Hi, I currently have the first Raspberry pi model B with 256mb of ram running openelec raspberry or whatever and the menu is choppy. I was wondering if upgrading to the 512mb PI would be better with the menu's? i really want to run Aeon Nox theme and not have it be choppy. Can the 512mb PI run Aeon Nox smoothly even if i overclock it or should i look for a more powerful machine if i want to run more complex themes?
Nope. Aeon Nox, even with most of the options turned off, is a bit of a dead end for the Raspberry Pi. Even overclocked, it's just too much for it.
You should look for a more powerful machine if you want to run the more heavy skins. I'd suggest a miniITX based system using an Intel Celeron processor. With sales, you can build a really nice and Aeon-friendly machine for $100 USD.
You could try the Ace skin, it is by the same author as Aeon Nox, but a lot lighter. Very nice even though it is so much lighter.
Revo 3700's make very nice XBMC machines capable of running Aeon-type skins- you can find them on ebay for under £100.
(2013-05-25, 07:49)rikardo1979 Wrote: [ -> ]you may be interested
http://www.thelittleblackbox.nl/en/
Based on a Cortex-A9 + Mali 400 and 1GB RAM for €100, even that might struggle running the heavier weight skins.
(2013-05-25, 07:55)MilhouseVH Wrote: [ -> ] (2013-05-25, 07:49)rikardo1979 Wrote: [ -> ]you may be interested
which platform does it run on?
HD-audio possible?
Would this be enough for bd25?
(2013-05-25, 07:09)MilhouseVH Wrote: [ -> ]Revo 3700's make very nice XBMC machines capable of running Aeon-type skins- you can find them on ebay for under £100.
dont know these... link?
(2013-05-25, 08:01)Skank Wrote: [ -> ]which platform does it run on?
HD-audio possible?
Buy one and let us know.
(2013-05-25, 08:01)Skank Wrote: [ -> ] (2013-05-25, 07:09)MilhouseVH Wrote: [ -> ]Revo 3700's make very nice XBMC machines capable of running Aeon-type skins- you can find them on ebay for under £100.
http://www.ebay.co.uk/ - type "revo 3700" in to the search box and press return on your keyboard.
I would like to get full specs first
cant find anything on that, on their website
(2013-05-25, 08:05)Skank Wrote: [ -> ]I would like to get full specs first
Click "Shop". Click "More Info". Click "Additional Information".
aha! Thx mate
How is this mali400 gpu and
ARM Cortex A9?
(2013-05-25, 05:42)Ned Scott Wrote: [ -> ]Nope. Aeon Nox, even with most of the options turned off, is a bit of a dead end for the Raspberry Pi. Even overclocked, it's just too much for it.
Thanks for your input ill check out the minilTX system
