Full Version: Bugs and Suggestions
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
Hi!
First of all, congratulations nessus for your work. This skin is awesome!
I love your work, and I'm very impressed with the new "Netflix" view, but I've got a little suggestion: could you put some kind of separator at the end of the row of images (as actual Netflix has). It would be specialy usefull for the series episodes... it's a bit odd with the cycling of the images not to know when it ends and when it starts again.
Sorry for my english!
Again, great work!!!
&Y
Hello.
I've got a problem with bello skin (3.0.6) on openelec latest version (5.0.7) / kodi 14.2 (raspberry pi)
all is ok with confluence skin.
When i switch to bello, i can't go to main menu (with film / video / music / image link)
Error displayed in GUI is : can't go to main menu error is : skin shortcuts unable to build menu
i've look in the kodi.log and found this
20:48:48 T:1559360576   ERROR: Traceback (most recent call last):
20:48:48 T:1559360576   ERROR:   File "/storage/.kodi/addons/script.skinshortcuts/resources/lib/xmlfunctions.py", line 87, in buildMenu
20:48:49 T:1559360576   ERROR:     self.writexml( profilelist, mainmenuID, groups, numLevels, buildMode, progress, options )
20:48:49 T:1559360576   ERROR:   File "/storage/.kodi/addons/script.skinshortcuts/resources/lib/xmlfunctions.py", line 340, in writexml
20:48:49 T:1559360576   ERROR:     for node in DATA._get_shortcuts( "mainmenu", None, True, profile[0] ).findall( "shortcut" ):
20:48:49 T:1559360576   ERROR:   File "/storage/.kodi/addons/script.skinshortcuts/resources/lib/datafunctions.py", line 150, in _get_shortcuts
20:48:49 T:1559360576   ERROR:     tree = xmltree.parse( path )
20:48:49 T:1559360576   ERROR:   File "/home/stephan/projects/openelec-5.0/build.OpenELEC-RPi.arm-5.0.7/Python-2.7.3/.install_pkg/usr/lib/python2.7/xml/etree/ElementTree.py", line 1183, in parse
20:48:49 T:1559360576   ERROR:   File "/home/stephan/projects/openelec-5.0/build.OpenELEC-RPi.arm-5.0.7/Python-2.7.3/.install_pkg/usr/lib/python2.7/xml/etree/ElementTree.py", line 657, in parse
20:48:49 T:1559360576   ERROR:   File "/home/stephan/projects/openelec-5.0/build.OpenELEC-RPi.arm-5.0.7/Python-2.7.3/.install_pkg/usr/lib/python2.7/xml/etree/ElementTree.py", line 1655, in close
20:48:49 T:1559360576   ERROR:   File "/home/stephan/projects/openelec-5.0/build.OpenELEC-RPi.arm-5.0.7/Python-2.7.3/.install_pkg/usr/lib/python2.7/xml/etree/ElementTree.py", line 1507, in _raiseerror
20:48:49 T:1559360576   ERROR: ParseError: no element found: line 1, column 0
previous version of bello work fine, it's only since the new 3.0.6 version that i've got this error.
if i restart my raspberry pi, bello is starting in "film" menu, so i can select a video and watch a film, but if i go back to main menu, the same error occured and i can't do nothing.
i have tried to uninstall bello, and install again without success.
Any help would be appreciate. I can stay on confluence but bello is better (thanks Nessus!).
FYI : i don't succeed to solve my problem, until I re-install from scratch my openelec system. Now all is ok.
I just noticed that in the Netflix view the Page Up and Page Down do not work as expected.
In every other view it scrolls a page up or down but the Netflix view seems to skip multiple pages at once.
Running Isengard beta 2 and all video have text in the middle "Channel Group" with two arrows. How do I make that go away?
(2015-06-19, 03:28)patseguin Wrote: [ -> ]Running Isengard beta 2 and all video have text in the middle "Channel Group" with two arrows. How do I make that go away?
http://forum.kodi.tv/showthread.php?tid=218791
(2015-06-19, 08:22)sualfred Wrote: [ -> ]
Thank you! So, I inly remove the words he highlighted in red?
No, the complete quoted part.
new bug on Bello 6
when i stop the video and the number of episode missing & when i hit the enter button it won't start resuming.
so i must back to choose season and choose the season again and the episode can be resuming again
it is working for me using my local library.
Peppe
How to enable Trakt in the Trailer Section of Bello 6? Normal Trakt Addon is enabled and set to my account...
(2017-05-12, 22:25)skinner99 Wrote: [ -> ]How to enable Trakt in the Trailer Section of Bello 6? Normal Trakt Addon is enabled and set to my account...
I was wondering the same thing.
The trakt lists in Trailers window are provided by the ExtendedInfo script. If they are not working disable them from the options menu (press left all the way) or ask for this in the ExtendedInfo addon thread.
Cheers
Nessus
(2017-05-13, 01:17)nessus Wrote: [ -> ]The trakt lists in Trailers window are provided by the ExtendedInfo script. If they are not working disable them from the options menu (press left all the way) or ask for this in the ExtendedInfo addon thread.
Cheers
Nessus
That did it, thank you sir!
I cant see all the media views even though theyre all rnabled in settings
