Full Version: VAAPI: Nuc, Chromebox, HSW, IVB, Baytrail with Ubuntu 14.04
Nice. thanks for this detailled report. Flushing renderer / decoder on fullscreen change should help here.
Thanks for testing and getting the backtrace. Upstream PR is here: https://github.com/xbmc/xbmc/pull/2460 - we hope, that it can go into mainline within the next time.
Glad I could help!
With next time you mean 12.4 ?
EDIT: can I try to apply the 3 commits directly on the latest frodo ? Or is it to be applied on main ?
That said, can I use https://github.com/BtbN/xbmc/commits/vaa...nterlacing to try ?
Indeed, no crash on latest main with the vaap-vpp patch..
EDIT:
I spoke too quickly...
No crash when pressing \, but random crash in window mode when launching a video. Will edit with debug.
#0  0x00007fffe44dd2ae in ?? () from /usr/lib/x86_64-linux-gnu/dri/i965_dri.so
#1  0x00007fffe44d3220 in ?? () from /usr/lib/x86_64-linux-gnu/dri/i965_dri.so
#2  0x00007fffe44bd5a0 in ?? () from /usr/lib/x86_64-linux-gnu/dri/i965_dri.so
#3  0x00007fffe44ab047 in ?? () from /usr/lib/x86_64-linux-gnu/dri/i965_dri.so
#4  0x00007fffe45c9e83 in ?? () from /usr/lib/x86_64-linux-gnu/dri/i965_dri.so
#5  0x00007fffe4655008 in ?? () from /usr/lib/x86_64-linux-gnu/dri/i965_dri.so
#6  0x00000000010a4264 in ClearBuffers (color=<optimized out>, this=<optimized out>) at RenderSystemGL.cpp:275
#7  CRenderSystemGL::ClearBuffers (this=<optimized out>, color=<optimized out>) at RenderSystemGL.cpp:262
#8  0x000000000080028e in CGUIWindowManager::RenderPass (this=this@entry=0x1696840) at GUIWindowManager.cpp:533
#9  0x0000000000800583 in CGUIWindowManager::Render (this=0x1696840) at GUIWindowManager.cpp:578
#10 0x0000000000ba8b86 in CApplication::RenderNoPresent (this=<optimized out>) at Application.cpp:2014
#11 0x0000000000ba9071 in CApplication::Render (this=0x1691930) at Application.cpp:2104
#12 0x0000000000c33801 in CXBApplicationEx::Run (this=0x1691930) at XBApplicationEx.cpp:175
#13 0x0000000000709f17 in XBMC_Run (renderGUI=true) at xbmc.cpp:69
#14 0x00000000006c8b8b in main (argc=1, argv=0x7fffffffeae8) at main.cpp:76
Another bug while running SD after an HD. It is on the btbn vaapi mainstream branch :\
libva info: VA-API version 0.34.0
libva info: va_getDriverName() returns 0
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/i965_drv_video.so
libva info: Found init function __vaDriverInit_0_34
libva info: va_openDriver() returns 0
[New Thread 0x7fff6affd700 (LWP 2470)]
xbmc.bin: i965_drv_video.c:2013: i965_EndPicture: Assertion `obj_context->codec_state.decode.pic_param' failed.
Program received signal SIGABRT, Aborted.
[Switching to Thread 0x7fff69ffb700 (LWP 2467)]
0x00007fffef328295 in raise () from /lib/x86_64-linux-gnu/libc.so.6
(gdb) bt
#0  0x00007fffef328295 in raise () from /lib/x86_64-linux-gnu/libc.so.6
#1  0x00007fffef32b438 in abort () from /lib/x86_64-linux-gnu/libc.so.6
#2  0x00007fffef321322 in ?? () from /lib/x86_64-linux-gnu/libc.so.6
#3  0x00007fffef3213d2 in __assert_fail () from /lib/x86_64-linux-gnu/libc.so.6
#4  0x00007fff694f8baf in ?? () from /usr/lib/x86_64-linux-gnu/dri/i965_drv_video.so
#5  0x00007ffff7bcb763 in vaEndPicture () from /usr/lib/x86_64-linux-gnu/libva.so.1
#6  0x00007fff73694174 in ff_vaapi_render_picture (vactx=vactx@entry=0x7fff60000b00, surface=67108864) at libavcodec/vaapi.c:77
#7  0x00007fff73694657 in ff_vaapi_mpeg_end_frame (avctx=0x7fff6c0f4a60) at libavcodec/vaapi.c:209
#8  0x00007fff735bbccf in slice_end (pict=0x7fff6c0f4ec0, avctx=0x7fff6c0f4a60) at libavcodec/mpeg12.c:1966
#9  decode_chunks (avctx=avctx@entry=0x7fff6c0f4a60, picture=picture@entry=0x7fff6c0f4ec0, got_output=got_output@entry=0x7fff69ffaa4c, buf=0x7fff78006b10 "", buf_size=13937) at libavcodec/mpeg12.c:2295
#10 0x00007fff735bd6c4 in mpeg_decode_frame (avctx=0x7fff6c0f4a60, data=0x7fff6c0f4ec0, got_output=0x7fff69ffaa4c, avpkt=<optimized out>) at libavcodec/mpeg12.c:2600
