2017-05-13, 08:35
2017-05-13, 10:29
(2017-05-13, 06:41)tpattison Wrote: [ -> ]That did it, thank you sir!
What exactly did it? Did you disable them via left options?
I want them working, not disabling them...
Gesendet von iPad mit Tapatalk
2017-05-13, 10:48
@ThatGuy93
are you using library or file mode?
@AbsurdBrian
wich version of the script are you using? i have the 5.6.0 with no errors
@skinner99
you have to ask in the extendedInfo script thread it is not skin related. the skin use the script.
@AbsurdBrian
@skinner99
2017-05-13, 16:16
@peepe_sr
I made sure it was up to date at 5.6.0. Even when I tried clearing that specific script cache it gave me the same error.
At home screen I went up to the the top power option and attempted to reload the skin. My screen went blank and I had to exit out and force stop Kodi. I'm on the 2nd gen Fire Stick btw
2017-05-13, 16:54
(2017-05-13, 10:48)peppe_sr Wrote: [ -> ]you have to ask in the extendedInfo script thread it is not skin related. the skin use the script.
Ok. I see, but thats really funny. I quote from the script thread:
Quote:Support for ExtendedInfo Script (for skinners only, no end-user support. please ask in the corresponding skin threads)
But anyways, i will give it a try.
2017-05-13, 21:24
@ThatGuy93
so you are using file mode. just tested, it so also for me.
@AbsurdBrian
i can test only windows, have only android box not compatible with krypton and never used a fire stick, maybe someone else will help you.
@skinner99
well done, IIRC it was an already known issue.
@AbsurdBrian
@skinner99
2017-05-14, 23:07
2017-05-15, 04:58
Ran into a bug. Installed Superfavorites, made a folder. Linked the folder as a main menu item. SF folder opens fine, but after pressing back to get back to the home, Kodi crashes everytime. I do see the errors in he Kodi log. Hopefully you can sort out this bug, thanks!
Skin has invalid include: skinshortcuts-template-widget
Error getting return
Heres the log: http://jed.one/777Other%20stuff/kodibello.log
2017-05-15, 13:49
(2017-05-15, 04:58)jdig4240 Wrote: [ -> ]Ran into a bug. Installed Superfavorites, made a folder. Linked the folder as a main menu item. SF folder opens fine, but after pressing back to get back to the home, Kodi crashes everytime. I do see the errors in he Kodi log. Hopefully you can sort out this bug, thanks!
Ok, after more trial and error, I find that this happens in Bello view, and is fine in List view
2017-05-16, 17:08
Another bug, you cannot exit the Kodi PVR guide when its set to guide. Only way is to set to channels, then it allows you to exit.
2017-05-16, 17:11
are you sure? esc button on my keyboard is working well!
2017-05-16, 20:43
(2017-05-16, 17:11)peppe_sr Wrote: [ -> ]are you sure? esc button on my keyboard is working well!
Maybe so, but most tv boxes dont have an escape button on the remote.
2017-05-17, 07:32
ah, so you are using the back button!
you have to map on your remote or "esc" button or "e".
with "e" you can activate/deactivate the tvguide window.
search in the official repo the, in programs addons the "ketmap editor"
Peppe
Peppe
2017-05-17, 17:01
(2017-05-17, 07:32)peppe_sr Wrote: [ -> ]ah, so you are using the back button!
Peppe
Well thats a workaround, but the back button on any skin Ive ever tried always goes back, or brings you back to Home.
2017-05-22, 17:19
FILMS LIBRARY.
Is possible to add info metadata in "list" view (720p - 1080p - H.265 - h.264, ecc......), as in "Bello" view?
