Full Version: Windows Shortcuts with Harmony Remote
Hi All,
I have a Harmony 650 remote. When I begin the "Watch XBMC" activity, I would like all other programs to minimize and XBMC to start. Windows has a show desktop keyboard shortcut (Win+D), and I've set up a keyboard shortcut to launch XBMC (F6). I easy solution would be to program a sequence for the remote where Win+D is first followed by F6. For the life of me, I can't figure out how to program the Harmony 650 to execute the Win+D command. Does anyone know of a solution?
Thank You All!
an IR remote cannot send windows commands, not technically possible. You need a Windows app to convert IR to a command.
check out EventGhost.org
Add the "Windows Media Center SE" device then add to Activity for the Win key combinations.
See http://forum.xbmc.org/showthread.php?tid...#pid942798
