2013-05-22, 11:24
Hi Guys,
First time poster, that needs some help with Frodo. I am going to try explain this as best as I can, but the reason I am here, is due to the fact that I cannot figure out what key words I need to use to google this issue. I used to have the problem in Eden, but found a fix and got it removed. However with Frodo's menu's being so different, I dont know where to start.
So, for my issue.
I am using the Aeon Mq4 theme, and my movies are listed in the Showcase view. The first folder/movie/item that gets listed, is not a movie, its some form of menu icon/ place holder. Which I want to remove.
Same goes for my TV series which is in the banner view mode. The first item is also not a tv show, its some place holder with no image. These are the two things I need to disable/remove still and I have no clue how to do it.
Anyone got any ideas? Help would be much appreciated.
So, for my issue.