#11 0x00007fff7368e799 in avcodec_decode_video2 (avctx=0x7fff6c0f4a60, picture=0x7fff6c0f4ec0, got_picture_ptr=0x7fff69ffaa4c, avpkt=0x7fff69ffaa70) at libavcodec/utils.c:1690
#12 0x000000000089412f in avcodec_decode_video2 (p4=0x7fff69ffaa60, p3=0x7fff69ffaa3c, p2=<optimized out>, p1=<optimized out>, this=0x7fff6c06b980) at /home/src/xbmc/btbn/xbmc/lib/DllAvCodec.h:205
#13 CDVDVideoCodecFFmpeg::Decode (this=0x7fff6c06b920, pData=0x7fff78006b10 "", iSize=13937, dts=78674788956, pts=<optimized out>) at DVDVideoCodecFFmpeg.cpp:453
#14 0x0000000000eaf53e in CDVDPlayerVideo::Process (this=0x53d44b8) at DVDPlayerVideo.cpp:552
#15 0x00000000010dadc0 in CThread::Action (this=0x53d44b8) at Thread.cpp:218
#16 0x00000000010db072 in CThread::staticThread (data=0x53d44b8) at Thread.cpp:128
#17 0x00007ffff4b46e0e in start_thread () from /lib/x86_64-linux-gnu/libpthread.so.0
#18 0x00007fffef3db95d in clone () from /lib/x86_64-linux-gnu/libc.so.6
EDIT: it happens also when decoding for the first time
Latest mainline (xbmc master branch) is broken for mpeg-2 via VAAPI - which is an MPEG-2/ffmpeg problem.
That is also the reason i made the frodo-vpp branch to be able to test the implementation without running into mpeg-2 problems - that are ffmpeg introduced.
Bugreport here: https://ffmpeg.org/trac/ffmpeg/ticket/2461
PS: Compare your stacktrace and the one in the bugreport :-) ffmpeg 1.3 is a sad thing for vaapi, as this mpeg-2 is standard LiveTV stream for SD channels.
I tried vaapi-vpp-deinterlacing-frodo branch from btbn github and the bugs disappeared ...
\ is now working and I did not expercienced a playback crash.
Strange isnt it ?
EDIT: i have a crash but only if I press \ to go from FS to Window mode, while doing a playback...
Region for name 16 already exists but is not compatible
It is not strange. Btbn's frodo branch with vpp is highly different from the one in the ppa, both share of course btbn's vpp work.
Hello,
unfortunately i'm having a lot of drops in LiveTV with vpp-deinterlacing enabled on my system.
I'm using a Celeron 847 with HD2000 on quantal xbmcbuntu (32Bit) with 3.7.0-7 kernel.
I added this ppa additionally to xorg-edgers ppa, disabled XBMC-main ppa and ran apt-get update/upgrade to update to the vpp drivers and xbmc.
All settings from first post applied.
My codec info looks like that :
my xbmc.log with debug enabled:
18:10:45 T:3038050048   DEBUG: OnKey: down (f081) pressed, action is ChannelDown
18:10:45 T:2511338304   DEBUG: CSoftAEStream::Flush
18:10:45 T:2571168576   DEBUG: CDVDPlayerVideo - CDVDMsg::GENERAL_SYNCHRONIZE
18:10:45 T:2511338304   DEBUG: CDVDPlayerAudio - CDVDMsg::GENERAL_SYNCHRONIZE
18:10:45 T:2781215552   DEBUG: CDVDPlayer::SetCaching - caching state 3
18:10:45 T:2781215552   DEBUG: PVRManager - PerformChannelSwitch - switching to channel 'glitz* HD'
18:10:45 T:2781215552   DEBUG: PVR - SaveCurrentChannelSettings - no custom channel settings for channel 'Syfy HD'
18:10:45 T:2781215552    INFO: AddOnLog: Tvheadend HTSP Client: SwitchChannel - changing to channel 'glitz* HD'
18:10:45 T:2781215552    INFO: AddOnLog: Tvheadend HTSP Client: SendUnsubscribe - unsubscribe from subscription 2
18:10:45 T:2781215552    INFO: AddOnLog: Tvheadend HTSP Client: SendSubscribe - subscribe to channel '114', subscription 3
18:10:45 T:2970651456   DEBUG: CSoftAE::Run - Sink restart flagged
18:10:45 T:2970651456    INFO: CSoftAE::InternalOpenSink - RAW passthrough enabled
18:10:45 T:2970651456    INFO: CSoftAE::InternalOpenSink - keeping old sink with : AE_FMT_AC3, FL,FR, 48000hz
18:10:45 T:2970651456   DEBUG: CSoftAE::InternalOpenSink - Internal Buffer Size: 9600
18:10:45 T:2781215552   DEBUG: AddOnLog: Tvheadend HTSP Client: SendSubscribe - new subscription for channel 115 (3)
18:10:45 T:2781215552  NOTICE: PVRManager - PerformChannelSwitch - switched to channel 'glitz* HD'
18:10:45 T:2781215552  NOTICE: Creating Demuxer
