Full Version: suggestion for radiobutton states
Is there any chance of having separate focused and unfocused textures on radiobuttons and spincontrols?
Currently:
<textureradiofocus>radiobutton-on.png</textureradiofocus>
<textureradionofocus>radiobutton-off.png</textureradionofocus>
Doesn't really make a whole lot of sense to me as they aren't actually focused and unfocused states, but activated and unactivated states. It causes problems when you want the <texturefocus> the same color as the color of the (unfocused) radiobutton textures.
Suggested:
<radiounselectednofocus>radiobutton-off-nf.png</radiounselectednofocus>
<radiounselectedfocus>radiobutton-off-fo.png</radiounselectedfocus>
<radioselectednofocus>radiobutton-on-nf.png</radioselectednofocus>
<radioselectedfocus>radiobutton-on-fo.png</radioselectedfocus>
Being able to apply a colordiffuse to the radio texture (so separate from the control's <texturefocus> ) would be an alternate possibility perhaps?
Also confusing is the wiki naming for them -
<textureradioon>myradiobutton.png</textureradioon>
<textureradiooff>myradiobutton_nf.png</textureradiooff>
(2013-05-13, 11:37)Jeroen Wrote: [ -> ]Being able to apply a colordiffuse to the radio texture (so separate from the control's <texturefocus> ) would be an alternate possibility perhaps?
Applying separate colordiffuses to textures should be getting added to Gotham in the May merge.
(2013-05-14, 09:15)Sranshaft Wrote: [ -> ]Applying separate colordiffuses to textures should be getting added to Gotham in the May merge.
Ah, good to know! Thanks for the heads up Wink
About naming convention:
This should work. <textureradiofocus>, <textureradionofocus> are there for backward compatibility (here's commit for it https://github.com/xbmc/xbmc/commit/3c3d...662b4d7cc3 )
I'll try to create PR to add seperate on/off textures for focus/unfocus soon. That's not much of work and is definitely reasonable.
There was obviously some oopsie from our side in not merging referenced separate colordiffuses PR in may. It will have to wait few days for june then, sorry Sad
(2013-05-23, 20:00)pieh Wrote: [ -> ]About naming convention:
Just got around checking for this, i see this made it in. Awesome, cheers Pieh!
Although the separate textures are still to come I assume?
Thanks Pieh Smile
