2013-05-30, 18:42
working circle comes up for a couple seconds and goes away.
xbmc log says: T:3616 WARNING: could not find codec parameters for D:\tv\Peppa Pig\Season3\Peppa Pig - s03e20. Talent Day.flv
background info: its a video file i downloaded and it works fine in vlc. im using windows xp, xbmc 12.0 and quartz skin.
anyone seen this before or able to shed any light on the problem?
here's some info on the video file:
General
Complete name : D:\tv\Peppa Pig\Season3\Peppa Pig - s03e06. The Camping Holiday.flv
Format : Flash Video
File size : 29.4 MiB
Duration : 10mn 1s
Overall bit rate : 410 Kbps
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : [email protected]
Format settings, CABAC : Yes
Format settings, ReFrames : 4 frames
Codec ID : 7
Duration : 10mn 1s
Bit rate mode : Constant
Nominal bit rate : 700 Kbps
Width : 640 pixels
Height : 360 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 0.003 fps
Original frame rate : 25.000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 1012.685
Audio
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : 10
Duration : 5mn 1s
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 KHz
Compression mode : Lossy
Delay relative to video : 5mn 1s
General
Duration : 10mn 1s
Video
Format : AVC
Codec ID : 7
Duration : 10mn 1s
Width : 640 pixels
Height : 360 pixels
Color space : YUV
Bit depth : 8 bits
Audio
Format : AAC
Format profile : LC
Codec ID : 10
Duration : 5mn 1s
