2013-05-29, 07:51
I have a fresh install of 12.2 (2:12.2~git20130525.1043-vpp-0precis) on Ubuntu 12.04LTS. I'm using ALC898 sound hardware through the HDMI port powered by an Intel HD 4000 GPU.
Video is working fine using HDMI3, but the problem I'm having is with audio over HDMI. In the Audio set up I'm only given options for HDMI #0 and HDMI #1 - but I need an option for HDMI #2. From the log it looks like XBMC isn't enumerating the third port from ALSA.
Playing audio via: aplay -D plughw:0,8 /usr/share/sounds/alsa/Front_Center.wav
works just fine.
Does anyone have suggestions? xbmc.log and aplay -L output are below...
works just fine.
21:47:19 T:139673386002304 ERROR: CAESinkOSS::EnumerateDevicesEx - Failed to open mixer: /dev/mixer
21:47:19 T:139673386002304 NOTICE: Found 1 Lists of Devices
21:47:19 T:139673386002304 NOTICE: Enumerated ALSA devices:
21:47:19 T:139673386002304 NOTICE: Device 1
21:47:19 T:139673386002304 NOTICE: m_deviceName : @
21:47:19 T:139673386002304 NOTICE: m_displayName : Default (HDA Intel PCH ALC898 Analog)
21:47:19 T:139673386002304 NOTICE: m_displayNameExtra:
21:47:19 T:139673386002304 NOTICE: m_deviceType : AE_DEVTYPE_PCM
21:47:19 T:139673386002304 NOTICE: m_channels : FL,FR,BL,BR,FC,LFE
21:47:19 T:139673386002304 NOTICE: m_sampleRates : 44100,48000,88200,96000,192000
21:47:19 T:139673386002304 NOTICE: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
21:47:19 T:139673386002304 NOTICE: Device 2
21:47:19 T:139673386002304 NOTICE: m_deviceName : @:CARD=PCH,DEV=0
21:47:19 T:139673386002304 NOTICE: m_displayName : HDA Intel PCH
21:47:19 T:139673386002304 NOTICE: m_displayNameExtra: ALC898 Analog
21:47:19 T:139673386002304 NOTICE: Device 3
21:47:19 T:139673386002304 NOTICE: m_deviceName : iec958:CARD=PCH,DEV=0
21:47:19 T:139673386002304 NOTICE: m_displayNameExtra: ALC898 Digital S/PDIF
21:47:19 T:139673386002304 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
21:47:19 T:139673386002304 NOTICE: m_sampleRates : 32000,44100,48000,88200,96000,192000
21:47:19 T:139673386002304 NOTICE: Device 4
21:47:19 T:139673386002304 NOTICE: m_deviceName : hdmi:CARD=PCH,DEV=0
21:47:19 T:139673386002304 NOTICE: m_displayNameExtra: HDMI #0
21:47:19 T:139673386002304 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
21:47:19 T:139673386002304 NOTICE: m_channels : FL,FR,BL,BR,FC,LFE,SL,SR
21:47:19 T:139673386002304 NOTICE: m_sampleRates : 32000,44100,48000,88200,96000,176400,192000
21:47:19 T:139673386002304 NOTICE: Device 5
21:47:19 T:139673386002304 NOTICE: m_deviceName : hdmi:CARD=PCH,DEV=1
21:47:19 T:139673386002304 NOTICE: m_displayNameExtra: HDMI #1
root@fe-lroom:/home/xbmc/.xbmc/temp# aplay -L
null
Discard all samples (playback) or generate zero samples (capture)
pulse
PulseAudio Sound Server
default
sysdefault:CARD=PCH
HDA Intel PCH, ALC898 Analog
Default Audio Device
front:CARD=PCH,DEV=0
Front speakers
surround40:CARD=PCH,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=PCH,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=PCH,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=PCH,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=PCH,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
HDA Intel PCH, ALC898 Digital
IEC958 (S/PDIF) Digital Audio Output
hdmi:CARD=PCH,DEV=0
HDA Intel PCH, HDMI 0
HDMI Audio Output
hdmi:CARD=PCH,DEV=1
HDA Intel PCH, HDMI 1
HDMI Audio Output
hdmi:CARD=PCH,DEV=2
HDA Intel PCH, HDMI 2
HDMI Audio Output
dmix:CARD=PCH,DEV=0
Direct sample mixing device
dmix:CARD=PCH,DEV=1
dmix:CARD=PCH,DEV=3
dmix:CARD=PCH,DEV=7
dmix:CARD=PCH,DEV=8
dsnoop:CARD=PCH,DEV=0
Direct sample snooping device
dsnoop:CARD=PCH,DEV=1
dsnoop:CARD=PCH,DEV=3
dsnoop:CARD=PCH,DEV=7
dsnoop:CARD=PCH,DEV=8
hw:CARD=PCH,DEV=0
Direct hardware device without any conversions
hw:CARD=PCH,DEV=1
hw:CARD=PCH,DEV=3
hw:CARD=PCH,DEV=7
hw:CARD=PCH,DEV=8
plughw:CARD=PCH,DEV=0
Hardware device with all software conversions
plughw:CARD=PCH,DEV=1
plughw:CARD=PCH,DEV=3
plughw:CARD=PCH,DEV=7
plughw:CARD=PCH,DEV=8
