OS: Crystalubuntu 2
Hardware: AppleTV 1
XBMC: Frodo
I'm a noob, but have not been able to find an answer to the issue I'm having. I have my movie source as my iTunes library. Some of the movies in my library, when played, display a black screen for video but play the audio. The movie is not DRM protected, and all movies play in iTunes, Quicktime, etc, so I know the movie is playable. What I've noticed in the log for these movies is:
Quote:09:00:51 T:2852100928 DEBUG: CAFPFile::Open - opened iTunes/iTunes Music/Movies/Zathura.m4v, fd=0
09:00:51 T:2852100928 DEBUG: Open - probing detected format [mov,mp4,m4a,3gp,3g2,mj2]
09:00:52 T:2852100928 DEBUG: Open - avformat_find_stream_info starting
09:00:52 T:2852100928 DEBUG: Open - av_find_stream_info finished
09:00:52 T:2852100928 DEBUG: CAFPFile::Close closing fd 0
09:00:52 T:2852100928 ERROR: SQL: SQL error or missing database
Query: INSERT INTO streamdetails (idFile, iStreamType, strVideoCodec, fVideoAspect, iVideoWidth, iVideoHeight, iVideoDuration) VALUES (1072,0,'avc1',NaN,0,0,6084)
09:00:52 T:2852100928 ERROR: SetStreamDetailsForFileId (1072) failed
Not sure why the SQL INSERT fails unless the width and height of 0 are not allowed. When I play the movie Zathura with VLC, it is able to determine width and height and play the movie (on my Mac), it reports for stream 0,
Quote:Type Video
Codec H264 - MPEG-4 AVC (part 10)(avc1)
Language English
Resolution 720x448
Frame rate 23.971824
Decoded format Planar 4:2:0 YUV
MPEG Streamclip reports:
Quote:Stream: Zathura.m4v
Path: /Volumes/iTunes/iTunes Music/Movies/Zathura.m4v
Duration: 1:41:24
Data Size: 2.50 GB
Bit Rate: 3.52 Mbps
Video Tracks:
H.264, 720 × 448, ~23.976 fps, 2.92 Mbps
Audio Tracks:
MPEG-4 Audio stereo, 48 kHz, 160 kbps
?, 0.001 kHz, 448 kbps
Stream Files:
Zathura.m4v (2.50 GB)
And Quicktime 7 reports,
Quote:Format: H.264, 720 x 448 (1,121 x 448) AAC, 48000 Hz, Stereo (L R)
FPS: 23.97
Data size: 2.68 GB
Data rate: 3.53 Mbit/s
Current size: 1,121 x 448 (Actual)
So can anyone explain why these movies don't play in XBMC and if there is anything I can do to fix the issue?
Dnar
Ned,
I've enclosed the debug log for "Bambi II". VLC reports:
Stream 0:
Type: Video
Codec: H264 - MPEG-4 AVC (part 10) (avc1)
Language: English
Resolution: 720x480
Frame Rate: 23.971126
Decoded format: Planar 4:2:0 YUV
Stream 1:
Type: Audio
Codec: MPEG AAC Audio (mp4a)
Language: English
Channels: Stereo
Sample rate: 48000 Hz
Stream 2:
Type: Audio
Codec A52 Audio (ada AC3)(a62)
Language: English
Description: Surround
Bitrate: 192 kb/s
I have enclosed the debug log below. I edited out what I hope was unnecessary information to make the log smaller. If there appears to be something that I've deleted that you need, I'll replay and submit the entire log. I have also found a solution. I first tried "MPEG Streamclip" opening and "save as" to produce a copy without conversion. That produced a playable movie, however, the resulting file only contained streams 0 and 1. The AC3 stream was missing. I then tried pay ware software called "SimpleMovieX" and opened and then a "save as" to produce a copy without conversion. That worked. All three streams exist in the resulting file and all three are playable. So whatever was causing XBMC not to play the movie was fixed using that program (however, Quicktime, VLC, and MPEG Streamclip could all play the video, although I cannot verify if they all could play stream 2).
Here is the log:
09:34:58 T:2733357888 DEBUG: DoWork - trying to extract filestream details from video file afp://itunes:[email protected]/iTunes/iTunes Music/Movies/Bambi II.m4v
09:34:58 T:2733357888 DEBUG: CAFPFile::Open - opened iTunes/iTunes Music/Movies/Bambi II.m4v, fd=0
09:34:58 T:2733357888 DEBUG: Open - probing detected format [mov,mp4,m4a,3gp,3g2,mj2]
09:34:59 T:2733357888 DEBUG: Open - avformat_find_stream_info starting
09:34:59 T:2733357888 DEBUG: ffmpeg[A2EBBB40]: [mov,mp4,m4a,3gp,3g2,mj2] max_analyze_duration 5000000 reached at 5024000
09:34:59 T:2733357888 DEBUG: ffmpeg[A2EBBB40]: [mov,mp4,m4a,3gp,3g2,mj2] decoding for stream 0 failed
09:34:59 T:2733357888 DEBUG: ffmpeg[A2EBBB40]: [mov,mp4,m4a,3gp,3g2,mj2] Could not find codec parameters (Video: h264 (avc1 / 0x31637661), 1169 kb/s)
09:34:59 T:2733357888 DEBUG: ffmpeg[A2EBBB40]: [mov,mp4,m4a,3gp,3g2,mj2] decoding for stream 3 failed
09:34:59 T:2733357888 DEBUG: Open - av_find_stream_info finished
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'afp://itunes:[email protected]/iTunes/iTunes Music/Movies/Bambi II.m4v':
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: Metadata:
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: major_brand : mp42
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: minor_version : 0
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: compatible_brands: mp42isom
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: creation_time : 2008-07-11 21:21:14
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: encoder : HandBrake svn1554M 2008070301
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: title : Bambi II
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: artist : Patrick Stewart, Cree Summer, Keith Ferguson, Brian Pimental, Andrea Bowen
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: date : 2006-09-26T02:00:00Z
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: genre : Kids & Family
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: description : Join Bambi as he reunites with his father, The Great Prince, who must now raise the young fawn and teach him the ways of the forest. But, in the adventure of a lifetime, the proud parent discovers that there is much that he can learn from his spirited yo
