Full Version: Can't Start XBMC 12.0 Frodo
I just installed XBMC via terminal:
sudo add-apt-repository ppa:team-xbmc/ppa
sudo apt-get update
sudo apt-get install xbmc
I am using Ubuntu 12.04 and Gnome Shell 3.4.
Every time I launch the application, I see the XBMC main logo for a second and then get sent back to the LOGIN SCREEN (lightdm).
Why can't I get XBMC to run?? Any help is greatly appreciated.
I have also included the crash log below:
############## XBMC CRASH LOG ###############
################ SYSTEM INFO ################
Date: Thu May 9 02:13:59 PDT 2013
XBMC Options:
Arch: x86_64
Kernel: Linux 3.2.0-41-generic #66-Ubuntu SMP Thu Apr 25 03:27:11 UTC 2013
Release:
Distributor ID: Ubuntu
Description: Ubuntu 12.04.2 LTS
Release: 12.04
Codename: precise
############## END SYSTEM INFO ##############
############### STACK TRACE #################
=====> Core file: /home/avila/core (2013-05-09 02:13:59.434970725 -0700)
[New LWP 1774]
[New LWP 1788]
[New LWP 1790]
[New LWP 1791]
[New LWP 1789]
[Thread debugging using libthread_db enabled]
Using host libthread_db library "/lib/x86_64-linux-gnu/libthread_db.so.1".
Core was generated by `/usr/lib/xbmc/xbmc.bin'.
Program terminated with signal 11, Segmentation fault.
#0 0x00007f9202e566bc in XUngrabPointer () from /usr/lib/x86_64-linux-gnu/libX11.so.6
Thread 5 (Thread 0x7f91f96d5700 (LWP 1789)):
#0 0x00007f9202210313 in poll () from /lib/x86_64-linux-gnu/libc.so.6
#1 0x00007f9203a94c31 in ?? () from /usr/lib/x86_64-linux-gnu/libasound.so.2
#2 0x0000000000b49a9a in CAESinkALSA::AddPackets(unsigned char*, unsigned int, bool) ()
#3 0x0000000000b3e87d in CSoftAE::RunOutputStage(bool) ()
#4 0x0000000000b43ad7 in CSoftAE::Run() ()
#5 0x0000000001142b71 in CThread::Action() ()
#6 0x0000000001142e21 in CThread:ConfusedtaticThread(void*) ()
#7 0x00007f9206268e9a in start_thread () from /lib/x86_64-linux-gnu/libpthread.so.0
#8 0x00007f920221bccd in clone () from /lib/x86_64-linux-gnu/libc.so.6
#9 0x0000000000000000 in ?? ()
Thread 4 (Thread 0x7f91f7e15700 (LWP 1791)):
#1 0x0000000000e49e0a in PERIPHERALS::CPeripheralBusUSB::WaitForUpdate() ()
#2 0x0000000000e49ed0 in PERIPHERALS::CPeripheralBusUSB:Tonguerocess() ()
#3 0x0000000001142b71 in CThread::Action() ()
#4 0x0000000001142e21 in CThread:ConfusedtaticThread(void*) ()
#5 0x00007f9206268e9a in start_thread () from /lib/x86_64-linux-gnu/libpthread.so.0
#6 0x00007f920221bccd in clone () from /lib/x86_64-linux-gnu/libc.so.6
#7 0x0000000000000000 in ?? ()
Thread 3 (Thread 0x7f91f8616700 (LWP 1790)):
#0 0x00007f920626d0fe in pthread_cond_timedwait@@GLIBC_2.3.2 () from /lib/x86_64-linux-gnu/libpthread.so.0
#1 0x0000000000e4775b in PERIPHERALS::CPeripheralBus:Tonguerocess() ()
#2 0x0000000001142b71 in CThread::Action() ()
#3 0x0000000001142e21 in CThread:ConfusedtaticThread(void*) ()
#4 0x00007f9206268e9a in start_thread () from /lib/x86_64-linux-gnu/libpthread.so.0
#5 0x00007f920221bccd in clone () from /lib/x86_64-linux-gnu/libc.so.6
#6 0x0000000000000000 in ?? ()
Thread 2 (Thread 0x7f91f5db7700 (LWP 1788)):
#1 0x00007f91fe82635f in ?? () from /usr/lib/x86_64-linux-gnu/libpulse.so.0
