Full Version: Prevent EventGhost from turning on monitor
Hi!
I'm using EventGhost to control XBMC with a Harmony Remote! EventGhost 0.4.1r1610 is running on an iMac (with Windows) to pick up the IR commands from the remote through the built-in IR reciever and then sending them to my HTPC in the same room. It works great, except for one little detail. I've configured it so that it turns off the screen of the computer when I start using the HTPC, but every time I press a button on the remote (and EventGhost forwards it to the HTPC) the screen of the computer turns on again. Is there any way to prevent this, either by some setting in EventGhost, a setting in Windows or a standalone program?