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: synopsis : Picking up shortly after the original movie's end, Bambi follows his father, the Great Prince, into the forest after his mother's death and the Great Prince must teach the young fawn, and his friends Thumper, Flower and Owl, how a deer survives in the for
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: media_type : 0
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: Duration: 01:12:25.47, start: 0.000000, bitrate: 1779 kb/s
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: Chapter #0.0: start 0.000000, end 327.432333
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: title : Chapter 1
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: Chapter #0.1: start 327.432333, end 559.375563
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: title : Chapter 2
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: Chapter #0.2: start 559.375563, end 780.044917
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: title : Chapter 3
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: Chapter #0.3: start 780.044917, end 1012.606917
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: title : Chapter 4
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: Chapter #0.4: start 1012.606917, end 1229.155687
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: title : Chapter 5
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: Chapter #0.5: start 1229.155687, end 1567.275646
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: title : Chapter 6
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: Chapter #0.6: start 1567.275646, end 1833.666771
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: title : Chapter 7
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: Chapter #0.7: start 1833.666771, end 2084.989292
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: title : Chapter 8
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: Chapter #0.8: start 2084.989292, end 2322.274771
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: title : Chapter 9
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: Chapter #0.9: start 2322.274771, end 2578.212187
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: title : Chapter 10
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: Chapter #0.10: start 2578.212187, end 2887.595771
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: title : Chapter 11
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: Chapter #0.11: start 2887.595771, end 3145.854562
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: title : Chapter 12
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: Chapter #0.12: start 3145.854562, end 3149.567167
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: title : Chapter 13
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: Chapter #0.13: start 3149.567167, end 3249.081688
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: title : Chapter 14
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: Chapter #0.14: start 3249.081688, end 3605.282813
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: title : Chapter 15
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: Chapter #0.15: start 3605.282813, end 3877.719917
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: title : Chapter 16
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: Chapter #0.16: start 3877.719917, end 4340.655542
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: title : Chapter 17
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: Chapter #0.17: start 4340.655542, end 4341.422979
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: title : Chapter 18
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: Stream #0:0(eng): Video: h264 (avc1 / 0x31637661), 1169 kb/s, SAR 853:720 DAR 0:0, 23.97 fps, 48k tbr, 48k tbn, 96k tbc
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: handler_name :
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: Stream #0:1(eng): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, s16, 159 kb/s
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: Stream #0:2(eng): Audio: ac3 (ac-3 / 0x332D6361), 48000 Hz, 5.1(side), s16, 448 kb/s
09:34:59 T:2733357888 INFO: ffmpeg[A2EBBB40]: Stream #0:3(eng): Subtitle: mov_text (text / 0x74786574)
09:34:59 T:2733357888 DEBUG: CAFPFile::Close closing fd 0
09:34:59 T:2733357888 ERROR: SQL: SQL error or missing database
Query: INSERT INTO streamdetails (idFile, iStreamType, strVideoCodec, fVideoAspect, iVideoWidth, iVideoHeight, iVideoDuration) VALUES (568,0,'avc1',NaN,0,0,4345)
09:34:59 T:2733357888 ERROR: SetStreamDetailsForFileId (568) failed
09:35:31 T:2683886400 DEBUG: Thread Jobworker 2683886400 terminating (autodelete)
09:35:31 T:2692279104 DEBUG: Thread Jobworker 2692279104 terminating (autodelete)
09:35:32 T:2733357888 DEBUG: Thread Jobworker 2733357888 terminating (autodelete)
09:35:33 T:3008653120 DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/players/dvdplayer/avcodec-53-i486-linux.so)
09:35:33 T:3008653120 DEBUG: Unloading: avcodec-53-i486-linux.so
09:35:33 T:3008653120 DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/players/dvdplayer/avformat-53-i486-linux.so)
09:35:33 T:3008653120 DEBUG: Unloading: avformat-53-i486-linux.so
09:36:17 T:3008653120 DEBUG: CAnnouncementManager - Announcement: OnScreensaverActivated from xbmc
09:36:17 T:3008653120 DEBUG: GOT ANNOUNCEMENT, type: 4, from xbmc, message OnScreensaverActivated
09:36:17 T:3008653120 DEBUG: ------ Window Init () ------
09:36:17 T:3008653120 DEBUG: Alloc resources: 0.01ms (0.01 ms skin load)
09:36:35 T:3008653120 NOTICE: AFP is idle. Closing the remaining connections.
