Full Version: Network setting and Default resovlution
a)How can i modify the network to static ip?
When i restart xbmc, i need adjust remoter host setting on Andriod phone.
b)How to make default resovlution to 1920*1080p?
Philips Monitor resovlution is 1280*1024. when i open xbmc, it's the default resovlution.
I need change to 1920*1080p each restart, 1920 is My SONY TV avaiable resovlution.
I hope to setting to default open as 1920*1080.
Thank you.
Are you using XBMCbuntu or are you using xbmc under another linux based system like OpenELEC ?
Xbmcbuntu.
I have experience for Ubuntu and BackTrack5.
So i choose the Xbmcbuntu.
Static networking is exactly the same as regular ubuntu
/etc/network/interfaces
Unplug your monitor and boot with the TV on. You don't need a separate monitor for an HTPC.
Thank you nickr.
I have fix the network problem with modify interfaces configuration .
buy i can't understand about the resolvtion.
it's not only htpc.i have windows for LOL game.
i want to modify default setting to solve this
anybody know where 's default setting config.
I have a lot of trouble understanding your question.
XBMC will remember the resolution you set, is it not doing that ?
mainline xbmc does not support multi monitor setups. It will always use the first display it sees.
Either turn your monitor off before starting xbmc, or use the version from http://forum.xbmc.org/showthread.php?t=116996 , it has proper multi screen support.
The more you learn, thx wsnipex - i'll try to remember that as well Tongue
Thank you wsnipex. I think it's will be usefully .
