whats the command to play a TV show episode from the database?
I have the episode id, how do i get XBMC to play it?
Player.Open....something?
Anyone have any clues?
PlayMedia(media[,isdir][,1],[playoffset=xx])
(2013-05-07, 15:30)mace08 Wrote: [ -> ]whats the command to play a TV show episode from the database?
So if i have idEpisode '20' from the MyVideos75.db, how do i play it from there?
where are you planning to play it from?
If you want to assign a key to it, then put the following command in the keymap.xml
<a>PlayMedia(C:\Videos\MyVideos75.db)</a>
(2013-05-07, 18:16)mace08 Wrote: [ -> ]So if i have idEpisode '20' from the MyVideos75.db, how do i play it from there?
What i'm trying to do is this:
Have open a view in XBMC library of a tv show, season, episode list.
eg: Eureka - Season 2 - showing episodes 1 - 13.
From there i'd like to have a script that i can enter a episode number, eg: ' 7 ', from any location on my network and it will play Eureka - Season 2 - 7 Family Reunion.
Not using a keybind, but a JSONRPC command of some kind. Oh, without having to highlight the episode first.
Is this possible?
I think this is what you are looking
for
(2013-05-14, 14:40)mace08 Wrote: [ -> ]What i'm trying to do is this:
Is this possible?
Worked it out at last....
For anyone else looking, this is how you play and episode from the database
{ "jsonrpc": "2.0", "method": "Player.Open", "params": { "item": { "episodeid": 200 }, "options":{ "resume": false } }, "id": 1 }
You can change the 200 to any number that's in the database