18:10:45 T:2781215552  NOTICE: Closing video stream
18:10:45 T:2781215552   DEBUG: CDVDPlayer::SetCaching - caching state 0
18:10:45 T:2781215552  NOTICE: waiting for video thread to exit
18:10:45 T:2571168576   ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true
18:10:45 T:2571168576  NOTICE: thread end: video_thread
18:10:45 T:2571168576   DEBUG: Thread CDVDPlayerVideo 2571168576 terminating
18:10:45 T:2700073792   DEBUG: CAnnouncementManager - Announcement: OnStop from xbmc
18:10:45 T:2700073792   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnStop
18:10:45 T:2700073792   DEBUG: CAnnouncementManager - Announcement: OnPlay from xbmc
18:10:45 T:2700073792   DEBUG: GOT ANNOUNCEMENT, type: 1, from xbmc, message OnPlay
18:10:45 T:2700073792   DEBUG: Building didl for object 'pvr://channels/tv/Alle TV-Kanäle/63.pvr'
18:10:45 T:2781215552  NOTICE: deleting video codec
18:10:45 T:2539088704   DEBUG: VAAPI - VPP thread on exit
18:10:45 T:2539088704   DEBUG: Thread VAAPI VPP Thread 2539088704 terminating
18:10:45 T:2781215552   DEBUG: VAAPI_VPP - Deinitializing
18:10:45 T:2781215552   DEBUG: VAAPI - destroying surface 0x4000016
18:10:45 T:2781215552   DEBUG: VAAPI - destroying surface 0x4000015
18:10:45 T:2781215552   DEBUG: VAAPI - destroying surface 0x4000014
18:10:45 T:2781215552   DEBUG: VAAPI - destroying surface 0x4000012
18:10:45 T:2781215552   DEBUG: VAAPI - destroying surface 0x4000011
18:10:45 T:2781215552   DEBUG: VAAPI - destroying surface 0x4000002
18:10:45 T:2781215552   DEBUG: VAAPI - destroying surface 0x400000d
18:10:45 T:2781215552   DEBUG: VAAPI_VPP - Deinitialized bob
18:10:45 T:2781215552   DEBUG: VAAPI_VPP - Deinitialized vpp
18:10:45 T:2781215552   DEBUG: VAAPI - destroying surface 0x4000003
18:10:45 T:2781215552   DEBUG: VAAPI - destroying surface 0x4000000
18:10:45 T:2781215552   DEBUG: VAAPI - destroying surface 0x400000e
18:10:45 T:2781215552   DEBUG: VAAPI - destroying surface 0x400000c
18:10:45 T:2781215552   DEBUG: VAAPI - destroying surface 0x4000006
18:10:45 T:2781215552   DEBUG: VAAPI - destroying surface 0x4000004
18:10:45 T:2781215552   DEBUG: VAAPI - destroying surface 0x4000009
18:10:45 T:2781215552   DEBUG: VAAPI - destroying surface 0x4000007
18:10:45 T:2781215552   DEBUG: VAAPI - destroying surface 0x400000a
18:10:45 T:2781215552   DEBUG: VAAPI - destroying surface 0x400000b
18:10:45 T:2781215552   DEBUG: VAAPI - destroying surface 0x4000001
18:10:45 T:2781215552   DEBUG: VAAPI - destroying surface 0x4000005
18:10:45 T:2781215552  NOTICE: Closing audio stream
18:10:45 T:2781215552  NOTICE: CDVDMessageQueue(audio)::WaitUntilEmpty
18:10:45 T:2511338304   DEBUG: CDVDPlayerAudio::Process - Abort received, exiting thread
18:10:45 T:2511338304  NOTICE: thread end: CDVDPlayerAudio::OnExit()
18:10:45 T:2511338304   DEBUG: Thread CDVDPlayerAudio 2511338304 terminating
18:10:45 T:2781215552  NOTICE: Waiting for audio thread to exit
18:10:45 T:2781215552  NOTICE: Closing audio device
18:10:45 T:2781215552   DEBUG: CSoftAEStream::~CSoftAEStream - Destructed
18:10:45 T:2781215552  NOTICE: Deleting audio codec
18:10:45 T:2781215552   DEBUG: CDVDPlayer::SetCaching - caching state 2
18:10:45 T:2781215552 WARNING: CDVDMessageQueue(audio)::Put MSGQ_NOT_INITIALIZED
18:10:45 T:2781215552 WARNING: CDVDMessageQueue(video)::Put MSGQ_NOT_INITIALIZED
18:10:45 T:2781215552   DEBUG: CGUIInfoManager::SetCurrentMovie(pvr://channels/tv/Alle TV-Kanäle/62.pvr)
18:10:45 T:2970651456    INFO: CSoftAE::InternalOpenSink - sink incompatible, re-starting
18:10:45 T:2970651456    INFO: CAESinkALSA::Initialize - Attempting to open device "hdmi:CARD=PCH,DEV=0"
18:10:45 T:2970651456    INFO: CAESinkALSA::Initialize - Opened device "hdmi:CARD=PCH,DEV=0,AES0=0x04,AES1=0x82,AES2=0x00,AES3=0x00"
18:10:45 T:2970651456    INFO: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
18:10:45 T:2970651456    INFO: CAESinkALSA::InitializeHW - Using data format AE_FMT_S32NE
