2014-07-27, 21:18
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128
2014-07-27, 22:11
Sorted, sorry
2014-07-29, 05:34
Hi All,
Thanks to fritsch and everybody for their hard work.
Big thanks to this thread and ppa:wsnipex/xbmc-fernetmenta-master for improving my PVR experience on Intel NUC D54250WYK
Did not realize how poor the deinterlacing was until after I bought it. Fortunately I found this thread!!.
Using TVHeadend for PVR. vaapi-sse4 for deinterlacing SD of PVR.
Currently I am running xbmc-fernetmenta-master from 30 Jun 2014 or 09 Jul 2014.
They seem to work OK but occasionally there are glitches.... to be expected with Alpha software.
My Question:
Which is the best build to run that incorporates the vaapi-sse4 changes for my PVR usage but does NOT use Helix requirements for the PVR menus yet?
I am running Aeon-Nox skin and with any build past 9 Jul 2014 of xbmc-fernetmenta-master, PVR menus are missing as they need to be in Helix format not Gotham.
Ideally.... I would like Gotham but with vaapi-sse4 changes for my PVR deinterlacing.
Any suggestions?
Thank You
My Question:
Any suggestions?
Thank You
2014-07-29, 06:16
What about openelec?
2014-07-29, 06:31
(2014-07-29, 06:16)-DDD- Wrote: [ -> ]What about openelec?
Thanks for the suggestion. I find the lack of fstab etc and not being able to build eg: tvheadend clients from git etc on openelec quite constrictive.
Including running my backup scripts for nightly thumbnail cleanup and thumbnail preloading/populating etc and backing up to my nas.
Things I do as standard from Ubuntu.
How far away is Openelec from Standard Ubuntu?
Am reading up on it now....
2014-07-29, 10:42
(2014-07-27, 20:23)FernetMenta Wrote: [ -> ]What exactly do I have to look for. Both samples play fine and I can't tell any difference. Tried on i5-4570T Linux, sw multi-threaded decoding and on i7 Windows.
The i5 is approximately at 50% CPU playing the 4:2:2 sample with yadif.
Look at the motion of fast moving elements with high-saturation chroma and relatively low luminance - the blue light beams on the wide shots, the foreground audience in the fast tracking shots etc.
The 4:2:0 clip has full 50Hz motion on these elements, the 4:2:2 clip appears to have some odd 25Hz motion artefacts on them, yet other areas of the picture are fine with 50Hz motion (i.e. it isn't a case that the sequence isn't being de-interlaced).
I'm wondering if there is some difference in the way 4:2:2 and 4:2:0 is handled, particularly in chroma terms? It's really odd. I'm running an i7-2600K with Intel drivers.
2014-07-29, 12:59
Could you be more specific on what to look at? Time, region of the screen for example.
I can't find anything in the code which would point in this direction. The only difference between 4:2:2 and 4:2.0 is that 4:2:2 has twice as much chroma samples.
Quote:I'm wondering if there is some difference in the way 4:2:2 and 4:2:0 is handled
2014-07-29, 13:39
(2014-07-29, 12:59)FernetMenta Wrote: [ -> ]Could you be more specific on what to look at? Time, region of the screen for example.
Will try and post times and screen grabs. Not near PC at the moment - probably later this evening.
2014-07-29, 20:27
Have sent PM with links to screen caps and timings.
Checked on two Intel machines. i7-2600K running Ubuntu and the fernetmenta build (temporarily compiled with YADIF not W3FDIF!) and an i5-4250U NUC running OpenElec 4.0.6
2014-08-02, 22:50
I just noticed mjpeg videos stopped working, and the thumbnail picture is kinda decolored, from what my kids told me they stopped working like 20-25 days ago. audio comes out fine, but screen gets jumpy with no video at all.
I just have this XBMC build installed, cant test with regular builds.
i get this error in xbmc.log
ERROR: CDVDVideoCodecFFmpeg::FilterOpen - avfilter_graph_create_filter: src
would debug enable show deeper error logs ?