09:38:17 T:3008653120 INFO: DPMS: enabled power-saving mode SUSPEND
09:38:18 T:3008653120 DEBUG: ------ Window Deinit () ------
09:48:24 T:3008653120 INFO: DPMS: disabled power-saving
09:48:24 T:3008653120 DEBUG: CAnnouncementManager - Announcement: OnScreensaverDeactivated from xbmc
09:48:24 T:3008653120 DEBUG: GOT ANNOUNCEMENT, type: 4, from xbmc, message OnScreensaverDeactivated
09:48:26 T:2973780800 INFO: CAESinkALSA::Initialize - Attempting to open device "@"
09:48:26 T:2973780800 INFO: CAESinkALSA::Initialize - Opened device "front"
09:48:26 T:3008653120 DEBUG: CGUIMediaWindow::GetDirectory (sources://video/)
09:48:26 T:3008653120 DEBUG: ParentPath = []
09:48:26 T:2973780800 INFO: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
09:48:26 T:2973780800 INFO: CAESinkALSA::InitializeHW - Using data format AE_FMT_S32NE
09:48:26 T:2973780800 DEBUG: CAESinkALSA::InitializeHW - Request: periodSize 2048, bufferSize 8192
09:48:26 T:2973780800 DEBUG: CAESinkALSA::InitializeHW - Got: periodSize 2048, bufferSize 8192
09:48:26 T:2973780800 DEBUG: CAESinkALSA::InitializeHW - Setting timeout to 186 ms
09:48:26 T:2973780800 DEBUG: Resumed the Sink
09:48:26 T:2733357888 NOTICE: Thread Jobworker start, auto delete: true
09:48:26 T:2692279104 NOTICE: Thread Background Loader start, auto delete: false
09:48:26 T:2692279104 DEBUG: Thread Background Loader 2692279104 terminating
09:48:27 T:3008653120 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
09:48:28 T:3008653120 DEBUG: ------ Window Deinit (MyVideoNav.xml) ------
09:48:28 T:3008653120 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
09:48:28 T:3008653120 DEBUG: ------ Window Init (Home.xml) ------
09:48:28 T:3008653120 DEBUG: Window Home.xml was already loaded
09:48:28 T:3008653120 DEBUG: Alloc resources: 113.42m
09:48:33 T:3008653120 DEBUG: ExecuteXBMCAction : Translating ActivateWindow(Videos,MovieTitles,return)
09:48:33 T:3008653120 DEBUG: ExecuteXBMCAction : To ActivateWindow(Videos,MovieTitles,return)
09:48:33 T:3008653120 DEBUG: Activating window ID: 10025
09:48:33 T:3008653120 DEBUG: ------ Window Deinit (Home.xml) ------
09:48:33 T:3008653120 DEBUG: ExecuteXBMCAction : Translating SetProperty(VideosDirectLink,True)
09:48:33 T:3008653120 DEBUG: ExecuteXBMCAction : To SetProperty(VideosDirectLink,True)
09:48:33 T:3008653120 DEBUG: ------ Window Init (MyVideoNav.xml) ------
09:48:33 T:3008653120 DEBUG: Window MyVideoNav.xml was already loaded
09:48:33 T:3008653120 DEBUG: Alloc resources: 29.26m
09:48:33 T:3008653120 DEBUG: CGUIMediaWindow::GetDirectory (videodb://1/2/)
09:48:33 T:3008653120 DEBUG: ParentPath = [videodb://1/2/]
09:48:33 T:3008653120 DEBUG: RunQuery took 212 ms for 535 items query: select * from movieview
09:48:33 T:2692279104 NOTICE: Thread Background Loader start, auto delete: false
09:48:33 T:2683886400 NOTICE: Thread Jobworker start, auto delete: true
09:48:33 T:2733357888 DEBUG: DoWork - trying to extract filestream details from video file afp://itunes:[email protected]/iTunes/iTunes Music/Movies/Alien 3.m4v
09:48:34 T:2692279104 DEBUG: Thread Background Loader 2692279104 terminating
09:48:34 T:2692279104 NOTICE: Thread Background Loader start, auto delete: false
09:48:35 T:2692279104 NOTICE: Thread Jobworker start, auto delete: true
09:48:35 T:2733357888 DEBUG: AFP: Connected to server server.dnar.net using UAM "DHX2"
09:48:35 T:2733357888 DEBUG: AFP: Connected to volume iTunes
09:48:35 T:2733357888 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/players/dvdplayer/avcodec-53-i486-linux.so)
09:48:35 T:2733357888 DEBUG: Loading: /usr/xbmc/lib/xbmc/system/players/dvdplayer/avcodec-53-i486-linux.so
09:48:35 T:2683886400 DEBUG: DoWork - took 317 ms to load special://masterprofile/Thumbnails/a/a7b2d5b3.jpg
09:48:35 T:2692279104 DEBUG: DoWork - took 195 ms to load special://masterprofile/Thumbnails/d/dd4bc42e.jpg
09:48:35 T:2733357888 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/players/dvdplayer/avformat-53-i486-linux.so)
09:48:35 T:2733357888 DEBUG: Loading: /usr/xbmc/lib/xbmc/system/players/dvdplayer/avformat-53-i486-linux.so
09:48:57 T:3008653120 DEBUG: OnPlayMedia afp://itunes:[email protected]/iTunes/iTunes Music/Movies/Bambi II.m4v
09:48:57 T:3008653120 DEBUG: CAnnouncementManager - Announcement: OnClear from xbmc
09:48:57 T:3008653120 DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnClear
09:48:57 T:3008653120 DEBUG: CAnnouncementManager - Announcement: OnAdd from xbmc
09:48:57 T:3008653120 DEBUG: GOT ANNOUNCEMENT, type: 2, from xbmc, message OnAdd
09:48:57 T:2716326720 DEBUG: Open - avformat_find_stream_info starting
