2013-05-27, 02:11
Hello, everyone.
I am a bit stumped how I should get this working. The task is simple: integrate WMC (more specifically, the netflix plugin) into the main menu of XBMC.
I have tried using this guide: http://forum.xbmc.org/showthread.php?tid=108043
With no luck. The skin I am using is Aeon Nox and I can't find the "Item ID" line on any of its Home.XML
Second, I am already using Advanced Launcher as a Game/Emulator widget. So, I would have to add 'netflix' into the Advanced Launcher (which I would prefer to keep separate).
Anyone have any suggestions? Thanks!
