Full Version: RemoteExecuter Execute applications from Web
Hello,
I want to show you guys my latest application RemoteExecuter.
This application allows you to execute programs on the computer where the application is installed.
No virus detected!
Things you need:
- Destination Host (Windows only)
- Device which can visit websites
Setup Steps:
- NO SETUP!!
- Execute the RemoteExecuter application as Admin (HTTPListener need admin rights)
- Configure settings Port and one Folder, do you want to show file extensions?
- Finish!
For example you want to open XBMC from any device, create a folder put in a shortcut to xbmc.exe and add the folder in the application settings. Visit the page and click the link! You will notice xbmc will be executed!
You can use it for anything! Every file can be executed just like you double click it with your mouse!
Also you can put your own design to this page if you place a main.css file near the exe file. I’m not a css pro just do a sample for you!
First i thought it is just for me, but maybe someone can also need it.
Download (Skydrive):http://goo.gl/Bs2lb
Screenshoots:
http://goo.gl/jC2dN
New features?
Nothing yet
Can you integrate this into Maraschino?
To be specific... it would be great to have this functionality as a separate module for Maraschino... which is a really nice web based dashboard for HA/HT
(2013-05-10, 18:15)Livin Wrote: [ -> ]Can you integrate this into Maraschino?
I cant do this, my skills in python are not very good. It's currently written in c#.
