I've followed all the guides and all my channels show up but when i press to switch to channel i get a Working symbol and than nothing? can someone please help
Do the channels work in NextPVR's front end?
If you can supply the xbmc.log (with debug logging enabled), and the web.log/nrecord.log files from the backend, I'll take a look.
figured it out
Thanks anyways
What did you do, I'm having the same problem
I am having problem also, Video seems to play fine on Npvr client, however it only shows working then switches to buffering and is stuck at 0% then crashes xbmc
