Mm still too much
Why need an ssd with openelec?
Cant we do it without?
And for total of 100?
go for an android mini pc.
eskro. It might be worth highlighting what wont work with these builds. Without looking at the other threads you posted, I wouldn't have noticed that HD audio was missing..
I know this is intended for OpenElec, but how would windows 8 run on this? I need to be able to watch netflix! Mostly 480p and occasionally 720p.
(2013-05-28, 19:54)grin Wrote: [ -> ]I know this is intended for OpenElec, but how would windows 8 run on this? I need to be able to watch netflix! Mostly 480p and occasionally 720p.
Do you just want Netflix?
Roku would probably be best.
I want more than netflix. I want to run XBMC, so I can rip all of my DVDs to a NAS and stream from there.
(2013-05-28, 20:18)grin Wrote: [ -> ]I want more than netflix. I want to run XBMC, so I can rip all of my DVDs to a NAS and stream from there.
Probably better off with a Celeron NUC. It can do Netflix HD.
No Netflix HD with E-350 or Atom -- neither are powerful enough to handle software rendering of high-def content (Netflix uses Silverlight which as of last checked does not always do GPU acceleration).
Celeron 847 (as cwide alludes to) is the minimum.
Or a DIY Celeron 847 system, some of the boards are showing up on sale for $60 after mail in rebates or $80 with 8GB memory included. Add a cheap case with a power supply and you have a system capable of running Windows and XBMC for much less than most of these pre built systems that will only be okay with OpenELEC.
@SKANK: at this moment, only the Pivos XIOS seems recommended because it gives you hardware decode.
android is fairly new in the htpc scene so, expectit to be buggy and clunky working a bit.
im not ready to go full android now in my htpc because of this.
someday i will tho, its going there. just not ready for prime time consumer level as of today.
@cwide: it is cheap, but again you need to look into what suits you best feature wise.
If you need FULL 3D 1080P and HD-Audio Bitstream, then its not for you.
then, it might be a noisy system with the APEC MI-008 PSU just on top of the CPU cooler,
you'll need to add a side Fan like many did in there with that case, so you add cost there just for that.
the ISK110 is a better case since it comes with a fanless PSU or that nice Habey case Dougie posted here
http://goo.gl/5c5qX,
i forgot that one! nice catch Dougie!
also, that gigabyte board has bad reviews to me.... i dunno...
