2013-05-09, 05:53
2013-05-22, 08:41
Same here. I have toshiba xoom tablet, android 4.1.2, installed xbmc for android but when i tried to open the xbmc app gets a message "this xbmc package is not compatible with your device"
Help.
Help.
2013-05-22, 14:57
Because XBMC is not compatible with the Xoom, like the error message says. Xoom uses a non-neon ARM processor, and XBMC needs a neon processor.
2013-05-23, 23:22
Ok...Thanks.
2013-05-25, 15:36
(2013-05-22, 14:57)Ned Scott Wrote: [ -> ]Because XBMC is not compatible with the Xoom, like the error message says. Xoom uses a non-neon ARM processor, and XBMC needs a neon processor.It work on my xoom 4.2.2 . xmbc 12.0 RC2... I have a non neon copy
2013-05-25, 20:55
Yes, if you use an unofficial build that is compiled for non-neon processors, that will work. However, since it's not officially supported, as things are further developed, it's going to be harder for those who make non-neon builds to keep XBMC working. I also hear the experience isn't very good on a non-neon build (very sluggish and lots of crashes).
2013-10-12, 11:49
I have xbmc running on my xoom, it does crash regularly on searching for a stream, that said once you have a stream up and running it's fine, more importantly I can connect the micro HDMI port and watch sports on the big tv screen.
