Full Version: Bugs and Suggestions
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
Always used to work for me. Now I can't change views and if I use another skin and choose a color setting, it goes away when I leave the skin and I have to do it again.
You on official frodo version?
Yep 12.2
Did a reformat and reinstall of Windows and XBMC and Bello still won't change view us movies. I don't get why because it's always worked before. I installed it from the repo.
(2013-11-28, 19:22)patseguin Wrote: [ -> ]Did a reformat and reinstall of Windows and XBMC and Bello still won't change view us movies. I don't get why because it's always worked before. I installed it from the repo.
i don't know...... but you could try to delete skin.bello and reinstall from git-hub.
Peppe
All the view types had a blue tick which it turns out was hiding then lol. Not sure why it happened, but I unmarked them all and now the view type work.
sorry but if i remember in settings we have "hide views". so if marked they vanish!
Peppe
You're 100% right. I don't know where my brain was. My bedroom PC did indeed have the same problem although I thought it didn't. Looking again at it now it says "hide views" and I had them all checked. It's surprising that Bello installs with all views disabled by default.
I did now a fresh install on my work pc just to try (no xbmc before). All views are not marked so all views are enabled.
Important is that you solved.
Peppe
Hello!
I looked all current XBMC skins and think Bello is the Best of All!!!
But I have one problem exactly with this skin... When I execute XBMC in secondary monitor and return to menu from fullscreen movie playback this results in background corruptions.
Windows 7 x64,
XBMC 12.2 (or 13 Alpha 9),
Primary monitor (1920x1200),
Seconday TV (1920x1080).
I have no problems when run on Primary monitor.
Please, Help! I really like this skin!
Seems like an issue with GPU drivers.
Thanks! I read some posts about XBMC graphics corruptions and found that if rollback to AMD Catalyst 12.4 (last video driver of 8 version) it works fine. Any further updates works with corruptions. I even tried last driver beta and it seems like AMD not going to solve the problem (if they knows). Or maybe it is not only driver's problem?
How about Latest Movies and Latest TV Shows on respective submenus on Home Screen?
Don't understand your question....but the related widget are under My Movies and My Tv Show.
Peppe
(2013-12-03, 09:28)peppe_sr Wrote: [ -> ]Don't understand your question....but the related widget are under My Movies and My Tv Show.
Peppe
That's exacly what I wanted, thanks. Is there a way to change the limit of 10 items?