09:48:57 T:3008653120 DEBUG: CPlayerCoreFactory::GetPlayers(afp://itunes:[email protected]/iTunes/iTunes Music/Movies/Bambi II.m4v)
09:48:57 T:3008653120 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: system rules
09:48:57 T:3008653120 DEBUG: CPlayerSelectionRule::GetPlayers: matches rule: system rules
09:48:57 T:3008653120 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtv
09:48:57 T:3008653120 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: hdhomerun/myth/mms/udp
09:48:57 T:3008653120 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: lastfm/shout
09:48:57 T:3008653120 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtmp
09:48:57 T:3008653120 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: rtsp
09:48:57 T:3008653120 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: streams
09:48:57 T:3008653120 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvd
09:48:57 T:3008653120 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: dvdimage
09:48:57 T:3008653120 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: sdp/asf
09:48:57 T:3008653120 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: nsv
09:48:57 T:3008653120 DEBUG: CPlayerSelectionRule::GetPlayers: considering rule: radio
09:48:57 T:3008653120 DEBUG: CPlayerCoreFactory::GetPlayers: matched 0 rules with players
09:48:57 T:3008653120 DEBUG: CPlayerCoreFactory::GetPlayers: adding videodefaultplayer (1)
09:48:57 T:3008653120 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=0
09:48:57 T:3008653120 DEBUG: CPlayerCoreFactory::GetPlayers: for video=1, audio=1
09:48:57 T:3008653120 DEBUG: CPlayerCoreFactory::GetPlayers: adding player: DVDPlayer (1)
09:48:57 T:3008653120 DEBUG: CPlayerCoreFactory::GetPlayers: added 1 players
09:48:57 T:3008653120 NOTICE: DVDPlayer: Opening: afp://itunes:[email protected]/iTunes/iTunes Music/Movies/Bambi II.m4v
09:48:57 T:3008653120 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
09:48:57 T:3008653120 DEBUG: CRenderManager::UpdateDisplayLatency - Latency set to 0 msec
09:48:57 T:3008653120 DEBUG: LinuxRendererGL: Cleaning up GL resources
09:48:57 T:3008653120 DEBUG: CLinuxRendererGL::PreInit - precision of luminance 16 is 16
09:48:57 T:2778229568 NOTICE: Thread CDVDPlayer start, auto delete: false
09:48:57 T:2778229568 NOTICE: Creating InputStream
09:48:57 T:2778229568 DEBUG: CAFPFile::Open - opened iTunes/iTunes Music/Movies/Bambi II.m4v, fd=0
09:48:57 T:3008653120 DEBUG: ------ Window Init (DialogBusy.xml) ------
09:48:57 T:3008653120 DEBUG: Window DialogBusy.xml was already loaded
09:48:57 T:3008653120 DEBUG: Alloc resources: 0.06m
09:48:57 T:2716326720 DEBUG: ffmpeg[A1E7DB40]: [mov,mp4,m4a,3gp,3g2,mj2] max_analyze_duration 5000000 reached at 5024000
09:48:57 T:2716326720 DEBUG: ffmpeg[A1E7DB40]: [mov,mp4,m4a,3gp,3g2,mj2] decoding for stream 0 failed
09:48:57 T:2716326720 DEBUG: ffmpeg[A1E7DB40]: [mov,mp4,m4a,3gp,3g2,mj2] Could not find codec parameters (Video: h264 (avc1 / 0x31637661), 2420 kb/s)
09:48:57 T:2716326720 DEBUG: ffmpeg[A1E7DB40]: [mov,mp4,m4a,3gp,3g2,mj2] decoding for stream 3 failed
09:48:57 T:2716326720 DEBUG: Open - av_find_stream_info finished
09:49:05 T:2778229568 DEBUG: CrystalHD(new API): device opened
09:49:05 T:2778229568 DEBUG: CrystalHD: profile 42c01e
09:49:05 T:2778229568 DEBUG: CrystalHD: nal size 4
09:49:05 T:2778229568 DEBUG: CrystalHD: num sps 1
09:49:05 T:2778229568 DEBUG: CrystalHD: data size at end = 0
09:49:06 T:2778229568 INFO: DVDVideoCodecCrystalHD: Opened Broadcom Crystal HD Codec
09:49:06 T:2778229568 DEBUG: FactoryCodec - Video: chd-h264 - Opened
09:49:06 T:2778229568 ERROR: CDVDPlayerVideo::OpenStream - Invalid framerate 48000, using forced 25fps and just trust timestamps
09:49:06 T:2778229568 NOTICE: Creating video thread
09:49:06 T:2656123712 NOTICE: Thread CDVDPlayerVideo start, auto delete: false
09:49:06 T:2656123712 NOTICE: running thread: video_thread
09:49:06 T:2778229568 NOTICE: Opening audio stream: 2 source: 256
09:49:06 T:2778229568 NOTICE: Finding audio codec for: 86019
09:49:06 T:2778229568 DEBUG: FactoryCodec - Audio: FFmpeg - Opening
09:49:06 T:2778229568 DEBUG: SECTION:LoadDLL(special://xbmcbin/system/players/dvdplayer/swresample-0-i486-linux.so)
09:49:06 T:2778229568 DEBUG: Loading: /usr/xbmc/lib/xbmc/system/players/dvdplayer/swresample-0-i486-linux.so
09:49:06 T:2656123712 DEBUG: CDVDPlayerVideo - CDVDMsg::GENERAL_SYNCHRONIZE
09:49:06 T:2664516416 NOTICE: Thread CMPCOutputThread start, auto delete: false
09:49:06 T:2664516416 DEBUG: CrystalHD: Output Thread Started...
