Full Version: Short newbie question
Hi everyone,
I've got a small question and hope you can help me with a short explication.
I just installed tvheadend on my synology and connected it to Frodo.
Everything works fine.
I installed TvH via the packagecenter of the syno, so that I am now Running V3.2.
Now my Question:
What do I have to do to Update to 3.4Huh Huh
Thanks in advance for your help!
Probably wait for someone to build 3.4 for your particular architecture (ARM, Intel, PowerPC, etc.) - I presume that you're using the synocommunity package, so head over there to see the status.
http://www.synocommunity.com
http://forum.synology.com/enu/viewtopic....90&t=50593
Alternatively, you can compile it yourself; there are several discussions on here as it's not a straightforward task on some Synology devices.