18:10:45 T:2970651456   DEBUG: CAESinkALSA::InitializeHW - Request: periodSize 2048, bufferSize 8192
18:10:45 T:2970651456   DEBUG: CAESinkALSA::InitializeHW - Got: periodSize 2048, bufferSize 8192
18:10:45 T:2970651456   DEBUG: CAESinkALSA::InitializeHW - Setting timeout to 186 ms
18:10:45 T:2970651456   DEBUG: CSoftAE::InternalOpenSink - ALSA Initialized:
18:10:45 T:2970651456   DEBUG:   Output Device : HDA Intel PCH
18:10:45 T:2970651456   DEBUG:   Sample Rate   : 44100
18:10:45 T:2970651456   DEBUG:   Sample Format : AE_FMT_S32NE
18:10:45 T:2970651456   DEBUG:   Channel Count : 2
18:10:45 T:2970651456   DEBUG:   Channel Layout: FL,FR
18:10:45 T:2970651456   DEBUG:   Frames        : 2048
18:10:45 T:2970651456   DEBUG:   Frame Samples : 4096
18:10:45 T:2970651456   DEBUG:   Frame Size    : 8
18:10:45 T:2970651456   DEBUG: CSoftAE::InternalOpenSink - Using speaker layout: 5.1
18:10:45 T:2970651456   DEBUG: CSoftAE::InternalOpenSink - Internal Buffer Size: 16384
18:10:46 T:2716859200   DEBUG: AddOnLog: Tvheadend HTSP Client: ParseSubscriptionStart - id: 1, type: H264
18:10:46 T:2716859200   DEBUG: AddOnLog: Tvheadend HTSP Client: ParseSubscriptionStart - id: 2, type: AC3
18:10:46 T:2716859200   DEBUG: AddOnLog: Tvheadend HTSP Client: ParseSubscriptionStart - id: 3, type: AC3
18:10:46 T:2716859200   DEBUG: AddOnLog: Tvheadend HTSP Client: ParseSubscriptionStart - id: 4, type: CA
18:10:46 T:2716859200   DEBUG: AddOnLog: Tvheadend HTSP Client: ParseSubscriptionStart - id: 5, type: CA
18:10:46 T:2716859200   DEBUG: AddOnLog: Tvheadend HTSP Client: ParseSubscriptionStart - id: 6, type: CA
18:10:46 T:2716859200    INFO: AddOnLog: Tvheadend HTSP Client: ParseSubscriptionStart - subscription started on adapter STV0367 DVB-C DVB-T, mux Kabel Deutschland: 434,000 kHz, network Kabel Deutschland, provider KD Home, service glitz* HD
18:10:46 T:2781215552   DEBUG: CDVDDemuxPVRClient::RequestStreams(): added/updated stream 0:1 with codec_id 28
18:10:46 T:2781215552   DEBUG: CDVDDemuxPVRClient::RequestStreams(): added/updated stream 1:2 with codec_id 86019
18:10:46 T:2781215552   DEBUG: CDVDDemuxPVRClient::RequestStreams(): added/updated stream 2:3 with codec_id 86019
18:10:46 T:2781215552  NOTICE: Opening video stream: 0 source: 256
18:10:46 T:2781215552  NOTICE: Creating video codec with codec id: 28
18:10:46 T:2781215552   DEBUG: CDVDFactoryCodec: compiled in hardware support: CrystalHD:no OpenMax:no VDPAU:yes VAAPI:yes XVBA:yes
18:10:46 T:2781215552   DEBUG: FactoryCodec - Video:  - Opening
18:10:46 T:2781215552  NOTICE: CDVDVideoCodecFFmpeg::Open() Creating VDPAU(0x0, 28)
18:10:46 T:2781215552 WARNING: (VDPAU) no width/height available, can't init
18:10:46 T:2781215552  NOTICE: CDVDVideoCodecFFmpeg::Open() Failed to get VDPAU device
18:10:46 T:2781215552  NOTICE:  (VDPAU) Close
18:10:46 T:2781215552  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
18:10:46 T:2781215552   DEBUG: FactoryCodec - Video: ff-h264 - Opened
18:10:46 T:2781215552  NOTICE: Creating video thread
18:10:46 T:2530503488  NOTICE: Thread CDVDPlayerVideo start, auto delete: false
18:10:46 T:2781215552  NOTICE: Opening audio stream: 1 source: 256
18:10:46 T:2781215552  NOTICE: Finding audio codec for: 86019
18:10:46 T:2781215552   DEBUG: FactoryCodec - Audio: passthrough - Opening
18:10:46 T:2781215552   DEBUG: FactoryCodec - Audio: passthrough - Opened
18:10:46 T:2781215552  NOTICE: Creating audio thread
18:10:46 T:2530503488  NOTICE: running thread: video_thread
18:10:46 T:2530503488   DEBUG: CDVDPlayerVideo - CDVDMsg::GENERAL_SYNCHRONIZE
18:10:46 T:2571168576  NOTICE: Thread CDVDPlayerAudio start, auto delete: false
18:10:46 T:2571168576  NOTICE: running thread: CDVDPlayerAudio::Process()
18:10:46 T:3038050048   DEBUG: PrepareNextRender no buffer, out: 0, current: 0, display: 0
18:10:46 T:2716859200   DEBUG: Previous line repeats 30 times.