09:49:06 T:2778229568 DEBUG: FactoryCodec - Audio: FFmpeg - Opened
09:49:06 T:2778229568 NOTICE: Creating audio thread
09:49:06 T:2644040512 NOTICE: Thread CDVDPlayerAudio start, auto delete: false
09:49:06 T:2778229568 NOTICE: Opening Subtitle stream: 3 source: 256
09:49:06 T:2778229568 DEBUG: FactoryCodec - Overlay: TX3G Subtitle Decoder - Opening
09:49:06 T:2778229568 DEBUG: FactoryCodec - Overlay: TX3G Subtitle Decoder - Opened
09:49:06 T:2778229568 DEBUG: ReadEditDecisionLists - Checking for edit decision lists (EDL) on local drive or remote share for: afp://itunes:[email protected]/iTunes/iTunes Music/Movies/Bambi II.m4v
09:49:06 T:2644040512 NOTICE: running thread: CDVDPlayerAudio::Process()
09:49:06 T:2692279104 DEBUG: Open - avformat_find_stream_info starting
09:49:06 T:2778229568 INFO: CAFPFile::Open: Unable to open file : '/iTunes Music/Movies/Bambi II.Vprj'
unix_err:'2' error : 'No such file or directory'
09:49:06 T:2778229568 DEBUG: CAFPFile::Close closing fd 0
09:49:06 T:2778229568 ERROR: ReadVideoReDo - Could not open VideoReDo file: afp://itunes:[email protected]/iTunes/iTunes Music/Movies/Bambi II.Vprj
09:49:06 T:2778229568 INFO: CAFPFile::Open: Unable to open file : '/iTunes Music/Movies/Bambi II.edl'
09:49:06 T:2778229568 ERROR: ReadEdl - Could not open EDL file: afp://itunes:[email protected]/iTunes/iTunes Music/Movies/Bambi II.edl
09:49:06 T:2778229568 INFO: CAFPFile::Open: Unable to open file : '/iTunes Music/Movies/Bambi II.txt'
09:49:06 T:2778229568 ERROR: ReadComskip - Could not open Comskip file: afp://itunes:[email protected]/iTunes/iTunes Music/Movies/Bambi II.txt
09:49:06 T:2778229568 INFO: CAFPFile::Open: Unable to open file : '/iTunes Music/Movies/Bambi II.m4v.chapters.xml'
09:49:06 T:2778229568 ERROR: ReadBeyondTV - Could not load Beyond TV file: afp://itunes:[email protected]/iTunes/iTunes Music/Movies/Bambi II.m4v.chapters.xml. Failed to open file
09:49:06 T:2778229568 DEBUG: CDVDPlayer::SetCaching - caching state 3
09:49:06 T:2644040512 NOTICE: Creating audio stream (codec id: 86019, channels: 6, sample rate: 48000, no pass-through)
09:49:06 T:2644040512 INFO: CSoftAE::MakeStream - AE_FMT_S16NE, 48000, FL,FR,FC,LFE,SL,SR
09:49:06 T:2973780800 DEBUG: CSoftAE::Run - Sink restart flagged
09:49:06 T:2973780800 INFO: CSoftAE::LoadSettings - Stereo upmix is enabled
09:49:06 T:2973780800 INFO: CSoftAE::InternalOpenSink - sink incompatible, re-starting
09:49:06 T:2656123712 INFO: CDVDPlayerVideo - Stillframe left, switching to normal playback
09:49:06 T:2656123712 DEBUG: CDVDPlayerVideo - CDVDMsg::GENERAL_RESYNC(33354.166667, 0)
09:49:06 T:2778229568 DEBUG: CDVDPlayer::SetCaching - caching state 0
09:49:06 T:2664516416 DEBUG: CrystalHD: Format Change Detected. Flags: 0x00030000
09:49:06 T:2664516416 DEBUG: ----------------------------------
09:49:06 T:2664516416 DEBUG: TimeStamp: 0
09:49:06 T:2664516416 DEBUG: Picture Number: 0
09:49:06 T:2664516416 DEBUG: Width: 720
09:49:06 T:2664516416 DEBUG: Height: 480
09:49:06 T:2664516416 DEBUG: Chroma: 0x001
09:49:06 T:2664516416 DEBUG: Pulldown: 9
09:49:06 T:2664516416 DEBUG: Flags: 0x00000000
09:49:06 T:2664516416 DEBUG: Frame Rate/Res: 0
09:49:06 T:2664516416 DEBUG: Aspect Ratio: 255
09:49:06 T:2664516416 DEBUG: Color Primaries: 101056768
09:49:06 T:2664516416 DEBUG: MetaData: 0
09:49:06 T:2664516416 DEBUG: Session Number: 0
09:49:06 T:2664516416 DEBUG: Custom Aspect: 0
09:49:06 T:2664516416 DEBUG: Frames to Drop: 0
09:49:06 T:2664516416 DEBUG: H264 Valid Fields: 0x00000000
09:49:06 T:2664516416 DEBUG: CrystalHD: dec_par x = 1, dec_par y = 1
09:49:06 T:2664516416 DEBUG: CrystalHD: resolution = 0 interlace = 0
09:49:06 T:2664516416 DEBUG: CrystalHD: No timestamp detected: 0
09:49:06 T:2664516416 DEBUG: CrystalHD: Added a new Buffer, ReadyListCount: 0
09:49:06 T:2656123712 NOTICE: fps: 25.000000, pwidth: 720, pheight: 480, dwidth: -2147483648, dheight: 480
09:49:06 T:2656123712 DEBUG: OutputPicture - change configuration. 720x480. framerate: 25.00. format: YUY2
