Hey there! I just replied about the same topic in a different thread:
https://forum.kodi.tv/showthread.php?tid...pid2696258
I would very much welcome this feature (=better trailer GUI, choice between multiple local trailers and online trailer instead of directly play first local if one exists, otherwise directly play online)
and with a bit of help of some developer who knows Kodi's insides would be willing to help code it.
Very old thread, bit same question about trailer files
I have some trailers named
"movie-trailer.mp4"
KODI find them in the right movie folder and plays them without any problems.
additional i have some trailers named eg.
Name part-01_AC3-trailer.mk4
which KODI does not recognise as a trailer
I alread tried this in my advancedsettings.xml
(like described
here)
<trailermatching>
<regexp>(.*?)(-trailer)(\.[^.]+)$</regexp>
</trailermatching>
As you can test
here, this regexp will match ALL files with a "-trailer" before the extension.
but this seem not to work
I tested with first trailer (movie-trailer.ext) and scan for new content. This works fine...
but when I put the second file (nameBlaBla AC3-xyz-trailer.ext) in the folder, KODI did not see the trailer.
Any help there?
Do I have to put the <trailermatching> into the <videolibrary> or somewhere else?
(already tried both).
Thank you
Kodi is tripping up on the operator "-" you have two in Name part-01_AC3-trailer.mk4
Trailers (wiki)
Hello and thank you for your help.
But I don't think so. I have many different trailer files and they all have different names. Even those without "-" won't play for me
Only if the trailers are located in the correspondending movie folder and called
"movie-trailer.ext", KODI does it play without problems.
If the trailer-file has another name:
no matter what regex I use and no matter what the trailer file is called (with "-" or without), KODI shows that there is no trailer or wants to download the YouTube addon.
I also tried the regex without the "-", so every file with word trailer bevor the .ext should match
<trailermatching>
<regexp>(.*?)(trailer)(\.[^.]+)$</regexp>
</trailermatching>
even
<trailermatching>
<regexp>/trailer/</regexp>
</trailermatching>
or
<trailermatching>
<regexp>trailer</regexp>
</trailermatching>
do not work.
I think
IT HAS TO WORK, when i name my trailerfile
"moviename_Trailer.ext" and use the
example from the Wiki
<trailermatching>
<!-- This regexp will match moviename_Trailer.avi -->
<regexp>(.*?)(_Trailer)(\.[^.]+)$</regexp>
</trailermatching>
But even that doesn't work.
To be honest, I'm a bit desperate and don't know how I can get KODI to recognize (and play) all video files with
...-trailer.ext as a local trailer file in the movies folder.
It seems like the <trailermatching> tag is just completely useless...
Can someone maybe test this and confirm that it works (or not)?
Your <trailermatching> tag must be inside a top level <advancedsettings> tag. Something like
<advancedsettings>
<trailermatching>
</trailermatching>
</advancedsettings>
is read successfully by Kodi.
Hello and thank you very much for the tip.
(in this case "unfortunately") i've already done it that way.
I have my
<trailermatching> tags at the very end of the advancedsettings.xml right before the end </advancedsettings>
here is my complete advancedsettings.xml
<advancedsettings>
<videodatabase>
<type>mysql</type>
<host>192.168.1.6</host>
<port>3307</port>
<user>XX-USER-XX</user>
<pass>XX-PW-XX</pass>
</videodatabase>
<musicdatabase>
<type>mysql</type>
<port>3307</port>
</musicdatabase>
<pathsubstitution>
<substitute>
<from>special://masterprofile/Thumbnails</from>
<to>smb://USER: [email protected]/PATH/TO/MY/THUMBNAILS/</to>
</substitute>
<substitute>
<from>special://masterprofile/sources.xml</from>
<to>smb://USER: [email protected]/PATH/TO/MY/sources.xml</to>
</substitute>
<substitute>
<from>special://masterprofile/favourites.xml</from>
<to>smb://USER: [email protected]/PATH/TO/MY/favourites.xml</to>
</substitute>
</pathsubstitution>
<seeksteps>5, 20, 60, 180, 300, 600, 1200, 1800</seeksteps>
<videolibrary>
<usefasthash>false</usefasthash>
<!-- defaults to true. Set to false in order to skip hashing based on the folders modification time. -->
<importwatchedstate>true</importwatchedstate>
<!-- import previously exported playdate and playcount from .nfo files. Defaults to false -->
<dateadded>1</dateadded>
<!-- 0 results in using the current datetime when adding a video;
1 (default) results in prefering to use the files mtime (if it's valid) and only using the file's ctime if the mtime isn't valid;
2 results in using the newer datetime of the file's mtime and ctime -->
</videolibrary>
<trailermatching>
</trailermatching>
</advancedsettings>
wait...
do i have to name the trailer-file exact like the movie-file?
For example my movie-FOLDER looks like "
Batman v Superman Dawn of Justice (2016)"
My movie-FILE do include some more details like "
Batman v Superman Dawn of Justice (2016) x265 AC3 [DE+EN] Bluray-1080p.mkv"
BUT my trailer looks like the folder "
Batman v Superman Dawn of Justice (2016)-trailer.ext"
No matter what i try: KODI only recognice a trailer, when it is named
"movie-trailer.ext" or (the full original movie-filename)
"Batman v Superman Dawn of Justice (2016) x265 AC3 [DE+EN] Bluray-1080p-trailer.ext"
I thought with the <regex> Tags i can tell KODI to recognice every file matching the regex (inside the movie folder) as the correspondending a trailer.
So it should recognice
"Batman v Superman Dawn of Justice (2016)-trailer.ext" as a trailer.
Is this train of thought wrong on my part?
The extension is truncated before the regexp execution on the file name.
<regexp>(.*?)(-trailer)$</regexp>
works.
It's very old code, looks like the wiki has always been misleading.
omg...
I've really tried to learn and/or understand regex expressions on various sites. I really didn't think that my "error" was due to an incorrect regex expression
I've only tested it briefly once, but this first short test was successful
and KODI recognized a trailer file that had a completely different name!! As long as it had “-trailer” at the end ;-)
Thank you @ChrystaIP !!!
You couldn't have guessed, especially with a broken example. I fixed the Wiki page.
