Full Version: HTPC case with at least 4 hard disk bays
Going to build an HTPC for a friend..
and i am looking for an HTPC Case with the ability to house at least 4 hd (+ 1 ssd if possible)
I checked the Fractal Design node 304.. but if i can find something more htpc style - with included IR if possible - would be really great
Any suggestions?
With any more than 2 drives, you really have to begin watching the internal case temps. However, the following two cases are built specifically as a HTPC. They also can support the drives you're looking to install,...and actually even more.
I'd recommend the Silverstone Tek GD08B HTPC Case, or the Silverstone Tek GD07B HTPC Case.
Between the two,..I'd pick the GD08B,...just a personal preference. I always look at Silverstone cases first.
Both look really nice....and at the right price... (will show them to my friend) (will go for green hard disks in order to have low temps)