09:49:06 T:2664516416 DEBUG: CrystalHD: Added a new Buffer, ReadyListCount: 1
09:49:06 T:2664516416 DEBUG: CrystalHD: Added a new Buffer, ReadyListCount: 2
09:49:06 T:3008653120 DEBUG: CGUIInfoManager::SetCurrentMovie(afp://itunes:[email protected]/iTunes/iTunes Music/Movies/Bambi II.m4v)
09:49:06 T:2692279104 DEBUG: ffmpeg[A078EB40]: [mov,mp4,m4a,3gp,3g2,mj2] max_analyze_duration 5000000 reached at 5024000
09:49:06 T:2692279104 DEBUG: ffmpeg[A078EB40]: [mov,mp4,m4a,3gp,3g2,mj2] decoding for stream 0 failed
09:49:06 T:2692279104 DEBUG: ffmpeg[A078EB40]: [mov,mp4,m4a,3gp,3g2,mj2] Could not find codec parameters (Video: h264 (avc1 / 0x31637661), 3099 kb/s)
09:49:06 T:2692279104 DEBUG: ffmpeg[A078EB40]: [mov,mp4,m4a,3gp,3g2,mj2] decoding for stream 3 failed
09:49:06 T:2692279104 DEBUG: Open - av_find_stream_info finished
09:49:06 T:2664516416 DEBUG: CrystalHD: Added a new Buffer, ReadyListCount: 7
09:49:06 T:2664516416 DEBUG: CrystalHD: Added a new Buffer, ReadyListCount: 8
09:49:06 T:3008653120 DEBUG: GetMovieId (afp://itunes:[email protected]/iTunes/iTunes Music/Movies/Bambi II.m4v), query = select idMovie from movie where idFile=568
09:49:06 T:2664516416 DEBUG: CrystalHD: Added a new Buffer, ReadyListCount: 9
09:49:06 T:2692279104 DEBUG: CAFPFile::Close closing fd 0
09:49:06 T:2664516416 DEBUG: CrystalHD: Added a new Buffer, ReadyListCount: 10
09:49:06 T:2664516416 DEBUG: CrystalHD: Added a new Buffer, ReadyListCount: 11
09:49:07 T:2692279104 ERROR: SQL: SQL error or missing database
Query: INSERT INTO streamdetails (idFile, iStreamType, strVideoCodec, fVideoAspect, iVideoWidth, iVideoHeight, iVideoDuration) VALUES (1037,0,'avc1',NaN,0,0,9757)
09:49:07 T:2656123712 WARNING: CRenderManager::Configure - timeout waiting for previous frame
09:49:07 T:2656123712 NOTICE: Display resolution DESKTOP : 1280x720 @ 60.00 - Full Screen (16)
09:49:07 T:2692279104 ERROR: SetStreamDetailsForFileId (1037) failed
09:49:07 T:2973780800 INFO: CAESinkALSA::Initialize - Attempting to open device "@"
09:49:07 T:2973780800 INFO: CAESinkALSA::Initialize - Opened device "sysdefault"
09:49:07 T:2973780800 INFO: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
09:49:07 T:2973780800 INFO: CAESinkALSA::InitializeHW - Using data format AE_FMT_S32NE
09:49:07 T:2973780800 DEBUG: CAESinkALSA::InitializeHW - Request: periodSize 1024, bufferSize 8192
09:49:07 T:2973780800 DEBUG: CAESinkALSA::InitializeHW - Got: periodSize 1024, bufferSize 8192
09:49:07 T:2973780800 DEBUG: CAESinkALSA::InitializeHW - Setting timeout to 171 ms
09:49:07 T:2973780800 DEBUG: CSoftAE::InternalOpenSink - ALSA Initialized:
09:49:07 T:2973780800 DEBUG: Output Device : Default (HDA Intel ALC889A Analog)
09:49:07 T:2973780800 DEBUG: Sample Rate : 48000
09:49:07 T:2973780800 DEBUG: Sample Format : AE_FMT_S32NE
09:49:07 T:2973780800 DEBUG: Channel Count : 2
09:49:07 T:2973780800 DEBUG: Channel Layout: FL,FR
09:49:07 T:2973780800 DEBUG: Frames : 1024
09:49:07 T:2973780800 DEBUG: Frame Samples : 2048
09:49:07 T:2973780800 DEBUG: Frame Size : 8
09:49:07 T:2973780800 DEBUG: CSoftAE::InternalOpenSink - Using speaker layout: 2.0
09:49:07 T:2973780800 DEBUG: CSoftAE::InternalOpenSink - Internal Buffer Size: 8192
09:49:07 T:2973780800 DEBUG: AERemap: Downmix normalization is disabled
09:49:07 T:3008653120 DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
09:49:07 T:3008653120 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
09:49:07 T:3008653120 DEBUG: Activating window ID: 12005
09:49:07 T:3008653120 DEBUG: ------ Window Deinit (MyVideoNav.xml) ------
09:49:07 T:3008653120 DEBUG: ------ Window Init (VideoFullScreen.xml) ------
09:49:07 T:2778229568 DEBUG: CDVDPlayer::HandleMessages - player started 2
09:49:07 T:3008653120 DEBUG: Window VideoFullScreen.xml was already loaded
09:49:07 T:3008653120 DEBUG: Alloc resources: 40.74m
09:49:07 T:2664516416 DEBUG: CrystalHD: Added a new Buffer, ReadyListCount: 12
09:49:07 T:2973780800 DEBUG: Previous line repeats 2 times.
