2013-05-28, 04:21
2013-05-28, 04:21
2013-05-28, 05:20
No, but there are scrapers out there that can handle anime. I can't be positive but the 'Universal Scraper' might cover them, or you could take a look here: http://forum.xbmc.org/forumdisplay.php?fid=147
If you want to separate tv shows from anime, your best bet is smart playlists. There is a link in my signature which should hopefully help you with those.
2013-05-28, 14:28
When you arrive in custom what you squeeze to appears that list you choose Smart Playlist Manager
2013-05-29, 05:51
You push arrow up to get the General Options screen to appear, and if Smart Playlist Manager isn't there it's because you are missing the randomandlastitems script.
2013-05-29, 08:55
Even stirring in the script is unable to create a new open source is not here?
2013-05-29, 09:41
Hey, it's easy.
At first, all your anime needs to be in a seperate folder. Then you download the AniDB.net scraper addon. Create a new source, selecting this scraper instead of TVDb. -> Your anime should be in your Video Database along with the other Videos. If you have that, you can read a little about Smartplaylists to get seperate views.
2013-05-29, 18:47
in the case they will get along with the movies or serials section, but do not have how to separate them?