#2 0x00007f91fe81776c in pa_mainloop_poll () from /usr/lib/x86_64-linux-gnu/libpulse.so.0
#3 0x00007f91fe817dd9 in pa_mainloop_iterate () from /usr/lib/x86_64-linux-gnu/libpulse.so.0
#4 0x00007f91fe817e90 in pa_mainloop_run () from /usr/lib/x86_64-linux-gnu/libpulse.so.0
#5 0x00007f91fe82630f in ?? () from /usr/lib/x86_64-linux-gnu/libpulse.so.0
#6 0x00007f91fd3e2d18 in ?? () from /usr/lib/x86_64-linux-gnu/libpulsecommon-1.1.so
Thread 1 (Thread 0x7f920949e780 (LWP 1774)):
#1 0x00007f92035af26b in ?? () from /usr/lib/x86_64-linux-gnu/libSDL-1.2.so.0
#2 0x00007f92035af2d2 in ?? () from /usr/lib/x86_64-linux-gnu/libSDL-1.2.so.0
#3 0x00007f920359cd11 in ?? () from /usr/lib/x86_64-linux-gnu/libSDL-1.2.so.0
#4 0x00007f920359e758 in SDL_VideoQuit () from /usr/lib/x86_64-linux-gnu/libSDL-1.2.so.0
#5 0x00007f9203575215 in SDL_QuitSubSystem () from /usr/lib/x86_64-linux-gnu/libSDL-1.2.so.0
#6 0x00007f92035752ce in SDL_Quit () from /usr/lib/x86_64-linux-gnu/libSDL-1.2.so.0
#7 0x00007f92035758cf in ?? () from /usr/lib/x86_64-linux-gnu/libSDL-1.2.so.0
#8 <signal handler called>
#9 0x00007f9202e566bc in XUngrabPointer () from /usr/lib/x86_64-linux-gnu/libX11.so.6
#10 0x00007f92035af26b in ?? () from /usr/lib/x86_64-linux-gnu/libSDL-1.2.so.0
#11 0x00007f92035af2d2 in ?? () from /usr/lib/x86_64-linux-gnu/libSDL-1.2.so.0
#12 0x00007f920359cd11 in ?? () from /usr/lib/x86_64-linux-gnu/libSDL-1.2.so.0
#13 0x00007f920359e758 in SDL_VideoQuit () from /usr/lib/x86_64-linux-gnu/libSDL-1.2.so.0
#14 0x00007f9203575215 in SDL_QuitSubSystem () from /usr/lib/x86_64-linux-gnu/libSDL-1.2.so.0
#15 0x00007f92035752ce in SDL_Quit () from /usr/lib/x86_64-linux-gnu/libSDL-1.2.so.0
#16 0x00007f9202163901 in ?? () from /lib/x86_64-linux-gnu/libc.so.6
#17 0x00007f9202163985 in exit () from /lib/x86_64-linux-gnu/libc.so.6
#18 0x00007f9202e5b1d4 in _XDefaultIOError () from /usr/lib/x86_64-linux-gnu/libX11.so.6
#19 0x00007f9202e5b41e in _XIOError () from /usr/lib/x86_64-linux-gnu/libX11.so.6
#20 0x00007f9202e5938b in _XReply () from /usr/lib/x86_64-linux-gnu/libX11.so.6
#21 0x00007f92056a0b82 in ?? () from /usr/lib/x86_64-linux-gnu/mesa/libGL.so.1
#22 0x00007f920569f9bb in ?? () from /usr/lib/x86_64-linux-gnu/mesa/libGL.so.1
#23 0x0000000001119267 in CWinSystemX11GL:TongueresentRenderImpl(std::vector<CDirtyRegion, std::allocator<CDirtyRegion> > const&) ()
#24 0x0000000001073f47 in CRenderSystemGL:TongueresentRender(std::vector<CDirtyRegion, std::allocator<CDirtyRegion> > const&) ()
#25 0x0000000000f4894d in CApplication::Render() ()
#26 0x0000000000a0544f in CGUIWindowManager:TonguerocessRenderLoop(bool) ()
#27 0x0000000000a06415 in CGUIWindowManager::CloseWindowSync(CGUIWindow*, int) ()
#28 0x0000000000a08b7a in CGUIWindowManager::ActivateWindow_Internal(int, std::vector<CStdStr<char>, std::allocator<CStdStr<char> > > const&, bool) ()
#29 0x0000000000a08ef0 in CGUIWindowManager::ActivateWindow(int, std::vector<CStdStr<char>, std::allocator<CStdStr<char> > > const&, bool) ()
#30 0x0000000000d2c4fa in CBuiltins::Execute(CStdStr<char> const&) ()
#31 0x0000000000f5787c in CApplication::ExecuteXBMCAction(std:Confusedtring) ()
