2017-08-30, 01:44
2017-09-17, 18:34
[size=large]I am using a new porn database program called Porngornizer. But all metadata has to be entered by hand. Is there a way to integrate this scraper. His backend is an SQL database with a GUI. I know this is the wrong place for this qestion, but not sure where the correct one is.
2017-09-18, 00:14
@Rahanflig
Save the large text for the Visually Impaired.
Wouldn't have a clue. Not as if you provided any useful information like, say a link to the porngornizer.
2018-02-04, 03:52
ok so i downloaded from the link on the first page and i have the folder in my addons folder, when i start up kodi nothing installs that i see and when i go to make a new source, under movies theres no data18 scraper or whatever, please explain to me what to do, btw im not great with kodi
2018-02-04, 20:20
ive tried it again "install from zip" and it keeps saying install failed
2018-02-04, 20:35
@o0nightfire0o
Looks like the add-on has not been updated since July 2015.
The author hasn't been online since August 2015, so it is highly likely the author is no longer maintaining it.
2018-02-04, 20:48
i see, are there any other scrapers i could get like this one?
2018-02-04, 21:06
Just did a quick search, looks like these are still working, judging by the last posts...
https://forum.kodi.tv/showthread.php?tid=200788&page=9
and
https://forum.kodi.tv/showthread.php?tid=237760
and
2018-02-04, 21:39
ill give those a look, thanks so much for the help
2018-05-29, 16:03
i don't know how it work i can't add any scene to library how do you do it
2020-01-13, 02:47
(2013-05-22, 05:00)DoctorD Wrote: [ -> ]This scraper uses data18.com to pull in information for downloaded adult web videos from sites like Brazzers, Naughty America, etc. For the complete list of sites supported by this scraper, you can visit the list of sites and networks on data18.com. The scraper will also sometimes work with split scene files from an adult DVD movie if the information is in Data18. The data for split scenes on Data18 is only average, so there's no guarantee that your split scene will be there. This scraper is not intended for use in feature length adult movies that come out on DVDs. For that, use the other existing Data18 scraper or the AdultDVDEmpire or ExcaliburFilms scraper (available from the XBMC Adult 18+ Repository, see installation instructions below for more detail). For Japanese Adult Videos (JAV), check out my new standalone program I wrote: https://github.com/DoctorD1501/JAVMovieScraper/ . The standalone program also supports data18 movies and data18 web content now!
Hi, any plan to update the scraper to use the new source?
https://data18.empirestores.co/
Thanks in advance
