
Schoko
(2013-05-07, 10:50)Schokohoernle Wrote: [ -> ]Hello,
Kind Regards
Schoko
Same problem here with the same device but I am not able to play HD or high size videos over smb, while I can play small videos.
I think this is a know problem due to hardware acceleration. I wonder if there are news on near future releases...
Edit: I saw there are test builds that support hardware acceleration, you can try.
http://forum.xbmc.org/showthread.php?tid=152005
http://mirrors.xbmc.org/test-builds/android/
Nothing, tried the test-build Alpha2 but no success on playing HD content. I cannot neither start watching the movie, it stops on loading and I have to close XBMC and start it again.
I am on MK809II with android 4.1.1.
