Hi guys,
I hope you don't mind if I will ask you for some small help here. I asked already in other topic but didn't get any answer.
I bought the HP MCE remote controller + IR receiver (HP OVU400102/71). I have model no.3 from picture
Since few days I'm trying to get it work, but without any positive results.
My system (windows 7 Ultimate x64) recognize it in Device Manager as:
(In HID): Microsoft eHome Infrared Transceiver
(In Universal Serial Bus Controllers): eHome Infrared Receiver (USBCIR)
In controller are two new batteries installed and I can see red led light on it when I press any of the buttons.
I see on back side of the cover a small instruction with pressing "i" and "#" but not sure if I have to press and hold them for 5 second simultaneously or one by one. I assume I should press them simultaneously but after 5sec I receive 4 led blinks so I must repeat this step. I did it many times already.
Is it some kind of activation for this controller?
And apart of this, does this IR receiver have some led light that should blink (like on controller when I press any button)?
I have tried few different approaches to get it work, including uninstalling drives so system can recognize it again.
I tried to run autohotkey with GBS script, also installed later Xbmccustomregis v2.80.01.
I ran Showkey but it shows me nothing when I press any of the keys on controller.
I checked if I have in registry "745a17a0-74d3-11d0-b6fe-00a0c90f57da" entry like it was mentioned (I guess also in this topic) and yes, I do have it with "RC6 based MCE remote" RemoteName.
EnableDebounce: 1
I have found somewhere (on this or other forum) that it maybe a good idea to turn off "EnableDebounce" for other Remotes like:
745a17a0-74d3-11d0-b6fe-00a0c90f57db
745a17a0-74d3-11d0-b6fe-00a0c90f57dc
...and for more two of them. Still no luck.
Maybe I missed something, maybe not. I have no idea why it doesn't work.
That's why I would like to ask you for your help/ideas what else I can do.
Regards,
Markos
