In addition to my issue with the music cover art I'm facing a similar issue for my movie library since I upgraded from Frodo 12.1 to 12.2.
Tried two scrapers (The Movie DB & Universal Scraper), both fail downloading artwork.
http://pastebin.com/cKW4YkF4
Manual download of artwork for every single movie and TV series works fine.
Sorry to say that, but my personal impression is that XBMC gets worse with every new release since Dharma...
That's a lot of errors.
Since you're posting about your banner/fanart not appearing, I'll focus on just those errors - it looks like either your Database\Textures13.db is corrupt, or your Thumbnails folder is not accessible.
I would suggest deleting your Textures13.db file and Thumbnails folder, then reloading the cache (one by one in the GUI, or
scripted). You can also use the same script to query your texture cache (before you delete it) to possibly determine why it is throwing up these errors.
Thanks, that did it. In similar cases I only deleted the Thumbnails folder and the MyVideos**.db, did not pay any attention to the Textures13.db (afair it did not exist before Frodo).
Has existed since Dharma (when it was called Textures.db), not sure about before though.
Okay. Unfortunately that did not solve my music cover art problem...
Not entirely sure about that, my albums are organised one album per folder and work fine with Universal Music Scraper. I'd suggest a separate thread for that as it bears no relation to the title of this thread, but using the script I mentioned you can view how the media library has scraped your albums (eg. "jd music <album name>") and, I'm just guessing, but it's likely that only the first album in each folder has been assigned any cover art.
Great, best to continue any discussion of that issue there.