09:49:07 T:2973780800 DEBUG: CSoftAEStream::CSoftAEStream - Converting from AE_FMT_S16NE to AE_FMT_FLOAT
09:49:07 T:2644040512 DEBUG: CDVDPlayerAudio:: synctype set to 0: clock feedback
09:49:07 T:2644040512 DEBUG: CDVDPlayerAudio - CDVDMsg::GENERAL_RESYNC(32000.000000, 1)
09:49:07 T:2644040512 DEBUG: CDVDPlayerAudio:: Discontinuity1 - was:661.269999, should be:667.696000, error:6.426001
09:49:07 T:2778229568 DEBUG: CDVDPlayer::HandleMessages - player started 1
09:49:07 T:2973780800 DEBUG: CSoftAE::Run - Sink restart flagged
09:49:07 T:2973780800 INFO: CSoftAE::LoadSettings - Stereo upmix is enabled
09:49:07 T:2973780800 INFO: CSoftAE::InternalOpenSink - keeping old sink with : AE_FMT_FLOAT, FL,FR, 48000hz
09:49:07 T:3008653120 NOTICE: Using GL_TEXTURE_2D
09:49:07 T:3008653120 DEBUG: GL: Requested render method: 0
09:49:07 T:3008653120 DEBUG: GL: BaseYUV2RGBGLSLShader: defines:
#define XBMC_texture_rectangle 0
#define XBMC_texture_rectangle_hack 0
#define XBMC_STRETCH 0
#define XBMC_YUY2
09:49:07 T:3008653120 NOTICE: GL: Selecting Single Pass YUV 2 RGB shader
09:49:07 T:3008653120 DEBUG: GL: Vertex Shader compilation log:
09:49:07 T:3008653120 DEBUG: GL: Vertex Shader compiled successfully
09:49:07 T:3008653120 DEBUG: GL: Pixel Shader compilation log:
09:49:07 T:3008653120 DEBUG: GL: Fragment Shader compiled successfully
09:49:07 T:3008653120 NOTICE: GL: NPOT texture support detected
09:49:07 T:3008653120 NOTICE: GL: Using GL_ARB_pixel_buffer_object
09:49:07 T:3008653120 DEBUG: ------ Window Deinit (DialogBusy.xml) ------
09:49:07 T:2644040512 DEBUG: CDVDPlayerAudio:: Discontinuity1 - was:526653.523000, should be:384000.000000, error:-142653.523000
09:49:09 T:2644040512 DEBUG: CDVDPlayerAudio:: Discontinuity2 - was:2388943.617000, should be:2338178.944952, error:-50764.672048
09:49:25 T:2656123712 DEBUG: CPullupCorrection: detected pattern of length 2: 33369.33 50047.33, frameduration: 41708.333333
09:49:25 T:2656123712 DEBUG: CPullupCorrection: pattern lost on diff 33380.000000
09:49:30 T:2656123712 DEBUG: CPullupCorrection: detected pattern of length 2: 33365.33 50051.33, frameduration: 41708.333333
09:49:32 T:2656123712 DEBUG: CPullupCorrection: pattern lost on diff 33400.000000
09:49:37 T:2683886400 DEBUG: Thread Jobworker 2683886400 terminating (autodelete)
09:49:37 T:2733357888 DEBUG: Thread Jobworker 2733357888 terminating (autodelete)
09:49:37 T:2716326720 DEBUG: Thread Jobworker 2716326720 terminating (autodelete)
09:49:37 T:2692279104 DEBUG: Thread Jobworker 2692279104 terminating (autodelete)
09:49:37 T:2656123712 DEBUG: CPullupCorrection: detected pattern of length 2: 33356.67 50060.00, frameduration: 41708.333333
09:49:58 T:2877279040 NOTICE: ES: Client from 127.0.0.1 timed out
09:50:03 T:3008653120 NOTICE: CDVDPlayer::CloseFile()
09:50:03 T:3008653120 NOTICE: DVDPlayer: waiting for threads to exit
09:50:03 T:2778229568 NOTICE: CDVDPlayer::OnExit()
09:50:03 T:2778229568 NOTICE: DVDPlayer: closing audio stream
09:50:03 T:2778229568 NOTICE: Closing audio stream
09:50:03 T:2778229568 NOTICE: Waiting for audio thread to exit
09:50:03 T:2644040512 NOTICE: thread end: CDVDPlayerAudio::OnExit()
09:50:03 T:2644040512 DEBUG: Thread CDVDPlayerAudio 2644040512 terminating
09:50:03 T:2778229568 NOTICE: Closing audio device
09:50:03 T:2778229568 DEBUG: CSoftAEStream::~CSoftAEStream - Destructed
09:50:03 T:2778229568 NOTICE: Deleting audio codec
09:50:03 T:2778229568 NOTICE: DVDPlayer: closing video stream
09:50:03 T:2778229568 NOTICE: Closing video stream
09:50:03 T:2778229568 NOTICE: waiting for video thread to exit
09:50:03 T:2973780800 DEBUG: CSoftAE::Run - Sink restart flagged
09:50:03 T:2973780800 INFO: CSoftAE::LoadSettings - Stereo upmix is enabled
09:50:03 T:2973780800 INFO: CSoftAE::InternalOpenSink - sink incompatible, re-starting
09:50:03 T:2656123712 NOTICE: thread end: video_thread
09:50:03 T:2656123712 DEBUG: Thread CDVDPlayerVideo 2656123712 terminating
09:50:03 T:2778229568 NOTICE: deleting video codec
09:50:03 T:2664516416 DEBUG: CrystalHD: Output Thread Stopped...