#32 0x0000000000f57f7e in CApplication::OnMessage(CGUIMessage&) ()
#33 0x0000000000a058e2 in CGUIWindowManager::SendMessage(CGUIMessage&) ()
#34 0x0000000000a05ddd in CGUIWindowManager:Big GrinispatchThreadMessages() ()
#35 0x0000000000f54123 in CApplication:Tonguerocess() ()
#36 0x0000000000fe5014 in CXBApplicationEx::Run() ()
#37 0x0000000000fece58 in XBMC_Run ()
#38 0x00000000006ecec5 in main ()
############# END STACK TRACE ###############
################# LOG FILE ##################
02:13:54 T:140265197791104 NOTICE: -----------------------------------------------------------------------
02:13:54 T:140265197791104 NOTICE: Starting XBMC (12.2 Git:32b1a5e), Platform: Linux (Ubuntu 12.04.2 LTS, 3.2.0-41-generic x86_64). Built on May 2 2013
02:13:54 T:140265197791104 NOTICE: special://xbmc/ is mapped to: /usr/share/xbmc
02:13:54 T:140265197791104 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/xbmc
02:13:54 T:140265197791104 NOTICE: special://masterprofile/ is mapped to: /home/avila/.xbmc/userdata
02:13:54 T:140265197791104 NOTICE: special://home/ is mapped to: /home/avila/.xbmc
02:13:54 T:140265197791104 NOTICE: special://temp/ is mapped to: /home/avila/.xbmc/temp
02:13:54 T:140265197791104 NOTICE: The executable running is: /usr/lib/xbmc/xbmc.bin
02:13:54 T:140265197791104 NOTICE: Local hostname: tvpc
02:13:54 T:140265197791104 NOTICE: Log File is located: /home/avila/.xbmc/temp/xbmc.log
02:13:54 T:140265197791104 ERROR: CAESinkOSS::EnumerateDevicesEx - Failed to open mixer: /dev/mixer
02:13:54 T:140265197791104 NOTICE: Found 1 Lists of Devices
02:13:54 T:140265197791104 NOTICE: Enumerated ALSA devices:
02:13:54 T:140265197791104 NOTICE: Device 1
02:13:54 T:140265197791104 NOTICE: m_deviceName : default
02:13:54 T:140265197791104 NOTICE: m_displayName : Playback/recording through the PulseAudio sound server
02:13:54 T:140265197791104 NOTICE: m_displayNameExtra:
02:13:54 T:140265197791104 NOTICE: m_deviceType : AE_DEVTYPE_PCM
02:13:54 T:140265197791104 NOTICE: m_channels : FL,FR,BL,BR,FC,LFE,SL,SR,UNKNOWN1,UNKNOWN2,UNKNOWN3,UNKNOWN4,UNKNOWN5,UNKNOWN6,UNKNOWN7,UNKNOWN8
02:13:54 T:140265197791104 NOTICE: m_sampleRates : 5512,8000,11025,16000,22050,32000,44100,48000,64000,88200,96000,176400,192000
02:13:54 T:140265197791104 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_U8
02:13:54 T:140265197791104 NOTICE: Device 2
02:13:54 T:140265197791104 NOTICE: m_deviceName : @:CARD=Intel,DEV=0
02:13:54 T:140265197791104 NOTICE: m_displayName : HDA Intel
02:13:54 T:140265197791104 NOTICE: m_displayNameExtra: ALC889A Analog
02:13:54 T:140265197791104 NOTICE: m_sampleRates : 44100,48000,96000,192000
02:13:54 T:140265197791104 NOTICE: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
02:13:54 T:140265197791104 NOTICE: Device 3
02:13:54 T:140265197791104 NOTICE: m_deviceName : iec958:CARD=Intel,DEV=0
02:13:54 T:140265197791104 NOTICE: m_displayNameExtra: ALC889A Digital S/PDIF
02:13:54 T:140265197791104 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
02:13:54 T:140265197791104 NOTICE: m_sampleRates : 44100,48000,88200,96000,192000
02:13:54 T:140265197791104 NOTICE: load settings...
