Full Version: Confluence Touchscreen Volume control Mod
Hello Community
I use a touch screen PC in my kitchen.
With the default skin Confluence I have had the problem, that the volume control is not easy possible via the touch panel.
For this reason, I have modded the default Confluence skin and inserted additional buttons for volume control.
The Skin is available for download HERE:
http://www.file-upload.net/download-7654...d.zip.html
Regards
Cleem
PS: I hope that I have not violated any rules!
Hi Cleem,
I have exactly the same setup and also need touchscreen volume control. Your mod is exactly what I need. I home.xml of Kodi 16.1 using your mod and added the icons to the media directory and it works fine !
Thanks !
Just as a side note, this mod was incorporated into both the CCM mods and the most recent fork of this mod called Xonfluence and has been working well for several years. It makes these skins friendly to both remote and touchscreen devices Smile