18:10:46 T:2716859200    INFO: AddOnLog: Tvheadend HTSP Client: ParseSubscriptionStop - subscription ended on adapter STV0367 DVB-C DVB-T
18:10:46 T:2781215552   DEBUG: ParsePacket - {0} profile changed from -99 to 100
18:10:46 T:2781215552   DEBUG: ParsePacket - {0} level changed from 0 to 40
18:10:46 T:2530503488   DEBUG: CDVDPlayerVideo - CDVDMsg::GENERAL_RESYNC(0.000000, 1)
18:10:46 T:2530503488   DEBUG: VAAPI - attempting to open codec 28 with profile 100 at level 40 with 3 reference frames
18:10:46 T:2530503488   DEBUG: VAAPI - attrib 6 (get/set) min 0 max 3 value 0x0
18:10:46 T:2530503488   DEBUG: VAAPI - profile 0
18:10:46 T:2530503488   DEBUG: VAAPI - profile 1
18:10:46 T:2530503488   DEBUG: VAAPI - profile 5
18:10:46 T:2530503488   DEBUG: VAAPI - profile 6
18:10:46 T:2530503488   DEBUG: VAAPI - profile 7
18:10:46 T:2530503488   DEBUG: VAAPI - profile 8
18:10:46 T:2530503488   DEBUG: VAAPI - profile 9
18:10:46 T:2530503488   DEBUG: VAAPI - profile 10
18:10:46 T:2530503488   DEBUG: VAAPI - profile -1
18:10:46 T:2530503488   DEBUG: VAAPI - making sure 12 surfaces are allocated for given 3 references
18:10:46 T:2530503488   DEBUG: VAAPI_VPP - Successfully initialized VPP
18:10:46 T:2530503488   DEBUG: VAAPI_VPP - Successfully initialized bob
18:10:46 T:2539088704  NOTICE: Thread VAAPI VPP Thread start, auto delete: false
18:10:46 T:2539088704   DEBUG: VAAPI - VPP thread on startup
18:10:46 T:2530503488   ERROR: ffmpeg[96D46B40]: [h264] mmco: unref short failure
18:10:46 T:2781215552   ERROR: Previous line repeats 1 times.
18:10:46 T:2781215552  NOTICE: CDVDVideoCodecFFmpeg::Open() Creating VDPAU(1920x1088, 28)
18:10:46 T:2781215552  NOTICE: vdp_device = 0xffffffff vdp_st = 0x00000001
18:10:46 T:2781215552   ERROR: (VDPAU) unable to init VDPAU - vdp_st = 0x1.  Falling back.
18:10:46 T:2539088704   DEBUG: VAAPI - VPP thread on exit
18:10:46 T:2539088704   DEBUG: Thread VAAPI VPP Thread 2539088704 terminating
18:10:46 T:2530503488   DEBUG: VAAPI_VPP - Deinitializing
18:10:46 T:2530503488   DEBUG: VAAPI - destroying surface 0x4000010
18:10:46 T:2530503488   DEBUG: VAAPI - destroying surface 0x400000f
18:10:46 T:2530503488   DEBUG: VAAPI - destroying surface 0x4000016
18:10:46 T:2530503488   DEBUG: VAAPI - destroying surface 0x4000015
18:10:46 T:2530503488   DEBUG: VAAPI - destroying surface 0x4000014
18:10:46 T:2530503488   DEBUG: VAAPI - destroying surface 0x4000012
18:10:46 T:2530503488   DEBUG: VAAPI - destroying surface 0x4000011
18:10:46 T:2530503488   DEBUG: VAAPI - destroying surface 0x4000002
18:10:46 T:2530503488   DEBUG: VAAPI - destroying surface 0x400000d
18:10:46 T:2530503488   DEBUG: VAAPI_VPP - Deinitialized bob
18:10:46 T:2530503488   DEBUG: VAAPI_VPP - Deinitialized vpp
18:10:46 T:2530503488   DEBUG: VAAPI - destroying surface 0x4000001
18:10:46 T:2530503488   DEBUG: VAAPI - destroying surface 0x400000b
18:10:46 T:2530503488   DEBUG: VAAPI - destroying surface 0x400000a
18:10:46 T:2530503488   DEBUG: VAAPI - destroying surface 0x4000007
18:10:46 T:2530503488   DEBUG: VAAPI - destroying surface 0x4000009
18:10:46 T:2530503488   DEBUG: VAAPI - destroying surface 0x4000004
18:10:46 T:2530503488   DEBUG: VAAPI - destroying surface 0x4000006
18:10:46 T:2530503488   DEBUG: VAAPI - destroying surface 0x400000c
18:10:46 T:2530503488   DEBUG: VAAPI - destroying surface 0x400000e
18:10:46 T:2530503488   DEBUG: VAAPI - destroying surface 0x4000000
18:10:46 T:2530503488   DEBUG: VAAPI - destroying surface 0x4000003
18:10:46 T:2530503488   DEBUG: VAAPI - destroying surface 0x4000005
18:10:47 T:2781215552   DEBUG: Previous line repeats 54 times.
