2015-09-14, 15:06
(2015-09-14, 06:25)icepacc Wrote: [ -> ]So i have my GBox Midnight MX2 close to one year now an never had any issues but about 5 days ago when I switched one my box It showed the Matricom screen, then it stuck there. I let it sit for 30 minutes and it wouldn't move past it. I unplugged it and let it sit for a few minutes then tried it again but it continues to get stuck at MATRICOM screen. I have rebooted it about a dozen times but it won't get past that screen.
Operating system Android 4.2.2
Firmware 1.2
isengard 15.2 rc1
I did the "toothpick reset" procedure
1. Place the Recovery.img, AML script, and 1.2.zip files and put them on an SD card via a computer.
2. Place the SD card into your MX2
But it doesn't go into recovery mode it just loads the MATRICOM and sticks/freezes there
Does anyone know what happened and how I can fix it?
Help me plz
You should post your problem with them in their forums and not bring up a 9 month old thread. I dont see how Kodi has anything to do with your device not turning on
