2013-05-23, 08:37
Hi guys and gals
So i have a bit of a story before telling u my actual problem.
I was running FRODO just fine all was good. I purchased a Antec Media Station elite.
I did the xbmc on iMON thing tried many versions on both imon and xbmc on imon.
I however could never get it working to my satisfaction, so i went back to eden which has the http api and is supported natively by iMON. This works 100%
However since going back i have the following problem.
My TV Shows posters do not work.
I tell it to get thumb. It still lists the banners first, then the posters. I select the poster it takes about 15 seconds then the poster is blank in my menu.
I am using the standard confluence skin.
I have enabled Prefer Posters for tv shows
I have set Prefer Posters on the content
I have removed my profile and recreated.
I created a seperate profile to test
I have un-installed eden and re-installed ( 3 times )
I will post a copy of my log as soon as i am in front of that pc again, but in the interim if anybody has any other ideas i can try to get this issue sorted it would be great.