18:10:47 T:2781215552   DEBUG: ParsePacket - {0} profile changed from -99 to 100
18:10:47 T:2781215552   DEBUG: ParsePacket - {0} level changed from 0 to 40
18:10:47 T:2781215552  NOTICE: Opening video stream: 0 source: 256
18:10:47 T:2781215552  NOTICE: Creating video codec with codec id: 28
18:10:47 T:2781215552   DEBUG: CDVDFactoryCodec: compiled in hardware support: CrystalHD:no OpenMax:no VDPAU:yes VAAPI:yes XVBA:yes
18:10:47 T:2781215552   DEBUG: FactoryCodec - Video:  - Opening
18:10:47 T:2781215552  NOTICE: CDVDVideoCodecFFmpeg::Open() Creating VDPAU(1920x1088, 28)
18:10:47 T:2781215552  NOTICE: vdp_device = 0xffffffff vdp_st = 0x00000001
18:10:47 T:2781215552   ERROR: (VDPAU) unable to init VDPAU - vdp_st = 0x1.  Falling back.
18:10:47 T:2781215552  NOTICE: CDVDVideoCodecFFmpeg::Open() Failed to get VDPAU device
18:10:47 T:2781215552  NOTICE:  (VDPAU) Close
18:10:47 T:2781215552  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
18:10:47 T:2781215552   DEBUG: FactoryCodec - Video: ff-h264 - Opened
18:10:47 T:2530503488   DEBUG: VAAPI - attempting to open codec 28 with profile 100 at level 40 with 3 reference frames
18:10:47 T:2530503488   DEBUG: VAAPI - attrib 6 (get/set) min 0 max 3 value 0x0
18:10:47 T:2530503488   DEBUG: VAAPI - profile 0
18:10:47 T:2530503488   DEBUG: VAAPI - profile 1
18:10:47 T:2530503488   DEBUG: VAAPI - profile 5
18:10:47 T:2530503488   DEBUG: VAAPI - profile 6
18:10:47 T:2530503488   DEBUG: VAAPI - profile 7
18:10:47 T:2530503488   DEBUG: VAAPI - profile 8
18:10:47 T:2530503488   DEBUG: VAAPI - profile 9
18:10:47 T:2530503488   DEBUG: VAAPI - profile 10
18:10:47 T:2530503488   DEBUG: VAAPI - profile -1
18:10:47 T:2530503488   DEBUG: VAAPI - making sure 12 surfaces are allocated for given 3 references
18:10:47 T:2530503488   DEBUG: VAAPI_VPP - Successfully initialized VPP
18:10:47 T:2530503488   DEBUG: VAAPI_VPP - Successfully initialized bob
18:10:47 T:2309602112  NOTICE: Thread VAAPI VPP Thread start, auto delete: false
18:10:47 T:2309602112   DEBUG: VAAPI - VPP thread on startup
18:10:47 T:2530503488   ERROR: ffmpeg[96D46B40]: [h264] mmco: unref short failure
18:10:47 T:3038050048   ERROR: Previous line repeats 1 times.
18:10:47 T:3038050048   DEBUG: PrepareNextRender no buffer, out: 0, current: 0, display: 0
18:10:48 T:2530503488   DEBUG: Previous line repeats 1 times.
18:10:48 T:2530503488   DEBUG: VAAPI - destroying surface 0x4000008
18:10:48 T:2530503488   ERROR: ffmpeg[96D46B40]: [h264] mmco: unref short failure
18:10:48 T:2781215552   ERROR: Previous line repeats 1 times.
