Full Version: WMV seek problem
I am running 12.2 “Frodo” and experiencing issues when trying to fast forward in WMV (mms) streams. The video plays fine until I press fast forward a few times. At this point XBMC either interrupts the video, or crashes. Searching the forums, and bugs revealed that there was a similar problem a while ago and it has reportedly been fixed: "Seeking in MMS Streams doesn't work" http://trac.xbmc.org/ticket/12167.
I've reproduced the problem with the same file referenced in the bug: mmsh://straumod.nrk.no/disk11/Supermorgen/2011-03-11/MSUS54000411AA-1Mbit.wmv?UseSilverlight=1
Does anyone else have problems trying to fast forward/skip (seek) WMV files?
Here is the log information:
https://www.dropbox.com/s/klvtdl2f8czzqgn/xbmc.log
https://www.dropbox.com/s/hz38jydtr3rvbl...170524.txt
https://www.dropbox.com/s/z8jpxef1kzo46k...170524.dmp
https://www.dropbox.com/s/23a31fum7udomg...e.6260.dmp
There is now a bug open in ffmpeg: "mmsh seeking crashes ffmpeg" https://ffmpeg.org/trac/ffmpeg/ticket/2581.
+1 on this problem - using brtv plugin
Currently running Eden to avoid this issue - anything after eden exposes this problem.
please register at ffmpegs bugtracker and upvote the bug - the better are the chances that it gets some attention from the devs sooner-ish
and thx to brtv_viewer for reporting it!
