Hi
For some reason I cannot figure out how to open a existing music playlist from the Android app? Am I blind or is the function not there?
Thanks in advance
Lasse
Well you can use Yatse or Music Pump to have more complete remotes that support playlists and much much more
About playlist there's a strange bug in currents Xbmc that register .m3u as pictures so may generate troubles.
A solution :
You just need to add the following in your advanced settings in Xbmc installation
<pictureextensions>
<remove>.m3u</remove>
</pictureextensions>
+1, i tried Yatse and it support music smart playlists
I didn't tried "Music Pump", does it have features that Yatse doesn't ?
Music Pump has a lot to offer, especially for music playback. You should definitively give it a try.
Appart from all standard features that most players have:
- You can download songs, albums, current queue
- Stream songs to your android device
- Use Music Pump as local music player and start streaming music to xbmc similar to airplay on apple devices
- Supports playlists and smart playlists
- Singles / Top 100 / recently added / recently played music ...
and much more
Some features are only available in the unlocked version
Screenshots
Thanks for your reply, i will try it
