2013-05-22, 23:42
Hello there,
I am using Frodo 12.2 on Ubuntu, and i have 2 questions.
When i reformat my computer there are two settings that i keep losing, which is a bit frustrating.
One is Movie Set Thumbnails. I have tried the following naming conventions for the Movie Set Thumbnail - folder.jpg, folder.tbn, foldername.tbn, foldername.jpg, moviesetname.tbn, moviesetname.jpg
But each time i update my movie library after a fresh install, my movie thumbnails are picked-up, but my Movie Set Thumbnails always default to one of the movie thumbnails, rather than the movie set one.
Any ideas on how to get XBMC to pick the right thumbnails for Movie Sets?
The second issue is Subtitle selection. I don't use any subtitle add-on. When in a movie, if i need a subtitle, i simply click on the Audio icon and select enable subtitle, then select the subtitle i want. When i leave the film and return to it, the settings are saved.
However, with a fresh install i have to go through and select the subtitle i want and enable it again.
I use nfo files for most of my movies, but there doesn't seem to be a setting for default subtitle, and for whether subtitles are enabled on a per movie basis.
So where does XBMC store this information? I have tried exporting a movie, but there is no entry for selected/default subtitle in the xml file. I have also checked advancedsettings.xml
Does anyone know where XBMC stores subtitle information and how i might export/import it so i don't have to start from scratch and do it manually on each install??
Many thanks in advance!
