Please provide a
Debug Log with just that non working sample playing.
Quote:[Sun Sep 28 12:17:37 2014] [drm] stuck on render ring
[Sun Sep 28 12:17:37 2014] [drm] GPU crash dump saved to /sys/class/drm/card0/error
[Sun Sep 28 12:17:37 2014] [drm] GPU hangs can indicate a bug anywhere in the entire gfx stack, including userspace.
[Sun Sep 28 12:17:37 2014] [drm] Please file a _new_ bug report on bugs.freedesktop.org against DRI -> DRM/Intel
[Sun Sep 28 12:17:37 2014] [drm] drm/i915 developers can then reassign to the right component if it's not a kernel issue.
[Sun Sep 28 12:17:37 2014] [drm] The gpu crash dump is required to analyze gpu hangs, so please always attach it.
[Sun Sep 28 12:17:44 2014] [drm] stuck on render ring
[Sun Sep 28 12:17:44 2014] [drm:i915_set_reset_status] *ERROR* render ring hung inside bo (0x2900000 ctx 1) at 0x29002c4
This one sucks though.
Try to upgrade to kernel 3.16.3, please via ubuntu mainline.
Is it something wrong with builds or. am i just too fast?
The following packages have unmet dependencies.
xbmc : Depends: xbmc-bin (< 2:14.0~git20140928.0500-c350d22-0trusty.1~) but 2:14.0~git20140929.0500-795877c-0trusty is to be installed
E: Unable to correct problems, you have held broken packages.
P.S.:
OK I was too fast it has not build yet. Now it is ok.
(2014-09-27, 13:16)fritsch Wrote: [ -> ]Quote:10:24:49 T:140281793988352 DEBUG: CPythonInvoker(13, /home/xbmc/.xbmc/addons/script.metadata.actors/resources/lib/service.py): th
Fix that addon or remove it.
Thanks, that helped for me... afer removing the addon, no more crashes...
(2014-09-28, 14:41)fritsch Wrote: [ -> ]This patch should fix the python issue of sveni_lee and orduek: https://github.com/xbmc/xbmc/pull/5425 - when jenkins is happy I will push it.
So I should update again?
Vorwärts immer - rückwärts nimmer!
"Vorwärts Leute... wir müssen zurück"
Libva-1.4.0 is now in OE 4.2. So Gotham will have the vaapi deint features as well?
No.
OE will only have VAAPI-BOB
Libva-1.4.0 is not enough for mcdi and madi, you need 8 additional patches, see:
https://github.com/fritsch/libva-intel-d...mits/ppa14
Everything with the name "vebox" in it is needed. I think the "nightly builds" of OpenELEC have the relevant code, but ask sraue - he knows best.
Edit: I just verified the code. It only has SW Deinterlacing with either Yadif or OpenGL Bob. And no automatically switching between VAAPI Render and SWRender in OE 4.2
OpenELEC master has a two days old patch for all VPP methods and they provide the relevant driver with the patches
https://github.com/OpenELEC/OpenELEC.tv/...ream.patch
Gotham have deint (yadif) since dec 2013.
Or do you mean madi DI with vpp?
If anything vpp related shows up in Gotham it is without my knowledge, means that behavior is undefined
Thanks fritsch. Still enjoying your yadif work for a while!
Btw. now after 4.2 is released - the next OE release will be 5.0 which will feature Helix. So the next alpha / beta / gammas will most likely have all the VPP work.
Yes looking forward to OE5.0! Just waiting for the betas and I'll switch.
(2014-09-22, 11:00)robo989 Wrote: [ -> ]Aftert recent sudo apt-get update/upgrade to Alpha4 the options for the MADI/MCDI deinterling have vanished leaving the usual bob/weave/deinterlace etc...
Any ideas on that? Thanks
(2014-09-22, 11:41)fritsch Wrote: [ -> ]Provide what the first page wants, thanks.
Have done so and then the MCDI/MADI modes started working on haswell.
Have just done and update/upgrade and the modes are gone again
