2013-05-29, 03:26
So I had 2 devices in sync and thought I was in the home stretch as far as syncing goes. I went to add a 3rd device and copy/pasted advancedsettings.xml from my other setup into the pc. The pc also happened to use xbmc previously and in the process, I removed existing libraries. I lost my library across all computers and had to re-add my library which took a good 20 minutes.
I'm hoping I did something wrong on my 3rd device to cause me to lose the library and am hesitant to add my 4th device. Is this normal behavior or I most likely did something wrong? What are the steps to add a device w/o affecting the library? Here is how I plan on adding the 4th device:
- Install XBMC
- Copy/Paste advancedsettings.xml
- Will it auto recognize library or do I add/browse for the library?
