2013-05-28, 11:43
I'm using XBMC as a notice board player in a remote location. The idea is to use a raspberry pi powered from the USB port of a TV. The TV is on a sleep timer & can be set to come on and turn off whenever you want. The raspberry boots up when the TV comes on & plays a particular looping playlist. This part all works fine. Only problem I have is that there is a warning box which comes on when the raspberry loads up XBMC saying that 'Raspbmc should always be shut down via the power icon in the lower left corner'. When this happens, the playlist plays once and then stops.
Is there anything can be done to get rid of this? I could leave the raspberry permanently powered up, but there is always the possibility that some one will cycle the power & I'll have the same issue. There will be no one on site to correct the problem.
Thanks for any help,
Joe
Joe
