Full Version: Files disappear
Hi guys,
I´ve got a weird problem. I have 2 usb hard drives connected to my raspberry. Whenever i add files to the HDD using my computer, and the connect the HDD again to the raspberry, the file is nowhere to be found. It does not matter which HDD i use. I can not find the file i just copied.
Any ideas?
Well...found out what was causing this. I never chose "safely remove" in xbmc when disconnecting the HDD.
I decided to try "safely remove" and connected the HDD to my computer, copied the file and chose "safely remove".
Connected the HDD back to xbmc and VOILA! The files are in place and everything is working beautifully.
So, if you have usb connected HDD, please choose "safely remove" in xbmc so you don´t get corrupt or deleted files.