02:13:54 T:140265197791104 ERROR: Unable to load libcrystalhd.so.3, reason: libcrystalhd.so.3: cannot open shared object file: No such file or directory
02:13:54 T:140265197791104 NOTICE: special://profile/ is mapped to: special://masterprofile/
02:13:54 T:140265197791104 NOTICE: loading special://masterprofile/guisettings.xml
02:13:54 T:140265197791104 NOTICE: Getting hardware information now...
02:13:54 T:140265197791104 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
02:13:54 T:140265197791104 NOTICE: Loaded playercorefactory configuration
02:13:54 T:140265197791104 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
02:13:54 T:140265197791104 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
02:13:54 T:140265197791104 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
02:13:54 T:140265197791104 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
02:13:54 T:140265197791104 NOTICE: Default DVD Player: dvdplayer
02:13:54 T:140265197791104 NOTICE: Default Video Player: dvdplayer
02:13:54 T:140265197791104 NOTICE: Default Audio Player: paplayer
02:13:54 T:140265197791104 NOTICE: Disabled debug logging due to GUI setting. Level 0.
02:13:54 T:140265197791104 NOTICE: Log level changed to 0
02:13:54 T:140265197791104 NOTICE: Loading media sources from special://masterprofile/sources.xml
02:13:54 T:140264931677952 NOTICE: Thread CSoftAE start, auto delete: false
02:13:54 T:140265197791104 NOTICE: Running database version Addons15
02:13:56 T:140264914118400 NOTICE: Thread XBMC Peripherals start, auto delete: false
02:13:56 T:140265197791104 NOTICE: Previous line repeats 1 times.
02:13:56 T:140265197791104 NOTICE: Setup SDL
02:13:56 T:140265197791104 NOTICE: Checking resolution 16
02:13:56 T:140265197791104 NOTICE: Using visual 0x22
02:13:56 T:140265197791104 NOTICE: GL_VENDOR = Tungsten Graphics, Inc
02:13:56 T:140265197791104 NOTICE: GL_RENDERER = Mesa DRI Intel® G41
02:13:56 T:140265197791104 NOTICE: GL_VERSION = 2.1 Mesa 8.0.4
02:13:56 T:140265197791104 NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.20
02:13:56 T:140265197791104 NOTICE: GL_EXTENSIONS = GL_ARB_multisample GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_copy_texture GL_EXT_polygon_offset GL_EXT_subtexture GL_EXT_texture_object GL_EXT_vertex_array GL_EXT_compiled_vertex_array GL_EXT_texture GL_EXT_texture3D GL_IBM_rasterpos_clip GL_ARB_point_parameters GL_EXT_draw_range_elements GL_EXT_packed_pixels GL_EXT_point_parameters GL_EXT_rescale_normal GL_EXT_separate_specular_color GL_EXT_texture_edge_clamp GL_SGIS_generate_mipmap GL_SGIS_texture_border_clamp GL_SGIS_texture_edge_clamp GL_SGIS_texture_lod GL_ARB_framebuffer_sRGB GL_ARB_multitexture GL_EXT_framebuffer_sRGB GL_IBM_multimode_draw_arrays GL_IBM_texture_mirrored_repeat GL_3DFX_texture_compression_FXT1 GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_transpose_matrix GL_EXT_blend_func_separate GL_EXT_fog_coord GL_EXT_multi_draw_arrays GL_EXT_secondary_color GL_EXT_texture_env_add GL_EXT_texture_filter_anisotropic GL_EXT_texture_lod_bias GL_INGR_blend_func_separate GL_NV_blend_square GL_NV_light_max_exponent GL_NV_texgen_reflection GL_NV_texture_env_combine4 GL_SUN_multi_draw_arrays GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_EXT_framebuffer_object GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_MESA_window_pos GL_NV_packed_depth_stencil GL_NV_texture_rectangle GL_NV_vertex_program GL_ARB_depth_texture GL_ARB_occlusion_query GL_ARB_shadow GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_mirrored_repeat GL_ARB_window_pos GL_ATI_envmap_bumpmap GL_EXT_stencil_two_side GL_EXT_texture_cube_map GL_NV_depth_clamp GL_NV_vertex_program1_1 GL_APPLE_packed_pixels GL_APPLE_vertex_array_object GL_ARB_draw_buffers GL_ARB_fragment_program GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_vertex_program GL_ARB_vertex_shader GL_ATI_draw_buffers GL_ATI_texture_env_combine3 GL_ATI_texture_float GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_MESA_pack_invert GL_MESA_ycbcr_texture GL_ARB_depth_clamp GL_ARB_fragment_program_shadow GL_ARB_half_float_pixel GL_ARB_point_sprite GL_ARB_shading_language_100 GL_ARB_sync GL_ARB_texture_non_power_of_two GL_ARB_vertex_buffer_object GL_ATI_blend_equation_separate GL_EXT_blend_equation_separate GL_OES_read_format GL_ARB_color_buffer_float GL_ARB_pixel_buffer_object GL_ARB_texture_compression_rgtc GL_ARB_texture_float GL_ARB_texture_rectangle GL_EXT_packed_float GL_EXT_pixel_buffer_object GL_EXT_texture_compression_rgtc GL_EXT_texture_rectangle GL_EXT_texture_sRGB GL_EXT_texture_shared_exponent GL_ARB_framebuffer_object GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_packed_depth_stencil GL_APPLE_object_purgeable GL_ARB_vertex_array_object GL_ATI_separate_stencil GL_EXT_draw_buffers2 GL_EXT_gpu_program_parameters GL_EXT_texture_array GL_EXT_texture_integer GL_EXT_texture_sRGB_decode GL_OES_EGL_image GL_MESA_texture_array GL_ARB_copy_buffer GL_ARB_depth_buffer_float GL_ARB_half_float_vertex GL_ARB_map_buffer_range GL_ARB_texture_rg GL_ARB_texture_swizzle GL_ARB_vertex_array_bgra GL_EXT_separate_shader_objects GL_EXT_texture_swizzle GL_EXT_vertex_array_bgra GL_NV_conditional_render GL_ARB_ES2_compatibility GL_ARB_draw_elements_base_vertex GL_ARB_explicit_attrib_location GL_ARB_fragment_coord_conventions GL_ARB_provoking_vertex GL_ARB_sampler_objects GL_ARB_seamless_cube_map GL_ARB_shader_texture_lod GL_EXT_provoking_vertex GL_EXT_texture_snorm GL_MESA_texture_signed_rgba GL_ARB_robustness
02:13:56 T:140265197791104 ERROR: GLX: Same window as before, refreshing context
02:13:56 T:140265197791104 NOTICE: Running database version Addons15
02:13:57 T:140265197791104 NOTICE: Running database version ViewModes4
02:13:57 T:140265197791104 NOTICE: Running database version Textures13
02:13:57 T:140265197791104 NOTICE: Running database version MyMusic32
02:13:57 T:140265197791104 NOTICE: Running database version MyVideos75
02:13:57 T:140265197791104 NOTICE: Running database version TV22
02:13:57 T:140265197791104 NOTICE: Running database version Epg7
02:13:57 T:140265197791104 NOTICE: start dvd mediatype detection
02:13:57 T:140265197791104 NOTICE: initializing playlistplayer
02:13:57 T:140265197791104 NOTICE: DONE initializing playlistplayer
02:13:57 T:140265197774592 NOTICE: Thread CDetectDVDMedia start, auto delete: false
02:13:57 T:140265197791104 NOTICE: initialize done
02:13:57 T:140265197791104 NOTICE: Enabled Joystick: Microsoft Microsoft® Nano Transceiver v2.0
02:13:57 T:140265197791104 NOTICE: Details: Total Axis: 37 Total Hats: 0 Total Buttons: 57
02:13:57 T:140265197791104 NOTICE: Running the application...
############### END LOG FILE ################
############ END XBMC CRASH LOG #############
You don't have a proper GL accelerated video driver installed.
Is this part of an upstream decision?
I have an 865G myself, which utilizes the i915 driver (for whatever reason), which seems to be based on Mesa libs.
I'm experiencing an identical issue after forcing DefaultDepth to 24 bits (default is 15bpp, for whatever reason).
For those who cannot afford to upgrade, isn't that an awful lot of people left out in the cold?
EDIT: It looks like Intel does have a driver available outside of the standard repos.
I'll see if I can knock out a tut once I've reached some semblance of a successful installation.
EDIT2:
nickr Wrote:You don't have a proper GL accelerated video driver installed.
Well that sucks. The Intel Linux driver uses Mesa to provide 3D rendering. Does this mean older Intel owners are out of luck? Sad
EDIT3:
Found a thread here that resolved my issue.
Perhaps forcing the GL version is a prerequisite for Springdales?
As promised, I'll have the guide up within the week. Look for it soon. Smile
EDIT4: Here is the guide. If this helps even one other person, I'll be happy. Smile