Juanjo
Juanjo
2014-08-03, 09:10
I hope so - try to upload those.
Edit: Fernet won't reply for the next 10 days - he currently is a long distance away from keyboard - it's summer.
2014-08-05, 01:28
ok, i did more testing, some of the files do work.. but i havent found any logic, headers seem the same in both playing and non-playing files.. im posting longs
xbmc.log http://paste.ubuntu.com/7956283/
vainfo http://paste.ubuntu.com/7956289/
mesa dpkg http://paste.ubuntu.com/7956296/
id http://paste.ubuntu.com/7956297/
aplay http://paste.ubuntu.com/7956298/
i will try to figure out why some files work and some does not
2014-08-05, 08:50
Quote:20:06:27 T:140663552837376 INFO: ffmpeg[C9198700]: [mpeg4] Video uses a non-standard and wasteful way to store B-frames ('packed B-frames'). Consider using a tool like VirtualDub or avidemux to fix it.
20:06:27 T:140662612207360 INFO: CDVDAudioCodecFFmpeg::GetChannelMap - FFmpeg reported 1 channels, but the layout contains 0 ignoring
20:06:27 T:140662612207360 NOTICE: Creating audio stream (codec id: 65541, channels: 1, sample rate: 11024, no pass-through)
20:06:27 T:140662612207360 DEBUG: CDVDPlayerAudio:: synctype set to 1: skip/duplicate
20:06:27 T:140663552837376 DEBUG: CDVDPlayerVideo - CDVDMsg::GENERAL_RESYNC(66666.000000, 0)
20:06:27 T:140663552837376 DEBUG: CDVDPlayerVideo::CalcDropRequirement - hurry: 0
20:06:27 T:140663552837376 DEBUG: ffmpeg[C9198700]: [src] w:240 h:320 pixfmt:yuv420p tb:4368/65535 fr:0/1 sar:1/1 sws_param:
20:06:27 T:140664365950912 DEBUG: CGUIInfoManager::SetCurrentMovie(/storage/filmaciones/2005-01-23 13.56.04.AVI)
20:06:27 T:140663552837376 NOTICE: fps: 15.000150, pwidth: 240, pheight: 320, dwidth: 240, dheight: 320
20:06:27 T:140663552837376 DEBUG: OutputPicture - change configuration. 240x320. framerate: 15.00. format: YV12
20:06:27 T:140663552837376 DEBUG: Resolution 1920x1080 (16) not a very good match for fps 15.000 (weight: 1.000), trying 2:3 cadence
20:06:27 T:140663552837376 DEBUG: Resolution 1920x1080 (16) not a very good match for fps 15.000 with 2:3 cadence (weight: 1.000), choosing 60 hertz
20:06:27 T:140663552837376 DEBUG: 60 hertz refreshrate not available, choosing highest
320x240 @ 15 fps?
I am quite sure those files won't work with any other xbmc version, too - please provide a sample.
2014-08-05, 10:12
Seems intel has "fixed" - better to say workarounded - one of the hangs we are seeing: https://bugs.freedesktop.org/show_bug.cgi?id=81447
Please someone that is able to build libva-driver-intel from source could verify this with the sample posted in the above bug.
2014-08-05, 12:25
(2014-08-05, 08:50)fritsch Wrote: [ -> ]Quote:20:06:27 T:140663552837376 INFO: ffmpeg[C9198700]: [mpeg4] Video uses a non-standard and wasteful way to store B-frames ('packed B-frames'). Consider using a tool like VirtualDub or avidemux to fix it.
320x240 @ 15 fps?
ah yes, lol, i said it was an old camera . they all used to play fine in the past, but i dont have any backups of anything older than trusty to test.
https://dl.dropboxusercontent.com/u/2086....42.58.AVI is one that does not play
anyways, if the info doesnt help or its not a minor glitch (aka too hard to fix) dont worry too much
thanks a lot
Juanjo