09:50:03 T:2664516416 DEBUG: Thread CMPCOutputThread 2664516416 terminating
09:50:03 T:2973780800 INFO: CAESinkALSA::Initialize - Attempting to open device "@"
09:50:03 T:2973780800 INFO: CAESinkALSA::Initialize - Opened device "front"
09:50:03 T:2973780800 INFO: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
09:50:03 T:2973780800 INFO: CAESinkALSA::InitializeHW - Using data format AE_FMT_S32NE
09:50:03 T:2973780800 DEBUG: CAESinkALSA::InitializeHW - Request: periodSize 2048, bufferSize 8192
09:50:03 T:2973780800 DEBUG: CAESinkALSA::InitializeHW - Got: periodSize 2048, bufferSize 8192
09:50:03 T:2973780800 DEBUG: CAESinkALSA::InitializeHW - Setting timeout to 186 ms
09:50:03 T:2973780800 DEBUG: CSoftAE::InternalOpenSink - ALSA Initialized:
09:50:03 T:2973780800 DEBUG: Output Device : Default (HDA Intel ALC889A Analog)
09:50:03 T:2973780800 DEBUG: Sample Rate : 44100
09:50:03 T:2973780800 DEBUG: Sample Format : AE_FMT_S32NE
09:50:03 T:2973780800 DEBUG: Channel Count : 2
09:50:03 T:2973780800 DEBUG: Channel Layout: FL,FR
09:50:03 T:2973780800 DEBUG: Frames : 2048
09:50:03 T:2973780800 DEBUG: Frame Samples : 4096
09:50:03 T:2973780800 DEBUG: Frame Size : 8
09:50:03 T:2973780800 DEBUG: CSoftAE::InternalOpenSink - Using speaker layout: 2.0
09:50:03 T:2973780800 DEBUG: CSoftAE::InternalOpenSink - Internal Buffer Size: 16384
09:50:03 T:2778229568 DEBUG: CrystalHD: device closed
09:50:03 T:2778229568 NOTICE: DVDPlayer: closing subtitle stream
09:50:03 T:2778229568 NOTICE: Closing subtitle stream
09:50:03 T:2778229568 NOTICE: CDVDPlayer::OnExit() deleting demuxer
09:50:03 T:2778229568 NOTICE: CDVDPlayer::OnExit() deleting input stream
09:50:03 T:2778229568 DEBUG: CAFPFile::Close closing fd 0
09:50:03 T:2778229568 DEBUG: CAnnouncementManager - Announcement: OnStop from xbmc
09:50:03 T:2778229568 DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnStop
09:50:03 T:3008653120 NOTICE: DVDPlayer: finished waiting
09:50:03 T:3008653120 DEBUG: LinuxRendererGL: Cleaning up GL resources
09:50:03 T:3008653120 DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
09:50:03 T:3008653120 DEBUG: ------ Window Deinit (VideoFullScreen.xml) ------
09:50:03 T:2778229568 DEBUG: Thread CDVDPlayer 2778229568 terminating
09:50:03 T:2973780800 DEBUG: AERemap: Downmix normalization is disabled
09:50:03 T:3008653120 DEBUG: CGUIWindowManager::PreviousWindow: Activate new
09:50:03 T:3008653120 DEBUG: ------ Window Init (MyVideoNav.xml) ------
09:50:03 T:3008653120 DEBUG: Previous line repeats 1 times.
09:50:03 T:3008653120 DEBUG: Window MyVideoNav.xml was already loaded
09:50:03 T:3008653120 DEBUG: Alloc resources: 88.81m
09:50:03 T:3008653120 DEBUG: CGUIMediaWindow::GetDirectory (videodb://1/2/)
09:50:03 T:3008653120 DEBUG: ParentPath = [videodb://1/2/]
09:50:03 T:3008653120 DEBUG: RunQuery took 183 ms for 535 items query: select * from movieview
09:50:04 T:2778229568 NOTICE: Thread Background Loader start, auto delete: false
09:50:04 T:2778229568 DEBUG: Thread Background Loader 2778229568 terminating
09:50:05 T:2778229568 NOTICE: Thread Background Loader start, auto delete: false
09:50:05 T:2778229568 DEBUG: Thread Background Loader 2778229568 terminating
09:50:05 T:3008653120 NOTICE: CDVDPlayer::CloseFile()
09:50:05 T:3008653120 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
09:50:05 T:3008653120 NOTICE: DVDPlayer: waiting for threads to exit
09:50:05 T:3008653120 NOTICE: DVDPlayer: finished waiting
09:50:05 T:3008653120 DEBUG: LinuxRendererGL: Cleaning up GL resources
09:50:05 T:3008653120 DEBUG: SECTION:UnloadDelayed(DLL: special://xbmcbin/system/ImageLib-i486-linux.so)
09:50:05 T:3008653120 DEBUG: Unloading: ImageLib-i486-linux.so
09:50:05 T:2778229568 NOTICE: Thread Jobworker start, auto delete: true
Dnar
Can you upload a full debug log to
http://xbmclogs.com ?
Also can you run
MediaInfo (wiki) on the file? If the video was encoded with something like Handbrake, then the encoding settings will be exposed in the MediaInfo readout, and that might provide some hints as well.
Ned,
Here is the info for Bambi II from Media-info
File: /Volumes/iTunes/iTunes Music/Movies/Bambi II.m4v
Format: QuickTime/MPEG-4/Motion JPEG 2000 format
Chapters count: 18
Stream count: 4
Duration: 01:12:25
Bit rate: 1779 kb/s
Meta info:
description: Join Bambi as he reunites with his father, The Great Prince, who must now raise the young fawn and teach him the ways of the forest. But, in the adventure of a lifetime, the proud parent discovers that there is much that he can learn from his spirited you
synopsis: Picking up shortly after the original movie's end, Bambi follows his father, the Great Prince, into the forest after his mother's death and the Great Prince must teach the young fawn, and his friends Thumper, Flower and Owl, how a deer survives in the forest. But the Great Prince finds that his high-spirited son may have a lesson or two to teach him, as well.
media_type: 0
minor_version: 0
encoder: HandBrake svn1554M 2008070301
title: Bambi II
major_brand: mp42
date: 2006-09-26T02:00:00Z
artist: Patrick Stewart, Cree Summer, Keith Ferguson, Brian Pimental, Andrea Bowen
creation_time: 2008-07-11 21:21:14
genre: Kids & Family
Stream 0
Type: video
Codec: h264
Codec profile: Constrained Baseline
FourCC: avc1
Duration: 01:12:21
Width: 720
Height: 480
Sample aspect ratio: 853:720
Display aspect ratio: 853:480
Pixel format: yuv420p
Frame rate: 23.98 fps
Bit rate: 1169 kb/s
Meta info:
language: eng
Stream 1
Type: audio
Codec: aac
FourCC: mp4a
Duration: 01:12:24
Bit rate: 159 kb/s
Sample format: s16
Channel: 2
Meta info:
language: eng
Stream 2
Type: audio
Codec: ac3
FourCC: ac-3
Duration: 01:12:25
Bit rate: 448 kb/s
Sample format: s16
Channel: 6
Meta info:
language: eng
Stream 3
Type: subtitle
Codec: Unknown codec
Meta info:
language: eng
I'll look up the upload instructions and try to get the entire log file uploaded this afternoon.
Dnar
