@TheYetWakes: Just use OpenELEC. If you want something working and don't want to invest time into fixing things yourself, OE is exactly made for you.
(2014-09-23, 17:30)fritsch Wrote: [ -> ]@TheYetWakes: Just use OpenELEC. If you want something working and don't want to invest time into fixing things yourself, OE is exactly made for you.
Yeah possibly. Not sure I want to install a new linux distro, everything else is finally setup and works. I don't mean to sound ungrateful, as I said previously this fix works like a charm, its more the PVR frontend having problems. I don't mind tinkering and sorting things, its part of the fun afterall. I'm just not sure I can fix this problem myself and mildly annoying as everything was working great previously. Guess i'll have to wait until TV headend offers better Helix support, i'll have to bother them instead
The other half is threatening to move in so I guess its just me finally thinking it may be a good idea to have a more stable system as the daily TV!
Just test it on a usbstick if you are unsure. It shouldn't take many minutes to make OE work. And you shouldn't have to do any tinkering, so the other half should be happy with it.
Let me preface this post by saying I'm a total linux newbie. I'm attempting to set up ubuntu mini + XBMC per the guide in the OP on my Zotac CI520, but I'm having difficulties with the graphics driver. When I attempt to run XBMC, I see this message:
Error: unable to open display
XBMC needs hardware accelerated OpenGL rendering.
Install an appropriate graphics driver.
lspci displays:
00:02.0 VGA compatible controller: Intel Corporation Device 0a1e (rev 0b)
pastebins:
http://paste.ubuntu.com/8434158/
http://paste.ubuntu.com/8434160/
http://paste.ubuntu.com/8434176/
http://paste.ubuntu.com/8434178/
http://paste.ubuntu.com/8434180/
"DISPLAY=:0 vainfo | pastebinit" results in
libva info: VA-API version 0.35.0
vainfo: dri2_util.c:199: isDRI2Connected: Assertion `dri_state->base.fd >= 0' failed.
Currently afk. But have read your post.
Retry line by line from the beginning:-) it is a good training.
I actually did that twice, and the third time I just copied and pasted each line from your guide via SSH terminal after running the basic installation (much easier!). Same results, though B(
I think you are better of with OpenELEC - as this howto is a bit more demanding especially for beginners.
Never the less, provide:
cat /etc/init/xbmc.conf | pastebinit
id | pastebinit
dpkg -l |grep mesa | pastebinit
Are you sure you added the user called xbmc? As your id comments reveals that your username is ayris and not xbmc as the howto wants.
Furthermore this ayris user is not member of group audio nor video.
Yep, it says user xbmc has been created. I'm going to give it another go just using xbmc as the default user, been playing around with my new monitor and graphics card so I've been distracted B) Thanks for the help so far!
Welp, still getting the same message with regard to XBMC needing hardware OpenGL accelerated rendering whenever I try to run it via commandline.
xbmc@zotac:~$ DISPLAY=:0 vainfo
libva info: VA-API version 0.36.0
libva info: va_getDriverName() returns 0
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/i965_drv_video.so
libva info: Found init function __vaDriverInit_0_36
libva info: va_openDriver() returns 0
vainfo: VA-API version: 0.36 (libva 1.4.0.pre1)
vainfo: Driver version: Intel i965 driver for Intel(R) Haswell - 1.3.3.pre1 (1.3.3.pre1)
vainfo: Supported profile and entrypoints
VAProfileMPEG2Simple : VAEntrypointVLD
VAProfileMPEG2Simple : VAEntrypointEncSlice
VAProfileMPEG2Main : VAEntrypointVLD
VAProfileMPEG2Main : VAEntrypointEncSlice
VAProfileH264ConstrainedBaseline: VAEntrypointVLD
VAProfileH264ConstrainedBaseline: VAEntrypointEncSlice
VAProfileH264Main : VAEntrypointVLD
VAProfileH264Main : VAEntrypointEncSlice
VAProfileH264High : VAEntrypointVLD
VAProfileH264High : VAEntrypointEncSlice
VAProfileH264MultiviewHigh : VAEntrypointVLD
VAProfileH264MultiviewHigh : VAEntrypointEncSlice
VAProfileH264StereoHigh : VAEntrypointVLD
VAProfileH264StereoHigh : VAEntrypointEncSlice
VAProfileVC1Simple : VAEntrypointVLD
VAProfileVC1Main : VAEntrypointVLD
VAProfileVC1Advanced : VAEntrypointVLD
VAProfileNone : VAEntrypointVideoProc
VAProfileJPEGBaseline : VAEntrypointVLD
xbmc@zotac:~$ id
uid=1000(xbmc) gid=1000(xbmc) groups=1000(xbmc),4(adm),20(dialout),24(cdrom),27(sudo),29(audio),30(dip),44(video),46(plugdev),100(users),109(lpadmin),110(sambashare)
Don't know where I'm going wrong since I've followed the guide line for line for the most part. Perhaps I'll try an automated installation of mini ubuntu.
Not sure what you are doing wrong - but yeah getting the howto not to run is like winning in the lottery. How do you start xbmc? Do you start it by opening a terminal in openbox? Provide:
sudo apt-get install mesa-utils
glxinfo | pastebinit
cat /var/log/Xorg.0.log | pastebinit
The above output looks promissing.
Last try ->
www.openelec.tv is your next station. They released version 4.2 which should work perfectly on your box.
I actually just went ahead with an automated ubuntu mini installation with a stable build of XBMC, I'll give this a go again in the future when I feel like tinkering again. Now I just want to set up Steam so I can start streaming some games B) Thanks again for the help, though!
So I add the the ppa:wsnipex/vaapi
and made a update, upgrade and dist-upgrade...
but with the same result, xbmc crashs every 30min...
it crash when I usins Live-Tv or listen music or somthing else...