18:10:48 T:2781215552   DEBUG: CDVDPlayer::HandleMessages - player started 2
18:10:48 T:2781215552   DEBUG: ParsePacket - {2} level changed from 0 to -99
18:10:48 T:2781215552   DEBUG: ParsePacket - {2} iChannels changed from 0 to 2
18:10:48 T:2781215552   DEBUG: ParsePacket - {2} iSampleRate changed from 0 to 48000
18:10:48 T:2781215552   DEBUG: ParsePacket - {1} level changed from 0 to -99
18:10:48 T:2781215552   DEBUG: ParsePacket - {1} iChannels changed from 0 to 6
18:10:48 T:2781215552   DEBUG: ParsePacket - {1} iSampleRate changed from 0 to 48000
18:10:48 T:2781215552  NOTICE: Opening audio stream: 1 source: 256
18:10:48 T:2781215552  NOTICE: Finding audio codec for: 86019
18:10:48 T:2781215552   DEBUG: FactoryCodec - Audio: passthrough - Opening
18:10:48 T:2781215552   DEBUG: FactoryCodec - Audio: passthrough - Opened
18:10:48 T:2571168576   DEBUG: CDVDPlayerAudio: Sample rate changed, checking for passthrough
18:10:48 T:2571168576   DEBUG: FactoryCodec - Audio: passthrough - Opening
18:10:48 T:2571168576   DEBUG: FactoryCodec - Audio: passthrough - Opened
18:10:48 T:2571168576   DEBUG: CDVDPlayerAudio - CDVDMsg::GENERAL_RESYNC(18611.000000, 0)
18:10:48 T:2571168576    INFO: CAEStreamInfo::SyncAC3 - AC3 stream detected (6 channels, 48000Hz)
18:10:48 T:2571168576  NOTICE: Creating audio stream (codec id: 86019, channels: 2, sample rate: 48000, pass-through)
18:10:48 T:2571168576    INFO: CSoftAE::MakeStream - AE_FMT_AC3, 48000, RAW,RAW
18:10:48 T:2970651456   DEBUG: CSoftAE::Run - Sink restart flagged
18:10:48 T:2970651456    INFO: CSoftAE::InternalOpenSink - RAW passthrough enabled
18:10:48 T:2970651456    INFO: CSoftAE::InternalOpenSink - sink incompatible, re-starting
18:10:48 T:2970651456    INFO: CAESinkALSA::Initialize - Attempting to open device "hdmi:CARD=PCH,DEV=0"
18:10:48 T:2970651456    INFO: CAESinkALSA::Initialize - Opened device "hdmi:CARD=PCH,DEV=0,AES0=0x06,AES1=0x82,AES2=0x00,AES3=0x02"
18:10:48 T:2970651456   DEBUG: CAESinkALSA::InitializeHW - Request: periodSize 2400, bufferSize 9600
18:10:48 T:2970651456   DEBUG: CAESinkALSA::InitializeHW - Got: periodSize 2400, bufferSize 9600
18:10:48 T:2970651456   DEBUG: CAESinkALSA::InitializeHW - Setting timeout to 200 ms
18:10:48 T:2970651456   DEBUG: CSoftAE::InternalOpenSink - ALSA Initialized:
18:10:48 T:2970651456   DEBUG:   Output Device : HDA Intel PCH
18:10:48 T:2970651456   DEBUG:   Sample Rate   : 48000
18:10:48 T:2970651456   DEBUG:   Sample Format : AE_FMT_S16NE
18:10:48 T:2970651456   DEBUG:   Channel Count : 2
18:10:48 T:2970651456   DEBUG:   Channel Layout: FL,FR
18:10:48 T:2970651456   DEBUG:   Frames        : 2400
18:10:48 T:2970651456   DEBUG:   Frame Samples : 4800
18:10:48 T:2970651456   DEBUG:   Frame Size    : 4
18:10:48 T:2970651456   DEBUG: CSoftAE::InternalOpenSink - Internal Buffer Size: 9600
18:10:48 T:2571168576   DEBUG: CDVDPlayerAudio:: synctype set to 1: skip/duplicate
18:10:48 T:2781215552   DEBUG: CDVDPlayer::HandleMessages - player started 1
18:10:49 T:2781215552   DEBUG: set caching from pvr to done. audio (1) = 11. video (1) = 13
18:10:49 T:2781215552   DEBUG: CDVDPlayer::SetCaching - caching state 0
18:10:49 T:2571168576   DEBUG: CDVDPlayerAudio:: Discontinuity1 - was:178.973000, should be:-194550.122666, error:-194729.095666
18:10:49 T:2530503488   DEBUG: ffmpeg[96D46B40]: [h264] Increasing reorder buffer to 1
18:10:49 T:2530503488   DEBUG: ffmpeg[96D46B40]: [h264] Increasing reorder buffer to 2
18:10:49 T:2970651456   DEBUG: CSoftAE::Run - Sink restart flagged
18:10:49 T:2970651456    INFO: CSoftAE::InternalOpenSink - RAW passthrough enabled
18:10:49 T:2970651456    INFO: CSoftAE::InternalOpenSink - keeping old sink with : AE_FMT_AC3, FL,FR, 48000hz
18:10:49 T:2970651456   DEBUG: CSoftAE::InternalOpenSink - Internal Buffer Size: 9600
18:10:49 T:2530503488   ERROR: ffmpeg[96D46B40]: [h264] mmco: unref short failure
18:10:49 T:2530503488   ERROR: Previous line repeats 1 times.
18:10:49 T:2530503488   DEBUG: VAAPI - destroying surface 0x4000013
18:10:49 T:2571168576 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
18:10:50 T:2530503488 WARNING: Previous line repeats 2 times.
18:10:50 T:2530503488   DEBUG: OutputPicture - dropped in output
18:10:50 T:2571168576   DEBUG: Previous line repeats 3 times.
18:10:50 T:2571168576 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
18:10:51 T:2530503488   DEBUG: OutputPicture - dropped in output
18:10:51 T:2571168576   DEBUG: Previous line repeats 9 times.
18:10:51 T:2571168576 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
18:10:51 T:2571168576   DEBUG: Previous line repeats 1 times.
18:10:52 T:2571168576   DEBUG: Previous line repeats 15 times.
18:10:52 T:2571168576 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
18:10:52 T:2530503488   DEBUG: OutputPicture - dropped in output
18:10:52 T:2571168576   DEBUG: Previous line repeats 13 times.
18:10:52 T:2530503488   DEBUG: Previous line repeats 1 times.
18:10:52 T:2530503488   DEBUG: CPullupCorrection: detected pattern of length 2: 0.00 40000.00, frameduration: 20000.000000
18:10:52 T:2571168576   DEBUG: Previous line repeats 1 times.
