Looks like XBMC again has changed the artwork filenames in v13:
... i really hate this shit !!!!
Regardless, I now have added banners and landscape for movies (commit this weekend).
Fanart.tv API is updated and running fine.
M.Savazzi, you have an idea how we can handle png (ClearArt, DiscArt...)?
Are you sure about that?
I have a Gotham b2 setup running
Did a test and deleted all sources
Add new source pointing to my test location (no artwork or nfos, only movies)
Let it scan from tmdb
Exported the content
Everything is named as with Frodo
(2014-04-05, 03:39)DanCooper Wrote: [ -> ]M.Savazzi, you have an idea how we can handle png (ClearArt, DiscArt...)?
Sorry for being offline for long... trying to get back on this.
Will look into it
(2014-04-05, 03:39)DanCooper Wrote: [ -> ]Looks like XBMC again has changed the artwork filenames in v13:
where did you found the naming convention?
M
(2014-05-01, 23:45)m.savazzi Wrote: [ -> ] (2014-04-05, 03:39)DanCooper Wrote: [ -> ]M.Savazzi, you have an idea how we can handle png (ClearArt, DiscArt...)?
Will look into it
M
XBMC wiki. But i think export settings are the same like in Frodo.
Btw. I'm nearly complete with theme scraper, I think I can do a new release this weekend.
Reading
http://wiki.xbmc.org/index.php?title=Fro...r_Frodo.3F and
http://wiki.xbmc.org/index.php?title=Thu..._directory
All depends how you organize your movies
If every movie is in separate folders both naming is accepted
If you have all movies in one large folder it's mandatory to name it
Do you do a different interpretation?
(2014-05-02, 15:16)T-bird_se Wrote: [ -> ] (2014-04-05, 03:39)DanCooper Wrote: [ -> ]Looks like XBMC again has changed the artwork filenames in v13:
Reading http://wiki.xbmc.org/index.php?title=Fro...r_Frodo.3F and http://wiki.xbmc.org/index.php?title=Thu..._directory
I would argue they have the wiki changed again since my last visit.... or I was too tired
In this case, everything is fine.
I have just merged my MovieSets branch back to master.
It's not all finished, but i think is easier to work on a up-to-date master branch.
Hi team
In my opinion we can remove the IMDB poster scraper. Just as he built atm only one image is loaded and only in the reduced quality. The scraper is very unreliable. It would be a lot of effort to change that to get more than one and only usefull images.
What do you think?
I use it
I'd leave it as we already have it... should not require additional work.
Why you say is low quality? it depends on settings and before the changes is was downloading the full quality.
M
What is the MyVideos2.emm database?
with latest version I have issues with manual scrape on TMDB.
Is just me?
(2014-06-25, 22:36)m.savazzi Wrote: [ -> ]What is the MyVideos2.emm database?
The new unique DB filename that coincide to the database version. I'm working on a merge-DB-to-new-DB solution like in XBMC.
(2014-06-25, 22:58)m.savazzi Wrote: [ -> ]with latest version I have issues with manual scrape on TMDB.
Is just me?
Can you describe the problem in more detail?
(2014-06-26, 14:31)DanCooper Wrote: [ -> ] (2014-06-25, 22:36)m.savazzi Wrote: [ -> ]What is the MyVideos2.emm database?
Ok.
It's weird as the size of the two db is different
(2014-06-26, 14:31)DanCooper Wrote: [ -> ] (2014-06-25, 22:58)m.savazzi Wrote: [ -> ]with latest version I have issues with manual scrape on TMDB.
Is just me?
When I do a scrape (CTRL-I) it hangs while trying to retrieve the data, no image selection dialog is shown
