I'm displaying the next 10 tracks while playing music. When I startup there is an m3u that is set to play in random order and this is fine. What is displayed is:
TrackNumber Artist: TrackTitle
And that looks ok because the m3u is a compilation of various artists.
The problem is that when I go to my music folders, I turn off the random play and play an album. Now it doesn't look fine because every track has the same artist.
I'd like to display two arrangements:
TrackNumber Artist: TrackTitle (when startup - random on)
or:
TrackNumber TrackTitle (playing an album - random off)
That is, drop the Artist name when playing an album
I've looked at another thread with
<label> $IF[condition,display1 if condition met,display2 if condition not met]</label>
I'm just not sure how to word the condition, based on whether random is on or off
Playlist.Random Returns string ID's 590 (Randomize Play Enabled) or 591 (Disabled)
So you need to this condition -
PHP Code:
StringCompare(Playlist.Random,$LOCALIZE(590))
Ok, as an example, here is the label for one of the tracks. To my understanding this should yield Artist: Title when random enabled and just Title when random disabled
<label>$IF[StringCompare(Playlist.Random,$LOCALIZE(590)),$INFO[MusicPlayer.offset(1).Artist]: $INFO[MusicPlayer.offset(1).Title], $INFO[MusicPlayer.offset(1).Title]]</label>
I tried it and it displayed the string compare bit ... as text.
Can you see anything wrong with the script?
There's no
$IF control in XBMC so I don't know where that's come from, you need to use the condition in a label control or variable control.
ie
PHP Code:
<control type="label">
<label>$INFO[MusicPlayer.offset(1).Artist]: $INFO[MusicPlayer.offset(1).Title], $INFO[MusicPlayer.offset(1).Title]</label>
<visible>StringCompare(Playlist.Random,$LOCALIZE(590))</visible>
</control>
or
PHP Code:
<label>$VAR[NowPlayingLabel]</label>
</control>
PHP Code:
<variable name="NowPlayingLabel">
<value condition="StringCompare(Playlist.Random,$LOCALIZE(590))">$INFO[MusicPlayer.offset(1).Artist]: $INFO[MusicPlayer.offset(1).Title], $INFO[MusicPlayer.offset(1).Title]</value>
<value>$INFO[MusicPlayer.offset(1).Title], $INFO[MusicPlayer.offset(1).Title]</value>
</variable>
Thanks Hitcher, I used the first code. The label was permanently invisible. I tried changing to 591 in case I was imagining it was random but no luck
Can you pastebin your complete code?
Try -
PHP Code:
<description>Track 1 title</description>
<visible>!IsEmpty(MusicPlayer.Offset(1).Title) + SubString(Playlist.Random,$LOCALIZE(590))</visible>
<posx>30</posx>
<posy>220</posy>
<height>30</height>
<width>800</width>
<label>[COLOR=lightblue]$INFO[MusicPlayer.offset(1).Artist]:[/COLOR] $INFO[MusicPlayer.offset(1).Title]</label>
<align>left</align>
<aligny>Top</aligny>
<font>font8</font>
<textcolor>bisque</textcolor>
<shadowcolor>black</shadowcolor>
<scroll>true</scroll>
</control>
<visible>!IsEmpty(MusicPlayer.Offset(1).Title) + SubString(Playlist.Random,$LOCALIZE(591))</visible>
<posx>30</posx>
<posy>220</posy>
<height>30</height>
<width>800</width>
<align>left</align>
<font>font8</font>
</control>
Didn't work
The title was not visible when random was on or off
Solved it!. I went to the list of Boolean conditions. The condition is : Playlist.IsRandom and the opposite being : !Playlist.IsRandom