18:10:53 T:2571168576   DEBUG: Previous line repeats 9 times.
18:10:53 T:2571168576 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
18:10:53 T:2530503488   DEBUG: OutputPicture - dropped in output
18:10:53 T:2571168576   DEBUG: Previous line repeats 3 times.
18:10:54 T:2530503488   DEBUG: OutputPicture - dropped in output
18:10:54 T:2571168576   DEBUG: Previous line repeats 4 times.
18:10:54 T:2571168576 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
18:10:55 T:2571168576   DEBUG: Previous line repeats 30 times.
18:10:55 T:2571168576 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
18:10:55 T:2530503488   DEBUG: OutputPicture - dropped in output
18:10:56 T:2571168576   DEBUG: Previous line repeats 14 times.
18:10:56 T:2571168576 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
18:10:56 T:2530503488   DEBUG: OutputPicture - dropped in output
18:10:56 T:2571168576   DEBUG: Previous line repeats 13 times.
18:10:56 T:2571168576   DEBUG: Previous line repeats 3 times.
18:10:57 T:2571168576   DEBUG: Previous line repeats 13 times.
18:10:57 T:2571168576 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
18:10:57 T:2530503488 WARNING: Previous line repeats 1 times.
18:10:57 T:2530503488   DEBUG: OutputPicture - dropped in output
18:10:58 T:2571168576   DEBUG: Previous line repeats 13 times.
18:10:58 T:2571168576 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
18:10:58 T:2530503488   DEBUG: OutputPicture - dropped in output
18:10:58 T:2571168576   DEBUG: Previous line repeats 14 times.
18:10:58 T:2571168576   DEBUG: Previous line repeats 1 times.
18:10:59 T:2530503488   DEBUG: OutputPicture - dropped in output
18:10:59 T:2571168576   DEBUG: Previous line repeats 8 times.
18:10:59 T:2571168576 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
18:10:59 T:2571168576   DEBUG: Previous line repeats 5 times.
18:11:00 T:2571168576   DEBUG: Previous line repeats 14 times.
18:11:00 T:2571168576 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
18:11:00 T:2530503488   DEBUG: OutputPicture - dropped in output
18:11:00 T:2571168576   DEBUG: Previous line repeats 13 times.
18:11:00 T:2571168576   DEBUG: Previous line repeats 2 times.
18:11:01 T:3038050048 WARNING: Previous line repeats 1 times.
18:11:01 T:3038050048   DEBUG: Keyboard: scancode: 09, sym: 001b, unicode: 001b, modifier: 0
18:11:01 T:3038050048   DEBUG: OnKey: escape (f01b) pressed, action is Fullscreen
18:11:01 T:3038050048   DEBUG: CGUIWindowManager::PreviousWindow: Deactivate
18:11:01 T:2530503488   DEBUG: OutputPicture - dropped in output
18:11:01 T:3038050048   DEBUG: Previous line repeats 6 times.
vainfo:
error: can't connect to X server!
libva info: Trying to open /usr/lib/i386-linux-gnu/dri/i965_drv_video.so
vainfo: VA-API version: 0.34 (libva 1.2.0.pre1)
vainfo: Driver version: Intel i965 driver - 1.1.0.pre1
vainfo: Supported profile and entrypoints
      VAProfileNone                   : VAEntrypointVideoProc
      VAProfileMPEG2Simple            : VAEntrypointVLD
      VAProfileMPEG2Simple            : VAEntrypointEncSlice
      VAProfileMPEG2Main              : VAEntrypointVLD
      VAProfileMPEG2Main              : VAEntrypointEncSlice
      VAProfileH264Baseline           : VAEntrypointVLD
      VAProfileH264Baseline           : VAEntrypointEncSlice
      VAProfileH264Main               : VAEntrypointVLD
      VAProfileH264Main               : VAEntrypointEncSlice
      VAProfileH264High               : VAEntrypointVLD
      VAProfileH264High               : VAEntrypointEncSlice
      VAProfileVC1Simple              : VAEntrypointVLD
      VAProfileVC1Main                : VAEntrypointVLD
      VAProfileVC1Advanced            : VAEntrypointVLD
With deinterlacing disabled or with XBMC-Main ppa: no drops at all
any ideas ?
regards gebnix
I have the exact same system as you have. Make sure, that you did the settings exactly as they are described in the howto.
For the Celeron 847 it is quite normal, that you get approx 1 fps drop when the OSD is on, but when I see it right you only have 37fps on total. There are no drops at all when running in fullscreen with 1080i50 content. Sadly you cut the important lines from this logfile, so I cannot see what I want to see.
Make sure, that you have set Scaling to "bilinear" and save this for all files.
thanks for your fast reply.
I made all settings like described in the first post.
Bilinear scaling is on.
Which lines from my xbmc.log do you want to see ?
here is a full xbmc.log with debug: http://paste.ubuntu.com/5745589/
Can you completely remove Boblight?
If you want, you can also join #xbmc-xvba
ok, deactivating boblight-Addon did it.
I switched to boblight-X11 and everything is working fine now.
Pause / FFWD is now fixed in frodo-vpp branch.
